[petsc-users] Triangle geometry data as input to DM object to generate a mesh
    Anthony Vergottis
    a.vergottis at ucl.ac.uk
    Mon Nov 11 12:35:40 CST 2013
Thank you very much.
Best regards,
Anthony
On 11 November 2013 18:21, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Nov 11, 2013 at 11:46 AM, Anthony Vergottis <a.vergottis at ucl.ac.uk
> > wrote:
>> Dear All,
>> I would like some assistance on how a mesh is created using Triangle with
>> the DM objects. Specifically how does one input the geometry of the
>> computational domain into PETSc/DM objects to then generate a 2D triangular
>> mesh? Is there a function that can do such a thing? Currently I have hard
>> coded all mesh I/O but I would like to make things a bit cleaner if its
>> possible.
> The default 2D mesh generator in PETSc is Triangle. If you have a 1D
> boundary, you can generate the 2D mesh using
>   DMPlexGenerate(boundaryDM, NULL, PETSC_FALSE, &dm)
> or PETSC_TRUE if you want edges included. I suggest using
> DMPlexCreateFromDAG() if you have programmatically
> constructed your boundary, or DMPlexCreateFromCellList() if you get your
> boundary from a meshing tool.
>   Thanks,
>      Matt
>> Thanks in advance for any help.
>> Best regards,
>> Anthony
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131111/ac2f8065/attachment.html>
