[petsc-users] Modify RHS values at each iteration
Jed Brown
jedbrown at mcs.anl.gov
Thu Nov 21 06:41:49 CST 2013
TAY wee-beng <zonexo at gmail.com> writes:
> Hi Jed,
> I need a solve a Poisson equation, which is part of my finite volume CFD
> code.
> The RHS terms are calculated from the velocity.
> In the standard mtd, the RHS terms are calculated from the velocity,
> which then solves the Poisson eqn to get the pressure.
> Now, to improve the accuracy of the pressure obtained, a paper suggested
> obtaining the pressure from the velocity in 1 iteration. Then use the
> new pressure for the momentum eqn to get a more accurate intermediate
> velocity. The RHS terms are recomputed again using the new velocity,
> which is then used to calculate the new pressure. This cycle goes on
> until the pressure converges to a certain value.
This is a crude iterative method for solving a coupled problem. I
recommend that you solve the coupled problem. See the section of the
user's manual on solving block problems, and the examples in PETSc that
solve Stokes-type problems.
Name: not available
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131121/0fed5a3d/attachment-0001.pgp>
