[petsc-users] subksp type of PCGASM
Laurent Berenguer
laurent.berenguer at gmail.com
Mon Nov 25 08:44:17 CST 2013
>How exactly did you set this subksp? Did you modify the code or change
>the command line arguments? Did the test run without errors when you
>don't modify anything?
I tried both methods, the error is the same in both cases :
- I added the option -user_set_subdomain_solvers and modified the code
from
ierr = PCSetType(subpc,PCILU);CHKERRQ(ierr);
to
ierr = PCSetType(subpc,PCJACOBI);CHKERRQ(ierr);
- Or I only added -sub_ksp_type gmres without changing the code.
The example runs correctly when I change nothing. But I'm not sure
what is the default subksp. When I change nothing in the code but it
seems to be KSPPREONLY.
2013/11/25 Jed Brown <jedbrown at mcs.anl.gov>:
> Laurent Berenguer <laurent.berenguer at gmail.com> writes:
>> Hi everyone,
>> I would like to use the Schwarz method with a few processors per subdomain,
>> that is to say with parallel subksps. PCGASM seems to do this if I look at
>> the example ksp/examples/tutorials/ex8g.c. The problem is that I didn't
>> manage to choose the subksp and the subpc. I tried the example ex8g.c with
>> the option -user_set_subdomains_solver to set explicitly KSPBCGS as
>> subksp,
>> and PCJACOBI as subpc and I get the following errors:
>> [0]PETSC ERROR: Null argument, when expecting valid pointer!
>> [0]PETSC ERROR: Null Object: Parameter # 1!
>> [0]PETSC ERROR: VecScatterBegin() line 1616 in
>> /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/vec/vec/utils/vscat.c
>> [0]PETSC ERROR: KSPSolve() line 441 in
>> /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
>> Obviously, I am doing something wrong. Do you have any idea/suggestion?
>> Thank you,
>> Laurent Berenguer
>> PS : You can find the full files in attachment, I used runex8g_2
>> [0]PETSC ERROR: --------------------- Error Message ------------------------------------
>> [0]PETSC ERROR: ------------------------------------------------------------------------
>> [0]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [0]PETSC ERROR: See docs/index.html for manual pages.
>> [0]PETSC ERROR: ./ex8g on a gnu-debug named trielen by berenguer Mon Nov 25 11:39:08 2013
>> [0]PETSC ERROR: Libraries linked from /home/cdcsp/berenguer/PETSC_INSTALL/lib
>> [0]PETSC ERROR: Configure run at Mon Nov 25 09:58:03 2013
>> [0]PETSC ERROR: Configure options --prefix=/home/cdcsp/berenguer/PETSC_INSTALL --PETSC_DIR=/home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3 --with-mpi-dir=/home/cdcsp/berenguer/mpichinstall/ --with-shared-libraries=0 --with-scalar-type=real --with-precision=double --with-debugging=yes --download-f-blas-lapack=1 --with-valgrind=1
>> [0]PETSC ERROR: VecScatterBegin() line 1616 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/vec/vec/utils/vscat.c
>> [0]PETSC ERROR: MatMult_MPIAIJ() line 1111 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/mat/impls/aij/mpi/mpiaij.c
>> [0]PETSC ERROR: MatMult() line 2179 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/mat/interface/matrix.c
>> [0]PETSC ERROR: PCApplyBAorAB() line 679 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/interface/precon.c
>> [0]PETSC ERROR: KSP_PCApplyBAorAB() line 257 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/include/petsc-private/kspimpl.h
>> [0]PETSC ERROR: KSPGMRESCycle() line 160 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
>> [0]PETSC ERROR: KSPSolve_GMRES() line 240 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
>> [0]PETSC ERROR: KSPSolve() line 441 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
>> [0]PETSC ERROR: PCApply_GASM() line 535 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/impls/gasm/gasm.c
>> [0]PETSC ERROR: PCApply() line 442 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/interface/precon.c
>> [0]PETSC ERROR: KSP_PCApply() line 227 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/include/petsc-private/kspimpl.h
>> [0]PETSC ERROR: KSPInitialResidual() line 64 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/interface/itres.c
>> [1]PETSC ERROR: --------------------- Error Message ------------------------------------
>> [1]PETSC ERROR: Null argument, when expecting valid pointer!
>> [1]PETSC ERROR: Null Object: Parameter # 1!
>> [1]PETSC ERROR: ------------------------------------------------------------------------
>> [1]PETSC ERROR: Petsc Release Version 3.4.3, Oct, 15, 2013
>> [1]PETSC ERROR: See docs/changes/index.html for recent updates.
>> [1]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>> [1]PETSC ERROR: See docs/index.html for manual pages.
>> [1]PETSC ERROR: ./ex8g on a gnu-debug named trielen by berenguer Mon Nov 25 11:39:08 2013
>> [1]PETSC ERROR: Libraries linked from /home/cdcsp/berenguer/PETSC_INSTALL/lib
>> [1]PETSC ERROR: Configure run at Mon Nov 25 09:58:03 2013
>> [1]PETSC ERROR: Configure options --prefix=/home/cdcsp/berenguer/PETSC_INSTALL --PETSC_DIR=/home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3 --with-mpi-dir=/home/cdcsp/berenguer/mpichinstall/ --with-shared-libraries=0 --with-scalar-type=real --with-precision=double --with-debugging=yes --download-f-blas-lapack=1 --with-valgrind=1
>> [1]PETSC ERROR: VecScatterBegin() line 1616 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/vec/vec/utils/vscat.c
>> [1]PETSC ERROR: MatMult_MPIAIJ() line 1111 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/mat/impls/aij/mpi/mpiaij.c
>> [1]PETSC ERROR: MatMult() line 2179 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/mat/interface/matrix.c
>> [1]PETSC ERROR: PCApplyBAorAB() line 679 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/interface/precon.c
>> [1]PETSC ERROR: KSP_PCApplyBAorAB() line 257 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/include/petsc-private/kspimpl.h
>> [1]PETSC ERROR: KSPGMRESCycle() line 160 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
>> [1]PETSC ERROR: KSPSolve_GMRES() line 240 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
>> [1]PETSC ERROR: KSPSolve() line 441 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/interface/itfunc.c
>> [1]PETSC ERROR: PCApply_GASM() line 535 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/impls/gasm/gasm.c
>> [1]PETSC ERROR: PCApply() line 442 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/pc/interface/precon.c
>> [1]PETSC ERROR: KSP_PCApply() line 227 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/include/petsc-private/kspimpl.h
>> [1]PETSC ERROR: KSPInitialResidual() line 64 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/interface/itres.c
>> [1]PETSC ERROR: KSPSolve_GMRES() line 239 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
>> [1]PETSC ERROR: main() line 272 in src/ksp/ksp/examples/tutorials/ex8g.c
>> application called MPI_Abort(MPI_COMM_WORLD, 85) - process 1
>> [0]PETSC ERROR: KSPSolve_GMRES() line 239 in /home/cdcsp/berenguer/PETSC_INSTALL/petsc-3.4.3/src/ksp/ksp/impls/gmres/gmres.c
>> [0]PETSC ERROR: main() line 272 in src/ksp/ksp/examples/tutorials/ex8g.c
>> application called MPI_Abort(MPI_COMM_WORLD, 85) - process 0
>> make: [runex8g_2] Erreur 85 (ignorée)
>> static char help[] = "Illustrates use of the preconditioner GASM.\n\
>> The Additive Schwarz Method for solving a linear system in parallel with KSP. The\n\
>> code indicates the procedure for setting user-defined subdomains. Input\n\
>> parameters include:\n\
>> -M: Number of mesh points in the x direction\n\
>> -N: Number of mesh points in the y direction\n\
>> -user_set_subdomain_solvers: User explicitly sets subdomain solvers\n\
>> -user_set_subdomains: Use the user-provided subdomain partitioning routine\n\
>> With -user_set_subdomains on, the following options are meaningful:\n\
>> -Mdomains: Number of subdomains in the x direction \n\
>> -Ndomains: Number of subdomains in the y direction \n\
>> -overlap: Size of domain overlap in terms of the number of mesh lines in x and y\n\
>> General useful options:\n\
>> -pc_gasm_print_subdomains: Print the index sets defining the subdomains\n\
>> \n";
>> Note: This example focuses on setting the subdomains for the GASM
>> preconditioner for a problem on a 2D rectangular grid. See ex1.c
>> and ex2.c for more detailed comments on the basic usage of KSP
>> (including working with matrices and vectors).
>> The GASM preconditioner is fully parallel. The user-space routine
>> CreateSubdomains2D that computes the domain decomposition is also parallel
>> and attempts to generate both subdomains straddling processors and multiple
>> domains per processor.
>> This matrix in this linear system arises from the discretized Laplacian,
>> and thus is not very interesting in terms of experimenting with variants
>> of the GASM preconditioner.
>> /*T
>> Concepts: KSP^Additive Schwarz Method (GASM) with user-defined subdomains
>> Processors: n
>> T*/
>> Include "petscksp.h" so that we can use KSP solvers. Note that this file
>> automatically includes:
>> petscsys.h - base PETSc routines petscvec.h - vectors
>> petscmat.h - matrices
>> petscis.h - index sets petscksp.h - Krylov subspace methods
>> petscviewer.h - viewers petscpc.h - preconditioners
>> #include <petscksp.h>
>> #undef __FUNCT__
>> #define __FUNCT__ "main"
>> int main(int argc,char **args)
>> Vec x,b,u; /* approx solution, RHS, exact solution */
>> Mat A; /* linear system matrix */
>> KSP ksp; /* linear solver context */
>> PC pc; /* PC context */
>> IS *inneris,*outeris; /* array of index sets that define the subdomains */
>> PetscInt overlap = 1; /* width of subdomain overlap */
>> PetscInt Nsub; /* number of subdomains */
>> PetscInt m = 15,n = 17; /* mesh dimensions in x- and y- directions */
>> PetscInt M = 2,N = 1; /* number of subdomains in x- and y- directions */
>> PetscInt i,j,Ii,J,Istart,Iend;
>> PetscErrorCode ierr;
>> PetscMPIInt size;
>> PetscBool flg;
>> PetscBool user_set_subdomains = PETSC_FALSE;
>> PetscScalar v, one = 1.0;
>> PetscReal e;
>> PetscInitialize(&argc,&args,(char*)0,help);
>> ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
>> ierr = PetscOptionsGetInt(NULL,"-M",&m,NULL);CHKERRQ(ierr);
>> ierr = PetscOptionsGetInt(NULL,"-N",&n,NULL);CHKERRQ(ierr);
>> ierr = PetscOptionsGetBool(NULL,"-user_set_subdomains",&user_set_subdomains,NULL);CHKERRQ(ierr);
>> ierr = PetscOptionsGetInt(NULL,"-Mdomains",&M,NULL);CHKERRQ(ierr);
>> ierr = PetscOptionsGetInt(NULL,"-Ndomains",&N,NULL);CHKERRQ(ierr);
>> ierr = PetscOptionsGetInt(NULL,"-overlap",&overlap,NULL);CHKERRQ(ierr);
>> Compute the matrix and right-hand-side vector that define
>> the linear system, Ax = b.
>> Assemble the matrix for the five point stencil, YET AGAIN
>> ierr = MatCreate(PETSC_COMM_WORLD,&A);CHKERRQ(ierr);
>> ierr = MatSetSizes(A,PETSC_DECIDE,PETSC_DECIDE,m*n,m*n);CHKERRQ(ierr);
>> ierr = MatSetFromOptions(A);CHKERRQ(ierr);
>> ierr = MatSetUp(A);CHKERRQ(ierr);
>> ierr = MatGetOwnershipRange(A,&Istart,&Iend);CHKERRQ(ierr);
>> for (Ii=Istart; Ii<Iend; Ii++) {
>> v = -1.0; i = Ii/n; j = Ii - i*n;
>> if (i>0) {J = Ii - n; ierr = MatSetValues(A,1,&Ii,1,&J,&v,INSERT_VALUES);CHKERRQ(ierr);}
>> if (i<m-1) {J = Ii + n; ierr = MatSetValues(A,1,&Ii,1,&J,&v,INSERT_VALUES);CHKERRQ(ierr);}
>> if (j>0) {J = Ii - 1; ierr = MatSetValues(A,1,&Ii,1,&J,&v,INSERT_VALUES);CHKERRQ(ierr);}
>> if (j<n-1) {J = Ii + 1; ierr = MatSetValues(A,1,&Ii,1,&J,&v,INSERT_VALUES);CHKERRQ(ierr);}
>> v = 4.0; ierr = MatSetValues(A,1,&Ii,1,&Ii,&v,INSERT_VALUES);CHKERRQ(ierr);
>> ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>> Create and set vectors
>> ierr = VecCreate(PETSC_COMM_WORLD,&b);CHKERRQ(ierr);
>> ierr = VecSetSizes(b,PETSC_DECIDE,m*n);CHKERRQ(ierr);
>> ierr = VecSetFromOptions(b);CHKERRQ(ierr);
>> ierr = VecDuplicate(b,&u);CHKERRQ(ierr);
>> ierr = VecDuplicate(b,&x);CHKERRQ(ierr);
>> ierr = VecSet(u,one);CHKERRQ(ierr);
>> ierr = MatMult(A,u,b);CHKERRQ(ierr);
>> Create linear solver context
>> ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>> Set operators. Here the matrix that defines the linear system
>> also serves as the preconditioning matrix.
>> ierr = KSPSetOperators(ksp,A,A,DIFFERENT_NONZERO_PATTERN);CHKERRQ(ierr);
>> Set the default preconditioner for this program to be GASM
>> ierr = KSPGetPC(ksp,&pc);CHKERRQ(ierr);
>> ierr = PCSetType(pc,PCGASM);CHKERRQ(ierr);
>> Define the problem decomposition
>> Basic method, should be sufficient for the needs of many users.
>> Set the overlap, using the default PETSc decomposition via
>> PCGASMSetOverlap(pc,overlap);
>> Could instead use the option -pc_gasm_overlap <ovl>
>> Set the total number of blocks via -pc_gasm_blocks <blks>
>> Note: The GASM default is to use 1 block per processor. To
>> experiment on a single processor with various overlaps, you
>> must specify use of multiple blocks!
>> More advanced method, setting user-defined subdomains
>> Firstly, create index sets that define the subdomains. The utility
>> routine PCGASMCreateSubdomains2D() is a simple example, which partitions
>> the 2D grid into MxN subdomains with an optional overlap.
>> More generally, the user should write a custom routine for a particular
>> problem geometry.
>> Then call PCGASMSetLocalSubdomains() with resulting index sets
>> to set the subdomains for the GASM preconditioner.
>> if (!user_set_subdomains) { /* basic version */
>> ierr = PCGASMSetOverlap(pc,overlap);CHKERRQ(ierr);
>> } else { /* advanced version */
>> ierr = PCGASMCreateSubdomains2D(pc, m,n,M,N,1,overlap,&Nsub,&inneris,&outeris);CHKERRQ(ierr);
>> ierr = PCGASMSetSubdomains(pc,Nsub,inneris,outeris);CHKERRQ(ierr);
>> flg = PETSC_FALSE;
>> ierr = PetscOptionsGetBool(NULL,"-subdomain_view",&flg,NULL);CHKERRQ(ierr);
>> if (flg) {
>> ierr = PetscPrintf(PETSC_COMM_SELF,"Nmesh points: %D x %D; subdomain partition: %D x %D; overlap: %D; Nsub: %D\n",m,n,M,N,overlap,Nsub);CHKERRQ(ierr);
>> ierr = PetscPrintf(PETSC_COMM_SELF,"Outer IS:\n");CHKERRQ(ierr);
>> for (i=0; i<Nsub; i++) {
>> ierr = PetscPrintf(PETSC_COMM_SELF," outer IS[%d]\n",i);CHKERRQ(ierr);
>> ierr = ISView(outeris[i],PETSC_VIEWER_STDOUT_SELF);CHKERRQ(ierr);
>> ierr = PetscPrintf(PETSC_COMM_SELF,"Inner IS:\n");CHKERRQ(ierr);
>> ierr = PetscPrintf(PETSC_COMM_SELF," inner IS[%d]\n",i);CHKERRQ(ierr);
>> ierr = ISView(inneris[i],PETSC_VIEWER_STDOUT_SELF);CHKERRQ(ierr);
>> Set the linear solvers for the subblocks
>> Basic method, should be sufficient for the needs of most users.
>> By default, the GASM preconditioner uses the same solver on each
>> block of the problem. To set the same solver options on all blocks,
>> use the prefix -sub before the usual PC and KSP options, e.g.,
>> -sub_pc_type <pc> -sub_ksp_type <ksp> -sub_ksp_rtol 1.e-4
>> Advanced method, setting different solvers for various blocks.
>> Note that each block's KSP context is completely independent of
>> the others, and the full range of uniprocessor KSP options is
>> available for each block.
>> - Use PCGASMGetSubKSP() to extract the array of KSP contexts for
>> the local blocks.
>> - See ex7.c for a simple example of setting different linear solvers
>> for the individual blocks for the block Jacobi method (which is
>> equivalent to the GASM method with zero overlap).
>> flg = PETSC_FALSE;
>> ierr = PetscOptionsGetBool(NULL,"-user_set_subdomain_solvers",&flg,NULL);CHKERRQ(ierr);
>> //flg=PETSC_TRUE;
>> if (flg) {
>> KSP *subksp; /* array of KSP contexts for local subblocks */
>> PetscInt nlocal,first; /* number of local subblocks, first local subblock */
>> PC subpc; /* PC context for subblock */
>> PetscBool isasm;
>> ierr = PetscPrintf(PETSC_COMM_WORLD,"User explicitly sets subdomain solvers.\n");CHKERRQ(ierr);
>> Set runtime options
>> ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>> Flag an error if PCTYPE is changed from the runtime options
>> ierr = PetscObjectTypeCompare((PetscObject)pc,PCGASM,&isasm);CHKERRQ(ierr);
>> if (!isasm) SETERRQ(PETSC_COMM_WORLD,1,"Cannot Change the PCTYPE when manually changing the subdomain solver settings");
>> Call KSPSetUp() to set the block Jacobi data structures (including
>> creation of an internal KSP context for each block).
>> Note: KSPSetUp() MUST be called before PCGASMGetSubKSP().
>> ierr = KSPSetUp(ksp);CHKERRQ(ierr);
>> Extract the array of KSP contexts for the local blocks
>> ierr = PCGASMGetSubKSP(pc,&nlocal,&first,&subksp);CHKERRQ(ierr);
>> Loop over the local blocks, setting various KSP options
>> for each block.
>> for (i=0; i<nlocal; i++) {
>> ierr = KSPGetPC(subksp[i],&subpc);CHKERRQ(ierr);
>> ierr = KSPSetType(subksp[i],KSPGMRES);CHKERRQ(ierr);
>> ierr = KSPSetTolerances(subksp[i],1.e-7,PETSC_DEFAULT,PETSC_DEFAULT,PETSC_DEFAULT);CHKERRQ(ierr);
>> } else {
>> Set runtime options
>> Solve the linear system
>> ierr = KSPSolve(ksp,b,x);CHKERRQ(ierr);
>> Compare result to the exact solution
>> ierr = VecAXPY(x,-1.0,u);CHKERRQ(ierr);
>> ierr = VecNorm(x,NORM_INFINITY, &e);CHKERRQ(ierr);
>> flg = PETSC_FALSE;
>> ierr = PetscOptionsGetBool(NULL,"-print_error",&flg,NULL);CHKERRQ(ierr);
>> if (flg) {
>> ierr = PetscPrintf(PETSC_COMM_WORLD, "Infinity norm of the error: %G\n", e);CHKERRQ(ierr);
>> Free work space. All PETSc objects should be destroyed when they
>> are no longer needed.
>> if (user_set_subdomains) {
>> ierr = PCGASMDestroySubdomains(Nsub, inneris, outeris);CHKERRQ(ierr);
>> ierr = KSPDestroy(&ksp);CHKERRQ(ierr);
>> ierr = VecDestroy(&u);CHKERRQ(ierr);
>> ierr = VecDestroy(&x);CHKERRQ(ierr);
>> ierr = VecDestroy(&b);CHKERRQ(ierr);
>> ierr = MatDestroy(&A);CHKERRQ(ierr);
>> ierr = PetscFinalize();
>> return 0;
Laurent Berenguer
