[petsc-users] subksp type of PCGASM
Jed Brown
jedbrown at mcs.anl.gov
Mon Nov 25 07:41:02 CST 2013
Laurent Berenguer <laurent.berenguer at gmail.com> writes:
> Hi everyone,
> I would like to use the Schwarz method with a few processors per subdomain,
> that is to say with parallel subksps. PCGASM seems to do this if I look at
> the example ksp/examples/tutorials/ex8g.c. The problem is that I didn't
> manage to choose the subksp and the subpc. I tried the example ex8g.c with
> the option -user_set_subdomains_solver to set explicitly KSPBCGS as
> subksp,
How exactly did you set this subksp? Did you modify the code or change
the command line arguments? Did the test run without errors when you
don't modify anything?
> and PCJACOBI as subpc and I get the following errors:
> [0]PETSC ERROR: Null argument, when expecting valid pointer!
> [0]PETSC ERROR: Null Object: Parameter # 1!
> [0]PETSC ERROR: VecScatterBegin() line 1616 in
> /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/vec/vec/utils/vscat.c
> [0]PETSC ERROR: KSPSolve() line 441 in
> /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
> Obviously, I am doing something wrong. Do you have any idea/suggestion?
> Thank you,
> Laurent Berenguer
> PS : You can find the full files in attachment, I used runex8g_2
> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [0]PETSC ERROR: See docs/index.html for manual pages.
> [0]PETSC ERROR: ./ex8g on a gnu-debug named trielen by berenguer Mon Nov 25 11:39:08 2013
> [0]PETSC ERROR: Libraries linked from /home/cdcsp/berenguer/PETSC_INSTALL/lib
> [0]PETSC ERROR: Configure run at Mon Nov 25 09:58:03 2013
> [0]PETSC ERROR: Configure options --prefix=/home/cdcsp/berenguer/PETSC_INSTALL --PETSC_DIR=/home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3 --with-mpi-dir=/home/cdcsp/berenguer/mpichinstall/ --with-shared-libraries=0 --with-scalar-type=real --with-precision=double --with-debugging=yes --download-f-blas-lapack=1 --with-valgrind=1
> [0]PETSC ERROR: VecScatterBegin() line 1616 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/vec/vec/utils/vscat.c
> [0]PETSC ERROR: MatMult_MPIAIJ() line 1111 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/mat/impls/aij/mpi/mpiaij.c
> [0]PETSC ERROR: MatMult() line 2179 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/mat/interface/matrix.c
> [0]PETSC ERROR: PCApplyBAorAB() line 679 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: KSP_PCApplyBAorAB() line 257 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/include/petsc-private/kspimpl.h
> [0]PETSC ERROR: KSPGMRESCycle() line 160 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: KSPSolve_GMRES() line 240 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: KSPSolve() line 441 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
> [0]PETSC ERROR: PCApply_GASM() line 535 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/impls/gasm/gasm.c
> [0]PETSC ERROR: PCApply() line 442 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/interface/precon.c
> [0]PETSC ERROR: KSP_PCApply() line 227 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/include/petsc-private/kspimpl.h
> [0]PETSC ERROR: KSPInitialResidual() line 64 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/interface/itres.c
> [1]PETSC ERROR: --------------------- Error Message ------------------------------------
> [1]PETSC ERROR: Null argument, when expecting valid pointer!
> [1]PETSC ERROR: Null Object: Parameter # 1!
> [1]PETSC ERROR: ------------------------------------------------------------------------
> [1]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
> [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> [1]PETSC ERROR: See docs/index.html for manual pages.
> [1]PETSC ERROR: ./ex8g on a gnu-debug named trielen by berenguer Mon Nov 25 11:39:08 2013
> [1]PETSC ERROR: Libraries linked from /home/cdcsp/berenguer/PETSC_INSTALL/lib
> [1]PETSC ERROR: Configure run at Mon Nov 25 09:58:03 2013
> [1]PETSC ERROR: Configure options --prefix=/home/cdcsp/berenguer/PETSC_INSTALL --PETSC_DIR=/home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3 --with-mpi-dir=/home/cdcsp/berenguer/mpichinstall/ --with-shared-libraries=0 --with-scalar-type=real --with-precision=double --with-debugging=yes --download-f-blas-lapack=1 --with-valgrind=1
> [1]PETSC ERROR: VecScatterBegin() line 1616 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/vec/vec/utils/vscat.c
> [1]PETSC ERROR: MatMult_MPIAIJ() line 1111 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/mat/impls/aij/mpi/mpiaij.c
> [1]PETSC ERROR: MatMult() line 2179 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/mat/interface/matrix.c
> [1]PETSC ERROR: PCApplyBAorAB() line 679 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/interface/precon.c
> [1]PETSC ERROR: KSP_PCApplyBAorAB() line 257 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/include/petsc-private/kspimpl.h
> [1]PETSC ERROR: KSPGMRESCycle() line 160 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
> [1]PETSC ERROR: KSPSolve_GMRES() line 240 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
> [1]PETSC ERROR: KSPSolve() line 441 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
> [1]PETSC ERROR: PCApply_GASM() line 535 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/impls/gasm/gasm.c
> [1]PETSC ERROR: PCApply() line 442 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/interface/precon.c
> [1]PETSC ERROR: KSP_PCApply() line 227 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/include/petsc-private/kspimpl.h
> [1]PETSC ERROR: KSPInitialResidual() line 64 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/interface/itres.c
> [1]PETSC ERROR: KSPSolve_GMRES() line 239 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
> [1]PETSC ERROR: main() line 272 in src/ksp/ksp/examples/tutorials/ex8g.c
> application called MPI_Abort(MPI_COMM_WORLD, 85) - process 1
> [0]PETSC ERROR: KSPSolve_GMRES() line 239 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
> [0]PETSC ERROR: main() line 272 in src/ksp/ksp/examples/tutorials/ex8g.c
> application called MPI_Abort(MPI_COMM_WORLD, 85) - process 0
> make: [runex8g_2] Erreur 85 (ignorée)
> static char help[] = "Illustrates use of the preconditioner GASM.\n\
> The Additive Schwarz Method for solving a linear system in parallel with KSP. The\n\
> code indicates the procedure for setting user-defined subdomains. Input\n\
> parameters include:\n\
> -M: Number of mesh points in the x direction\n\
> -N: Number of mesh points in the y direction\n\
> -user_set_subdomain_solvers: User explicitly sets subdomain solvers\n\
> -user_set_subdomains: Use the user-provided subdomain partitioning routine\n\
> With -user_set_subdomains on, the following options are meaningful:\n\
> -Mdomains: Number of subdomains in the x direction \n\
> -Ndomains: Number of subdomains in the y direction \n\
> -overlap: Size of domain overlap in terms of the number of mesh lines in x and y\n\
> General useful options:\n\
> -pc_gasm_print_subdomains: Print the index sets defining the subdomains\n\
> \n";
> Note: This example focuses on setting the subdomains for the GASM
> preconditioner for a problem on a 2D rectangular grid. See ex1.c
> and ex2.c for more detailed comments on the basic usage of KSP
> (including working with matrices and vectors).
> The GASM preconditioner is fully parallel. The user-space routine
> CreateSubdomains2D that computes the domain decomposition is also parallel
> and attempts to generate both subdomains straddling processors and multiple
> domains per processor.
> This matrix in this linear system arises from the discretized Laplacian,
> and thus is not very interesting in terms of experimenting with variants
> of the GASM preconditioner.
> /*T
> Concepts: KSP^Additive Schwarz Method (GASM) with user-defined subdomains
> Processors: n
> T*/
> Include "petscksp.h" so that we can use KSP solvers. Note that this file
> automatically includes:
> petscsys.h - base PETSc routines petscvec.h - vectors
> petscmat.h - matrices
> petscis.h - index sets petscksp.h - Krylov subspace methods
> petscviewer.h - viewers petscpc.h - preconditioners
> #include <petscksp.h>
> #undef __FUNCT__
> #define __FUNCT__ "main"
> int main(int argc,char **args)
> Vec x,b,u; /* approx solution, RHS, exact solution */
> Mat A; /* linear system matrix */
> KSP ksp; /* linear solver context */
> PC pc; /* PC context */
> IS *inneris,*outeris; /* array of index sets that define the subdomains */
> PetscInt overlap = 1; /* width of subdomain overlap */
> PetscInt Nsub; /* number of subdomains */
> PetscInt m = 15,n = 17; /* mesh dimensions in x- and y- directions */
> PetscInt M = 2,N = 1; /* number of subdomains in x- and y- directions */
> PetscInt i,j,Ii,J,Istart,Iend;
> PetscErrorCode ierr;
> PetscMPIInt size;
> PetscBool flg;
> PetscBool user_set_subdomains = PETSC_FALSE;
> PetscScalar v, one = 1.0;
> PetscReal e;
> PetscInitialize(&argc,&args,(char*)0,help);
> ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
> ierr = PetscOptionsGetInt(NULL,"-M",&m,NULL);CHKERRQ(ierr);
> ierr = PetscOptionsGetInt(NULL,"-N",&n,NULL);CHKERRQ(ierr);
> ierr = PetscOptionsGetBool(NULL,"-user_set_subdomains",&user_set_subdomains,NULL);CHKERRQ(ierr);
> ierr = PetscOptionsGetInt(NULL,"-Mdomains",&M,NULL);CHKERRQ(ierr);
> ierr = PetscOptionsGetInt(NULL,"-Ndomains",&N,NULL);CHKERRQ(ierr);
> ierr = PetscOptionsGetInt(NULL,"-overlap",&overlap,NULL);CHKERRQ(ierr);
> Compute the matrix and right-hand-side vector that define
> the linear system, Ax = b.
> Assemble the matrix for the five point stencil, YET AGAIN
> ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
> ierr = MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,m*n,m*n);CHKERRQ(ierr);
> ierr = MatSetFromOptions(A);CHKERRQ(ierr);
> ierr = MatSetUp(A);CHKERRQ(ierr);
> ierr = MatGetOwnershipRange(A,&Istart,&Iend);CHKERRQ(ierr);
> for (Ii=Istart; Ii<Iend; Ii++) {
> v = -1.0; i = Ii/n; j = Ii - i*n;
> if (i>0) {J = Ii - n; ierr = MatSetValues(A,1,&Ii,1,&J,&v,INSERT_VALUES);CHKERRQ(ierr);}
> if (i<m-1) {J = Ii + n; ierr = MatSetValues(A,1,&Ii,1,&J,&v,INSERT_VALUES);CHKERRQ(ierr);}
> if (j>0) {J = Ii - 1; ierr = MatSetValues(A,1,&Ii,1,&J,&v,INSERT_VALUES);CHKERRQ(ierr);}
> if (j<n-1) {J = Ii + 1; ierr = MatSetValues(A,1,&Ii,1,&J,&v,INSERT_VALUES);CHKERRQ(ierr);}
> v = 4.0; ierr = MatSetValues(A,1,&Ii,1,&Ii,&v,INSERT_VALUES);CHKERRQ(ierr);
> ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
> Create and set vectors
> ierr = VecCreate(PETSC_COMM_WORLD,&b);CHKERRQ(ierr);
> ierr = VecSetSizes(b,PETSC_DECIDE,m*n);CHKERRQ(ierr);
> ierr = VecSetFromOptions(b);CHKERRQ(ierr);
> ierr = VecDuplicate(b,&u);CHKERRQ(ierr);
> ierr = VecDuplicate(b,&x);CHKERRQ(ierr);
> ierr = VecSet(u,one);CHKERRQ(ierr);
> ierr = MatMult(A,u,b);CHKERRQ(ierr);
> Create linear solver context
> ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
> Set operators. Here the matrix that defines the linear system
> also serves as the preconditioning matrix.
> ierr = KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);CHKERRQ(ierr);
> Set the default preconditioner for this program to be GASM
> ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
> ierr = PCSetType(pc,PCGASM);CHKERRQ(ierr);
> Define the problem decomposition
> Basic method, should be sufficient for the needs of many users.
> Set the overlap, using the default PETSc decomposition via
> PCGASMSetOverlap(pc,overlap);
> Could instead use the option -pc_gasm_overlap <ovl>
> Set the total number of blocks via -pc_gasm_blocks <blks>
> Note: The GASM default is to use 1 block per processor. To
> experiment on a single processor with various overlaps, you
> must specify use of multiple blocks!
> More advanced method, setting user-defined subdomains
> Firstly, create index sets that define the subdomains. The utility
> routine PCGASMCreateSubdomains2D() is a simple example, which partitions
> the 2D grid into MxN subdomains with an optional overlap.
> More generally, the user should write a custom routine for a particular
> problem geometry.
> Then call PCGASMSetLocalSubdomains() with resulting index sets
> to set the subdomains for the GASM preconditioner.
> if (!user_set_subdomains) { /* basic version */
> ierr = PCGASMSetOverlap(pc,overlap);CHKERRQ(ierr);
> } else { /* advanced version */
> ierr = PCGASMCreateSubdomains2D(pc, m,n,M,N,1,overlap,&Nsub,&inneris,&outeris);CHKERRQ(ierr);
> ierr = PCGASMSetSubdomains(pc,Nsub,inneris,outeris);CHKERRQ(ierr);
> flg = PETSC_FALSE;
> ierr = PetscOptionsGetBool(NULL,"-subdomain_view",&flg,NULL);CHKERRQ(ierr);
> if (flg) {
> ierr = PetscPrintf(PETSC_COMM_SELF,"Nmesh points: %D x %D; subdomain partition: %D x %D; overlap: %D; Nsub: %D\n",m,n,M,N,overlap,Nsub);CHKERRQ(ierr);
> ierr = PetscPrintf(PETSC_COMM_SELF,"Outer IS:\n");CHKERRQ(ierr);
> for (i=0; i<Nsub; i++) {
> ierr = PetscPrintf(PETSC_COMM_SELF," outer IS[%d]\n",i);CHKERRQ(ierr);
> ierr = ISView(outeris[i],PETSC_VIEWER_STDOUT_SELF);CHKERRQ(ierr);
> ierr = PetscPrintf(PETSC_COMM_SELF,"Inner IS:\n");CHKERRQ(ierr);
> ierr = PetscPrintf(PETSC_COMM_SELF," inner IS[%d]\n",i);CHKERRQ(ierr);
> ierr = ISView(inneris[i],PETSC_VIEWER_STDOUT_SELF);CHKERRQ(ierr);
> Set the linear solvers for the subblocks
> Basic method, should be sufficient for the needs of most users.
> By default, the GASM preconditioner uses the same solver on each
> block of the problem. To set the same solver options on all blocks,
> use the prefix -sub before the usual PC and KSP options, e.g.,
> -sub_pc_type <pc> -sub_ksp_type <ksp> -sub_ksp_rtol 1.e-4
> Advanced method, setting different solvers for various blocks.
> Note that each block's KSP context is completely independent of
> the others, and the full range of uniprocessor KSP options is
> available for each block.
> - Use PCGASMGetSubKSP() to extract the array of KSP contexts for
> the local blocks.
> - See ex7.c for a simple example of setting different linear solvers
> for the individual blocks for the block Jacobi method (which is
> equivalent to the GASM method with zero overlap).
> flg = PETSC_FALSE;
> ierr = PetscOptionsGetBool(NULL,"-user_set_subdomain_solvers",&flg,NULL);CHKERRQ(ierr);
> //flg=PETSC_TRUE;
> if (flg) {
> KSP *subksp; /* array of KSP contexts for local subblocks */
> PetscInt nlocal,first; /* number of local subblocks, first local subblock */
> PC subpc; /* PC context for subblock */
> PetscBool isasm;
> ierr = PetscPrintf(PETSC_COMM_WORLD,"User explicitly sets subdomain solvers.\n");CHKERRQ(ierr);
> Set runtime options
> ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
> Flag an error if PCTYPE is changed from the runtime options
> ierr = PetscObjectTypeCompare((PetscObject)pc,PCGASM,&isasm);CHKERRQ(ierr);
> if (!isasm) SETERRQ(PETSC_COMM_WORLD,1,"Cannot Change the PCTYPE when manually changing the subdomain solver settings");
> Call KSPSetUp() to set the block Jacobi data structures (including
> creation of an internal KSP context for each block).
> Note: KSPSetUp() MUST be called before PCGASMGetSubKSP().
> ierr = KSPSetUp(ksp);CHKERRQ(ierr);
> Extract the array of KSP contexts for the local blocks
> ierr = PCGASMGetSubKSP(pc,&nlocal,&first,&subksp);CHKERRQ(ierr);
> Loop over the local blocks, setting various KSP options
> for each block.
> for (i=0; i<nlocal; i++) {
> ierr = KSPGetPC(subksp[i],&subpc);CHKERRQ(ierr);
> ierr = PCSetType(subpc,PCJACOBI);CHKERRQ(ierr);
> ierr = KSPSetType(subksp[i],KSPGMRES);CHKERRQ(ierr);
> ierr = KSPSetTolerances(subksp[i],1.e-7,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);CHKERRQ(ierr);
> } else {
> Set runtime options
> Solve the linear system
> ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
> Compare result to the exact solution
> ierr = VecAXPY(x,-1.0,u);CHKERRQ(ierr);
> ierr = VecNorm(x,NORM_INFINITY, &e);CHKERRQ(ierr);
> flg = PETSC_FALSE;
> ierr = PetscOptionsGetBool(NULL,"-print_error",&flg,NULL);CHKERRQ(ierr);
> if (flg) {
> ierr = PetscPrintf(PETSC_COMM_WORLD, "Infinity norm of the error: %G\n", e);CHKERRQ(ierr);
> Free work space. All PETSc objects should be destroyed when they
> are no longer needed.
> if (user_set_subdomains) {
> ierr = PCGASMDestroySubdomains(Nsub, inneris, outeris);CHKERRQ(ierr);
> ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
> ierr = VecDestroy(&u);CHKERRQ(ierr);
> ierr = VecDestroy(&x);CHKERRQ(ierr);
> ierr = VecDestroy(&b);CHKERRQ(ierr);
> ierr = MatDestroy(&A);CHKERRQ(ierr);
> ierr = PetscFinalize();
> return 0;
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131125/73d34eda/attachment.pgp>
