[petsc-users] subksp type of PCGASM
    Laurent Berenguer
    laurent.berenguer at gmail.com
    Mon Nov 25 05:51:00 CST 2013
Hi everyone,
I would like to use the Schwarz method with a few processors per subdomain,
that is to say with parallel subksps. PCGASM seems to do this if I look at
the example ksp/examples/tutorials/ex8g.c. The problem is that I didn't
manage to choose the subksp and the subpc. I tried the example ex8g.c with
the option -user_set_subdomains_solver to set explicitly KSPBCGS as subksp,
and PCJACOBI as subpc and I get the following errors:
[0]PETSC ERROR: Null argument, when expecting valid pointer!
[0]PETSC ERROR: Null Object: Parameter # 1!
[0]PETSC ERROR: VecScatterBegin() line 1616 in
/home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/vec/vec/utils/vscat.c
[0]PETSC ERROR: KSPSolve() line 441 in
/home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
Obviously, I am doing something wrong. Do you have any idea/suggestion?
Thank you,
Laurent Berenguer
PS : You can find the full files in attachment, I used runex8g_2
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131125/f04bf433/attachment-0001.html>
[0]PETSC ERROR: --------------------- Error Message ------------------------------------
[0]PETSC ERROR: ------------------------------------------------------------------------
[0]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
[0]PETSC ERROR: See docs/changes/index.html for recent updates.
[0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[0]PETSC ERROR: See docs/index.html for manual pages.
[0]PETSC ERROR: ./ex8g on a gnu-debug named trielen by berenguer Mon Nov 25 11:39:08 2013
[0]PETSC ERROR: Libraries linked from /home/cdcsp/berenguer/PETSC_INSTALL/lib
[0]PETSC ERROR: Configure run at Mon Nov 25 09:58:03 2013
[0]PETSC ERROR: Configure options --prefix=/home/cdcsp/berenguer/PETSC_INSTALL --PETSC_DIR=/home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3 --with-mpi-dir=/home/cdcsp/berenguer/mpichinstall/ --with-shared-libraries=0 --with-scalar-type=real --with-precision=double --with-debugging=yes --download-f-blas-lapack=1 --with-valgrind=1
[0]PETSC ERROR: VecScatterBegin() line 1616 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/vec/vec/utils/vscat.c
[0]PETSC ERROR: MatMult_MPIAIJ() line 1111 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/mat/impls/aij/mpi/mpiaij.c
[0]PETSC ERROR: MatMult() line 2179 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/mat/interface/matrix.c
[0]PETSC ERROR: PCApplyBAorAB() line 679 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: KSP_PCApplyBAorAB() line 257 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/include/petsc-private/kspimpl.h
[0]PETSC ERROR: KSPGMRESCycle() line 160 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: KSPSolve_GMRES() line 240 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: KSPSolve() line 441 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: PCApply_GASM() line 535 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/impls/gasm/gasm.c
[0]PETSC ERROR: PCApply() line 442 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: KSP_PCApply() line 227 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/include/petsc-private/kspimpl.h
[0]PETSC ERROR: KSPInitialResidual() line 64 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/interface/itres.c
[1]PETSC ERROR: --------------------- Error Message ------------------------------------
[1]PETSC ERROR: Null argument, when expecting valid pointer!
[1]PETSC ERROR: Null Object: Parameter # 1!
[1]PETSC ERROR: ------------------------------------------------------------------------
[1]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
[1]PETSC ERROR: See docs/changes/index.html for recent updates.
[1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
[1]PETSC ERROR: See docs/index.html for manual pages.
[1]PETSC ERROR: ./ex8g on a gnu-debug named trielen by berenguer Mon Nov 25 11:39:08 2013
[1]PETSC ERROR: Libraries linked from /home/cdcsp/berenguer/PETSC_INSTALL/lib
[1]PETSC ERROR: Configure run at Mon Nov 25 09:58:03 2013
[1]PETSC ERROR: Configure options --prefix=/home/cdcsp/berenguer/PETSC_INSTALL --PETSC_DIR=/home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3 --with-mpi-dir=/home/cdcsp/berenguer/mpichinstall/ --with-shared-libraries=0 --with-scalar-type=real --with-precision=double --with-debugging=yes --download-f-blas-lapack=1 --with-valgrind=1
[1]PETSC ERROR: VecScatterBegin() line 1616 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/vec/vec/utils/vscat.c
[1]PETSC ERROR: MatMult_MPIAIJ() line 1111 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/mat/impls/aij/mpi/mpiaij.c
[1]PETSC ERROR: MatMult() line 2179 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/mat/interface/matrix.c
[1]PETSC ERROR: PCApplyBAorAB() line 679 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/interface/precon.c
[1]PETSC ERROR: KSP_PCApplyBAorAB() line 257 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/include/petsc-private/kspimpl.h
[1]PETSC ERROR: KSPGMRESCycle() line 160 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
[1]PETSC ERROR: KSPSolve_GMRES() line 240 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
[1]PETSC ERROR: KSPSolve() line 441 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
[1]PETSC ERROR: PCApply_GASM() line 535 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/impls/gasm/gasm.c
[1]PETSC ERROR: PCApply() line 442 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/interface/precon.c
[1]PETSC ERROR: KSP_PCApply() line 227 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/include/petsc-private/kspimpl.h
[1]PETSC ERROR: KSPInitialResidual() line 64 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/interface/itres.c
[1]PETSC ERROR: KSPSolve_GMRES() line 239 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
[1]PETSC ERROR: main() line 272 in src/ksp/ksp/examples/tutorials/ex8g.c
application called MPI_Abort(MPI_COMM_WORLD, 85) - process 1
[0]PETSC ERROR: KSPSolve_GMRES() line 239 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: main() line 272 in src/ksp/ksp/examples/tutorials/ex8g.c
application called MPI_Abort(MPI_COMM_WORLD, 85) - process 0
make: [runex8g_2] Erreur 85 (ignorée)
Type: text/x-csrc
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131125/f04bf433/attachment-0001.c>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131125/f04bf433/attachment-0001.obj>
