[petsc-users] Triangle geometry data as input to DM object to generate a mesh
Mon Nov 11 12:21:47 CST 2013
On Mon, Nov 11, 2013 at 11:46 AM, Anthony Vergottis
<a.vergottis at ucl.ac.uk>wrote:
> Dear All,
> I would like some assistance on how a mesh is created using Triangle with
> the DM objects. Specifically how does one input the geometry of the
> computational domain into PETSc/DM objects to then generate a 2D triangular
> mesh? Is there a function that can do such a thing? Currently I have hard
> coded all mesh I/O but I would like to make things a bit cleaner if its
> possible.
The default 2D mesh generator in PETSc is Triangle. If you have a 1D
boundary, you can generate the 2D mesh using
  DMPlexGenerate(boundaryDM, NULL, PETSC_FALSE, &dm)
or PETSC_TRUE if you want edges included. I suggest using
DMPlexCreateFromDAG() if you have programmatically
constructed your boundary, or DMPlexCreateFromCellList() if you get your
boundary from a meshing tool.
     Matt
> Thanks in advance for any help.
> Best regards,
> Anthony
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131111/487d99fb/attachment.html>
