[petsc-users] GAMG processor reduction
Dave May
dave.mayhem23 at gmail.com
Thu Nov 21 15:43:10 CST 2013
Is using the "big communicator" really the right way to go? What happens
when I call VecNorm() when the local size on most ranks =0.. the global
reduction still has to be performed and all ranks in the original
communicator associated with the fine get participate.
I thought the primary advantage/reason to use less ranks with small
distributed systems was to avoid seeing the network latency when there is
little computational work. I don't see how using the big communicator
avoids this.
Am I missing something?
Cheers,
Dave
On Thursday, 21 November 2013, Jed Brown wrote:
> John Mousel <john.mousel at gmail.com <javascript:;>> writes:
> > Thanks Jed. How does this represent itself in the KSPView output?
> I'm afraid it's not there, though you can extract the ownership ranges
> From code.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131121/6d33f168/attachment.html>
