[petsc-users] questions about KSP with-pc_type hypre
Mark F. Adams mfadams at lbl.gov
Mon Oct 7 15:16:30 CDT 2013
I assume this is a Lapacian and its not a pure Neumann problem.  I did not quite follow you description.  Do you have some Dirichlet BCs?
Hypre is a very robust solver, for a scalable solver.  ILU, the default PC, is very robust but slow (that's why its the default).  You could try gamg, another AMG solver to get another data point.
On Oct 7, 2013, at 3:08 PM, Roc Wang <pengxwang at hotmail.com> wrote:
> Hello,
>    I am trying to solve a linear system with KSP for a 3-D domain.  The computational domain is a cubic space with Neumann condition on the lateral sides( y, and z directions).  A smaller round plate is on the left side in x direction.  The right side is a rectangular plane either with or without a hole.  In testing studies, the KSP solver works fine both with and without -pc_type hypre runtime option for the domain with a whole plane(without a hole) on the right, but diverges for the case of a plane with a hole with -ps_type hypre option.
>   My question is whether the hypre pre-conditioner is sensitive to the geometry boundary?  If the answer is yes, is there any other pre-conditioner available for my particular case(the domain with a plane which with a hole on the right side) to reduce the number of iterations? Thanks in advance.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131007/c7c4bab5/attachment.html>
