[petsc-users] signal received error; MatNullSpaceTest; Stokes flow solver with pc fieldsplit and schur complement
Barry Smith
bsmith at mcs.anl.gov
Wed Oct 16 10:19:04 CDT 2013
http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
especially the GAMG version which you also try in the debugger with the argument -start_in_debugger
On Oct 16, 2013, at 9:32 AM, Dave May <dave.mayhem23 at gmail.com> wrote:
> Sounds like a memory error.
> I'd run your code through valgrind to double check. The error could be completely unconnected to the nullspaces.
> Cheers,
> Dave
> On 16 October 2013 16:18, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> Dear all,
> I'm trying to solve a stokes flow with constant viscosity but with non-zero divergence prescribed in the rhs.
> I have a matrix created from DMDA (mDa) of 4 dofs: vx, vy, vz and p respectively.
> I have another DMDA (mDaP) of same size but of 1 dof corresponding to only p.
> I have assigned the null space for constant pressure inside the code. I have assigned two nullspace basis: One corresponding to vector created from mDa that is assigned to outer ksp. Second corresponding to vector created from mDaP that is assigned to a ksp obtained from the fieldsplit corresponding to the schur complement.
> Now when running the code, the solver converges for up to certain size, e.g. 92X110 X 92 (the results for this convegent case with -ksp_view is given at the end of the emal.
> But when I double the size of the grid in each dimension, it gives me a run-time error.
> The options I've used are of the kind:
> -pc_type fieldsplit -pc_fieldsplit_type schur -pc_fieldsplit_dm_splits 0 -pc_fieldsplit_0_fields 0,1,2 -pc_fieldsplit_1_fields 3 -fieldsplit_0_pc_type hypre -fieldsplit_0_ksp_converged_reason -fieldsplit_1_ksp_converged_reason -ksp_converged_reason -ksp_view
> Here are:
> 1. Error message when using hypre for fieldsplit_0
> 2. Error message when using gamg for fieldsplit_0
> 3. -ksp_view of the working case using hypre for filedsplit_0
> I get following error when I use hypre :
> 1. ******************************************************************************************************
> [5]PETSC ERROR: --------------------- Error Message ------------------------------------
> [5]PETSC ERROR: Signal received!
> [5]PETSC ERROR: ------------------------------------------------------------------------
> [5]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
> [5]PETSC ERROR: See docs/changes/index.html for recent updates.
> [5]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [5]PETSC ERROR: See docs/index.html for manual pages.
> [5]PETSC ERROR: /epi/asclepios2/bkhanal/works/AdLemModel/build/src/AdLemMain on a arch-linux2-cxx-debug named nef001 by bkhanal Wed Oct 16 15:08:42 2013
> [5]PETSC ERROR: Libraries linked from /epi/asclepios2/bkhanal/petscDebug/lib
> [5]PETSC ERROR: Configure run at Wed Oct 16 14:18:48 2013
> [5]PETSC ERROR: Configure options --with-mpi-dir=/opt/openmpi-gcc/current/ --with-shared-libraries --prefix=/epi/asclepios2/bkhanal/petscDebug -download-f-blas-lapack=1 --download-metis --download-parmetis --download-superlu_dist --download-scalapack --download-mumps --download-hypre --with-clanguage=cxx
> [5]PETSC ERROR: User provided function() line 0 in unknown directory unknown file
> [6]PETSC ERROR: ------------------------------------------------------------------------
> [6]PETSC ERROR: Caught signal number 15 Terminate: Somet process (or the batch system) has told this process to end
> [6]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [6]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind[6]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
> [6]PETSC ERROR: likely location of problem given in stack below
> [6]PETSC ERROR: --------------------- Stack Frames ------------------------------------
> [6]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [6]PETSC ERROR: INSTEAD the line number of the start of the function
> [6]PETSC ERROR: is given.
> [6]PETSC ERROR: [6] HYPRE_SetupXXX line 130 /tmp/petsc-3.4.3/src/ksp/pc/impls/hypre/hypre.c
> [6]PETSC ERROR: [6] PCSetUp_HYPRE line 94 /tmp/petsc-3.4.3/src/ksp/pc/impls/hypre/hypre.c
> [6]PETSC ERROR: [6] PCSetUp line 868 /tmp/petsc-3.4.3/src/ksp/pc/interface/precon.c
> [6]PETSC ERROR: [6] KSPSetUp line 192 /tmp/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
> [6]PETSC ERROR: [6] KSPSolve line 356 /tmp/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
> [6]PETSC ERROR: [6] MatMult_SchurComplement line 75 /tmp/petsc-3.4.3/src/ksp/ksp/utils/schurm.c
> [6]PETSC ERROR: [6] MatNullSpaceTest line 408 /tmp/petsc-3.4.3/src/mat/interface/matnull.c
> [6]PETSC ERROR: [6] solveModel line 113 "unknowndirectory/"/epi/asclepios2/bkhanal/works/AdLemModel/src/PetscAdLemTaras3D.cxx
> 2. ****************************************************************************************************
> Using gamg instead has errors like following:
> [5]PETSC ERROR: --------------------- Stack Frames ------------------------------------
> [5]PETSC ERROR: Note: The EXACT line numbers in the stack are not available,
> [5]PETSC ERROR: INSTEAD the line number of the start of the function
> [5]PETSC ERROR: is given.
> [5]PETSC ERROR: [5] PetscLLCondensedAddSorted line 1202 /tmp/petsc-3.4.3/include/petsc-private/matimpl.h
> [5]PETSC ERROR: [5] MatPtAPSymbolic_MPIAIJ_MPIAIJ line 124 /tmp/petsc-3.4.3/src/mat/impls/aij/mpi/mpiptap.c
> [5]PETSC ERROR: [5] MatPtAP_MPIAIJ_MPIAIJ line 80 /tmp/petsc-3.4.3/src/mat/impls/aij/mpi/mpiptap.c
> [5]PETSC ERROR: [5] MatPtAP line 8223 /tmp/petsc-3.4.3/src/mat/interface/matrix.c
> [5]PETSC ERROR: [5] createLevel line 144 /tmp/petsc-3.4.3/src/ksp/pc/impls/gamg/gamg.c
> [5]PETSC ERROR: [5] PCSetUp_GAMG line 545 /tmp/petsc-3.4.3/src/ksp/pc/impls/gamg/gamg.c
> [5]PETSC ERROR: [5] PCSetUp line 868 /tmp/petsc-3.4.3/src/ksp/pc/interface/precon.c
> [5]PETSC ERROR: [5] KSPSetUp line 192 /tmp/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
> [5]PETSC ERROR: [5] KSPSolve line 356 /tmp/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
> [5]PETSC ERROR: [5] MatMult_SchurComplement line 75 /tmp/petsc-3.4.3/src/ksp/ksp/utils/schurm.c
> [5]PETSC ERROR: [5] MatNullSpaceTest line 408 /tmp/petsc-3.4.3/src/mat/interface/matnull.c
> [5]PETSC ERROR: [5] solveModel line 113 "unknowndirectory/"/epi/asclepios2/bkhanal/works/AdLemModel/src/PetscAdLemTaras3D.cxx
> 3. ********************************************************************************************************
> BUT, It does give me results when I use a domain of size: 91X109 X 91 (half sized in each dimension) The result along with ksp view in this case is as follows:
> Linear solve converged due to CONVERGED_RTOL iterations 2
> KSP Object: 64 MPI processes
> type: gmres
> GMRES: restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
> GMRES: happy breakdown tolerance 1e-30
> maximum iterations=10000, initial guess is zero
> tolerances: relative=1e-05, absolute=1e-50, divergence=10000
> left preconditioning
> has attached null space
> using PRECONDITIONED norm type for convergence test
> PC Object: 64 MPI processes
> type: fieldsplit
> FieldSplit with Schur preconditioner, blocksize = 4, factorization FULL
> Preconditioner for the Schur complement formed from user provided matrix
> Split info:
> Split number 0 Fields 0, 1, 2
> Split number 1 Fields 3
> KSP solver for A00 block
> KSP Object: (fieldsplit_0_) 64 MPI processes
> type: gmres
> PC Object: (fieldsplit_0_) 64 MPI processes
> type: hypre
> HYPRE BoomerAMG preconditioning
> HYPRE BoomerAMG: Cycle type V
> HYPRE BoomerAMG: Maximum number of levels 25
> HYPRE BoomerAMG: Maximum number of iterations PER hypre call 1
> HYPRE BoomerAMG: Convergence tolerance PER hypre call 0
> HYPRE BoomerAMG: Threshold for strong coupling 0.25
> HYPRE BoomerAMG: Interpolation truncation factor 0
> HYPRE BoomerAMG: Interpolation: max elements per row 0
> HYPRE BoomerAMG: Number of levels of aggressive coarsening 0
> HYPRE BoomerAMG: Number of paths for aggressive coarsening 1
> HYPRE BoomerAMG: Maximum row sums 0.9
> HYPRE BoomerAMG: Sweeps down 1
> HYPRE BoomerAMG: Sweeps up 1
> HYPRE BoomerAMG: Sweeps on coarse 1
> HYPRE BoomerAMG: Relax down symmetric-SOR/Jacobi
> HYPRE BoomerAMG: Relax up symmetric-SOR/Jacobi
> HYPRE BoomerAMG: Relax on coarse Gaussian-elimination
> HYPRE BoomerAMG: Relax weight (all) 1
> HYPRE BoomerAMG: Outer relax weight (all) 1
> HYPRE BoomerAMG: Using CF-relaxation
> HYPRE BoomerAMG: Measure type local
> HYPRE BoomerAMG: Coarsen type Falgout
> HYPRE BoomerAMG: Interpolation type classical
> linear system matrix = precond matrix:
> Matrix Object: 64 MPI processes
> type: mpiaij
> rows=2793120, cols=2793120
> total: nonzeros=221624352, allocated nonzeros=221624352
> total number of mallocs used during MatSetValues calls =0
> using I-node (on process 0) routines: found 14812 nodes, limit used is 5
> KSP solver for S = A11 - A10 inv(A00) A01
> KSP Object: (fieldsplit_1_) 64 MPI processes
> type: gmres
> PC Object: (fieldsplit_1_) 64 MPI processes
> type: bjacobi
> block Jacobi: number of blocks = 64
> Local solve is same for all blocks, in the following KSP and PC objects:
> KSP Object: (fieldsplit_1_sub_) 1 MPI processes
> type: preonly
> using NONE norm type for convergence test
> PC Object: (fieldsplit_1_sub_) 1 MPI processes
> type: ilu
> ILU: out-of-place factorization
> 0 levels of fill
> tolerance for zero pivot 2.22045e-14
> using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
> matrix ordering: natural
> factor fill ratio given 1, needed 1
> Factored matrix follows:
> Matrix Object: 1 MPI processes
> type: seqaij
> rows=14812, cols=14812
> package used to perform factorization: petsc
> total: nonzeros=368098, allocated nonzeros=368098
> not using I-node routines
> type: seqaij
> linear system matrix followed by preconditioner matrix:
> type: schurcomplement
> rows=931040, cols=931040
> Schur complement A11 - A10 inv(A00) A01
> A11
> type: mpiaij
> total: nonzeros=24624928, allocated nonzeros=24624928
> not using I-node (on process 0) routines
> A10
> type: mpiaij
> rows=931040, cols=2793120
> total: nonzeros=73874784, allocated nonzeros=73874784
> KSP of A00
> type: gmres
> type: hypre
> type: mpiaij
> A01
> type: mpiaij
> rows=2793120, cols=931040
> type: mpiaij
> type: mpiaij
> rows=3724160, cols=3724160, bs=4
> total: nonzeros=393998848, allocated nonzeros=393998848
> What could be going wrong here ? Is it something related to null-space setting ? But I do not know why it does not arise for smaller domain sizes!
