[petsc-users] using petsc tools to solve isolated irregular domains with finite difference
Bishesh Khanal bisheshkh at gmail.com
Mon Nov 4 10:25:45 CST 2013
On Mon, Nov 4, 2013 at 4:54 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Nov 4, 2013 at 4:49 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>> On Fri, Nov 1, 2013 at 1:30 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Fri, Nov 1, 2013 at 12:08 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>> On Thu, Oct 31, 2013 at 11:34 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Thu, Oct 31, 2013 at 5:02 PM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>> On Thu, Oct 31, 2013 at 7:43 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>> On Thu, Oct 31, 2013 at 1:25 PM, Bishesh Khanal <bisheshkh at gmail.com
>>>>>>> > wrote:
>>>>>>>> I did not call DMCreateMatrix() before when using just dmda (and it
>>>>>>>> is working). In any case, I added a call to DMCreateMatrix() now but still
>>>>>>>> there are problems. Here are the code snippets and the error I get:
>>>>>>> Then you were allowing it to be called automatically by PETSc, and
>>>>>>> it would have been this time as well.
>>>>>>>> //Setting up the section and linking it to DM:
>>>>>>>> ierr = PetscSectionCreate(PETSC_COMM_WORLD, &s);CHKERRQ(ierr);
>>>>>>>>     ierr = DMDAGetNumCells(dm, NULL, NULL, NULL, &nC);CHKERRQ(ierr);
>>>>>>>>     ierr = PetscSectionSetChart(s, 0, nC);CHKERRQ(ierr);
>>>>>>>>     for (PetscInt j = info.ys; j < info.ys+info.ym; ++j) {
>>>>>>>>         for (PetscInt i = info.xs; i < info.xs+info.xm; ++i) {
>>>>>>>>             PetscInt point;
>>>>>>>>             if(isPosInDomain(&testPoisson,i,j,0)) {
>>>>>>>>                 ierr = DMDAGetCellPoint(dm, i, j, 0,
>>>>>>>> &point);CHKERRQ(ierr);
>>>>>>>>                 ierr = PetscSectionSetDof(s, point,
>>>>>>>> testPoisson.mDof); // No. of dofs associated with the point.
>>>>>>>>     ierr = PetscSectionSetUp(s);CHKERRQ(ierr);
>>>>>>>>     ierr = DMSetDefaultSection(dm, s);CHKERRQ(ierr);
>>>>>>>>     ierr = PetscSectionDestroy(&s);CHKERRQ(ierr);
>>>>>>>>     ierr = DMCreateMatrix(dm,&A);CHKERRQ(ierr);
>>>>>>>>  //Set up KSP:
>>>>>>>>     ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>>>>>>>>     ierr = KSPSetDM(ksp,dm);CHKERRQ(ierr);
>>>>>>>>     ierr =
>>>>>>>> KSPSetComputeOperators(ksp,computeMatrix2dSection,(void*)&testPoisson);CHKERRQ(ierr);
>>>>>>>>     ierr =
>>>>>>>> KSPSetComputeRHS(ksp,computeRhs2dSection,(void*)&testPoisson);CHKERRQ(ierr);
>>>>>>>>     ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>>>>>>>>     ierr = KSPSolve(ksp,NULL,NULL);CHKERRQ(ierr);
>>>>>>>> The computeMatrix2dSection function has:
>>>>>>>> ierr = KSPGetDM(ksp,&da);CHKERRQ(ierr);
>>>>>>>>     ierr = DMDAGetLocalInfo(da,&info);CHKERRQ(ierr);
>>>>>>>>     ierr = DMGetDefaultGlobalSection(da,&gs);CHKERRQ(ierr);
>>>>>>>>     for(PetscInt j = info.ys; j<info.ys+info.ym; ++j) {
>>>>>>>>         for(PetscInt i = info.xs; i<info.xs+info.xm; ++i) {
>>>>>>>>             if (isPosInDomain(ctx,i,j)) {
>>>>>>>>                 ierr =
>>>>>>>> DMDAGetCellPoint(da,i,j,0,&point);CHKERRQ(ierr);
>>>>>>>>                 ierr = PetscSectionGetOffset(gs,point,&row);
>>>>>>>>                 ierr = PetscSectionGetDof(gs,point,&dof);
>>>>>>>>                 for(PetscInt cDof = 0; cDof < dof; ++cDof) {
>>>>>>>>                     num = 0;
>>>>>>>>                     row+=cDof;
>>>>>>>>                     col[num] = row;         //(i,j) position
>>>>>>>>                     v[num++] = -4;
>>>>>>>>                     if(isPosInDomain(ctx,i+1,j)) {
>>>>>>>>                         ierr =
>>>>>>>> DMDAGetCellPoint(da,i+1,j,0,&point);CHKERRQ(ierr);
>>>>>>>>                         ierr =
>>>>>>>> PetscSectionGetOffset(gs,point,&col[num]);
>>>>>>>>                         col[num] += cDof;
>>>>>>>>                         v[num++] = 1;
>>>>>>>>                     if(isPosInDomain(ctx,i-1,j)) {
>>>>>>>>                         ierr =
>>>>>>>> DMDAGetCellPoint(da,i-1,j,0,&point);CHKERRQ(ierr);
>>>>>>>>                         ierr =
>>>>>>>>                         col[num] += cDof;
>>>>>>>>                         v[num++] = 1;
>>>>>>>>                     if(isPosInDomain(ctx,i,j+1)) {
>>>>>>>>                         ierr =
>>>>>>>> DMDAGetCellPoint(da,i,j+1,0,&point);CHKERRQ(ierr);
>>>>>>>>                         ierr =
>>>>>>>>                         col[num] += cDof;
>>>>>>>>                         v[num++] = 1;
>>>>>>>>                     if(isPosInDomain(ctx,i,j-1)) {
>>>>>>>>                         ierr =
>>>>>>>> DMDAGetCellPoint(da,i,j-1,0,&point);CHKERRQ(ierr);
>>>>>>>>                         ierr =
>>>>>>>>                         col[num] += cDof;
>>>>>>>>                         v[num++] = 1;
>>>>>>>>                     ierr =
>>>>>>>> MatSetValues(A,1,&row,num,col,v,INSERT_VALUES);CHKERRQ(ierr);
>>>>>>>>     ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>>>>>>     ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>>>>>> But this is not working. For e.g. for a 6X6 grid size I get the
>>>>>>>> following error:
>>>>>>> Okay, here is how to debug this:
>>>>>>>   0) Go to a single scalar equations to make things easier
>>>>>>>   1) Use MatView(A, PETSC_VIEWER_STDOUT_WORLD), which should output
>>>>>>> a 36 row matrix with
>>>>>>>        the preallocated nonzero pattern, filled with zeros
>>>>>>>   2) Make sure this is the pattern you want
>>>>>>>   3) Run in the debugger with -start_in_debugger
>>>>>>>   4) When you get the error, see
>>>>>>>     a) If the (i, j) is one that should be setting a value
>>>>>>>     b) Why this (i, j) was not preallocated
>>>>>> Up to 4 (a), it is correct. There is a problem in the way
>>>>>> DMDAGetCellPoint and PetscSectionGetOffset works in this case scenario. I
>>>>>> will try to explain it below for the case of 4X4 grid.
>>>>>> First case:
>>>>>> If I set the computational domain to be all the points of the dmda
>>>>>> grid, (i.e. isPosInDomain(..,i,j,..) returns true for all i and j in the
>>>>>> dmda grid), the program runs fine and does not give any error.
>>>>>> Second case:
>>>>>> I want the computational domain to be some part of the whole grid.
>>>>>> There is a problem in this case.
>>>>>> The following test is in a case where,
>>>>>> isPosInDomain(..,i,j,..) returns true ONLY for (i,j) pairs of (2,1)
>>>>>> (1,2) (2,2) (3,2) and (3,2). The grid with its corresponding point number
>>>>>> in the petscsection is shown below:
>>>>>> 12  13  14  15
>>>>>> 8    9     10  11
>>>>>> 4    5     6    7
>>>>>> 0    1     2    3
>>>>>> of which 6, 9, 10, 11 and 14 correspond to the (i,j) points that
>>>>>> returns true for isPosInDomain(..,i,j,..)
>>>>>> MatView gives me the 16-row matrix with the star stencil non-zero
>>>>>> structure as expected.
>>>>>> The error I get is: new non-zero at (0,2) caused a malloc.
>>>>>> This error is for the value of (i,j) = (2,1), i.e. point 6.
>>>>>> The loop to set values in the matrix starts as:
>>>>>>                 ierr =
>>>>>> Now, what I wanted from the beginning is to create the matrix
>>>>>> containing the rows corresponding to only those points (i,j) which has true
>>>>>> values for isPosInDomain(ctx,i,j), that means in this case 5 row matrix. In
>>>>>> the current test, the first (i,j) that reaches DMDAGetCellPoint is (2,1),
>>>>>> which gives sets point variable to 6.
>>>>>> The line PetscSectionGetOffset(gs,point,&row) sets the value of row
>>>>>> to 0.
>>>>>> So I think this where the inconsistency lies.
>>>>>> MatSetValues(A,1,&row,num,col,v,INSERT_VALUES) expects row variable
>>>>>> and col[] array to correspond to (i,j) based on DMDA, but
>>>>>> PetsSectionGetOffset gives result based on how we masked away some of the
>>>>>> points from dmda grid. Or am I missing something very basic here ?
>>>>> You are missing something basic. The row is correctly identified as 0,
>>>>> and that means the 2 is
>>>>> point 10.
>>>> The problem must be preallocation. First, you should send the result of
>>>>> MatView().
>>>> MatView shows that the preallocation and the matrix created is for the
>>>> full dmda grid which is probably not what we want here, right ? Here is the
>>>> matview result:
>>> Thats right. Did you call
>>>   DMSetDefaultSection(da, s)
>>> after you made the new section and before you called DMGetMatrix()?
>> Do you mean before I called DMCreateMatrix() ? I called
>> DMSetDefaultSection(da,s) as below:
>> //    ierr = DMGetMatrix(dm,&A);CHKERRQ(ierr);  //It seems DMGetMatrix is
>> changed to DMCreateMatrix().
>>     ierr = MatView(A,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
> Yes, this is correct. I do exactly this in the example code and it works
> fine. I suspect
> you are not creating the section you think you are. You can send the code
> if you want
> and I will look at it.
Thanks, here is the code:
https://github.com/bishesh/petscPoissonIrregular/blob/master/poissonIrregular.cxx
It works for 2D and 3D without using PetscSection. (The choice of using
Petsc_section is on line 68). Using PetsSection currently it implements
only the 2D case with dof = 1. It works when the domain consists of all the
cells of the dmda, it works (to check you can uncomment line 129 in
isPosInDomain(). But it does not when I mask out some of the cells while
creating the petscsection.
>    Matt
>> This MatView on A shows (result below) that it still has 16 rows for all
>> DMDA points instead of only those petscsection points for which I set a
>> non-zero dof. Is it what it should not be doing ?
>>>  Mat Object: 1 MPI processes
>>>> type: seqaij
>>>> row 0: (0, 0) (1, 0) (4, 0)
>>>> row 1: (0, 0) (1, 0) (2, 0) (5, 0)
>>>> row 2: (1, 0) (2, 0) (3, 0) (6, 0)
>>>> row 3: (2, 0) (3, 0) (7, 0)
>>>> row 4: (0, 0) (4, 0) (5, 0) (8, 0)
>>>> row 5: (1, 0) (4, 0) (5, 0) (6, 0) (9, 0)
>>>> row 6: (2, 0) (5, 0) (6, 0) (7, 0) (10, 0)
>>>> row 7: (3, 0) (6, 0) (7, 0) (11, 0)
>>>> row 8: (4, 0) (8, 0) (9, 0) (12, 0)
>>>> row 9: (5, 0) (8, 0) (9, 0) (10, 0) (13, 0)
>>>> row 10: (6, 0) (9, 0) (10, 0) (11, 0) (14, 0)
>>>> row 11: (7, 0) (10, 0) (11, 0) (15, 0)
>>>> row 12: (8, 0) (12, 0) (13, 0)
>>>> row 13: (9, 0) (12, 0) (13, 0) (14, 0)
>>>> row 14: (10, 0) (13, 0) (14, 0) (15, 0)
>>>> row 15: (11, 0) (14, 0) (15, 0)
>>>> [0]PETSC ERROR: --------------------- Error Message
>>>> [0]PETSC ERROR: Argument out of range!
>>>> [0]PETSC ERROR: New nonzero at (0,2) caused a malloc!
>> For reference here is the code snippet again:
>>             PetscInt point;
>>                 ierr = PetscSectionSetDof(s, point, testPoisson.mDof); //
>>  ierr =
>>  ierr =
>> The function computeMatrix2dSection:
>> #undef __FUNCT__
>> #define __FUNCT__ "computeMatrix2dSection"
>> PetscErrorCode computeMatrix2dSection(KSP ksp, Mat A, Mat B, MatStructure
>> *str, void *context) {
>>     PoissonModel            *ctx = (PoissonModel*)context;
>>     PetscErrorCode          ierr;
>>     DM                      da;
>>     DMDALocalInfo           info;
>>     PetscInt                row, col[5];
>>     PetscInt                dof;
>>     PetscScalar             v[5]; //array to store 5 point stencil for
>> each row
>>     PetscInt                num; //non-zero position in the current row
>>     //    PetscScalar             dScale = 1;     //to scale Dirichlet
>> identity rows if needed
>>     PetscSection            gs;             //Global Section that keeps
>> the grid info and indices
>>     PetscInt                point;          //Current point of the
>> petscSection
>>     PetscFunctionBeginUser;
>>     ierr = DMCreateMatrix(da,&A);CHKERRQ(ierr);
>> //    ierr = MatView(A,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>>                 ierr = DMDAGetCellPoint(da,i,j,0,&point);CHKERRQ(ierr);
>>                 for(PetscInt cDof = 0; cDof < ctx->mDof; ++cDof) {
>>                     num = 0;
>>                     row+=cDof;
>>                     v[num++] = -4;
>>                         ierr =
>>                         ierr = PetscSectionGetOffset(gs,point,&col[num]);
>>                         col[num] += cDof;
>>                         v[num++] = 1;
>>                         ierr =
>>                         col[num] += cDof;
>>                         v[num++] = 1;
>>                         ierr =
>>                         col[num] += cDof;
>>                         v[num++] = 1;
>>                         ierr =
>>                         col[num] += cDof;
>>                         v[num++] = 1;
>>                     ierr =
>>>>>    Matt
>>>>>>>   Thanks,
>>>>>>>      Matt
>>>>>>>> [0]PETSC ERROR: New nonzero at (0,6) caused a malloc!
>>>>>>>> [0]PETSC ERROR:
>>>>>>>> [0]PETSC ERROR: Petsc Development GIT revision:
>>>>>>>> 61e5e40bb2c5bf2423e94b71a15fef47e411b0da  GIT Date: 2013-10-25 21:47:45
>>>>>>>> -0500
>>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>> [0]PETSC ERROR:
>>>>>>>> [0]PETSC ERROR: build/poissonIrregular on a arch-linux2-cxx-debug
>>>>>>>> named edwards by bkhanal Thu Oct 31 19:23:58 2013
>>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>>> /home/bkhanal/Documents/softwares/petsc/arch-linux2-cxx-debug/lib
>>>>>>>> [0]PETSC ERROR: Configure run at Sat Oct 26 16:35:15 2013
>>>>>>>> [0]PETSC ERROR: Configure options --download-mpich
>>>>>>>> -download-f-blas-lapack=1 --download-metis --download-parmetis
>>>>>>>> --download-superlu_dist --download-scalapack --download-mumps
>>>>>>>> --download-hypre --with-clanguage=cxx
>>>>>>>> [0]PETSC ERROR:
>>>>>>>> [0]PETSC ERROR: MatSetValues_SeqAIJ() line 413 in
>>>>>>>> src/mat/impls/aij/seq/aij.c
>>>>>>>> [0]PETSC ERROR: MatSetValues() line 1130 in
>>>>>>>> src/mat/interface/matrix.c
>>>>>>>> [0]PETSC ERROR: computeMatrix2dSection() line 318 in
>>>>>>>> /user/bkhanal/home/works/poissonIrregular/poissonIrregular.cxx
>>>>>>>> [0]PETSC ERROR: KSPSetUp() line 228 in
>>>>>>>> src/ksp/ksp/interface/itfunc.c
>>>>>>>> [0]PETSC ERROR: KSPSolve() line 399 in
>>>>>>>> [0]PETSC ERROR: main() line 598 in
>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 63) - process 0
>>>>>>>> [unset]: aborting job:
>>>>>>>>>    Matt
>>>>>>>>>> However, now since I do not want the rows in the matrix
>>>>>>>>>> corresponding to the points in the grid which do not lie in the
>>>>>>>>>> computational domain. This means the size of the matrix will not
>>>>>>>>>> necessarily equal the total number of cells in DMDA. So in the following
>>>>>>>>>> code:
>>>>>>>>>>  ierr = DMDAGetLocalInfo(dm,&info);CHKERRQ(ierr);
>>>>>>>>>> &nC);CHKERRQ(ierr);
>>>>>>>>>>             PetscInt point;
>>>>>>>>>> should I myself compute proper nC (i.e. total no. of points for
>>>>>>>>>> which I want the matrix to have a corresponding row) before calling
>>>>>>>>>> PetscSectionSetChart() or is the masking out of the points inside the loop
>>>>>>>>>> with if(isPosInDomain(&testPoisson,i,j,0)) sufficient ?
>>>>>>>>>> And, when you write:
>>>>>>>>>> PetscSectionGetOffset(gs, p, &ind);
>>>>>>>>>>   row = ind < 0 ? -(ind+1) : ind;
>>>>>>>>>> it seems you allow the possibility of getting a -ve ind when
>>>>>>>>>> using PetscSectionGetOffset. When would an offset to a particular dof and
>>>>>>>>>> point?
>>>>>>>>>>>>                 num = 0;
>>>>>>>>>>>>                 /*ierr =
>>>>>>>>>>>> DMDAGetCellPoint(da,i,j,0,&point);CHKERRQ(ierr);*/ /*Get the PetscPoint*/
>>>>>>>>>>>>                 /*But I did now understand how I would emulate
>>>>>>>>>>>> the row.c and col.c info with PetscSection*/
>>>>>>>>>>>>                 row.i = i;  row.j = j;
>>>>>>>>>>> Here you would call
>>>>>>>>>>>    ierr = DMDAGetCellPoint(da, i, j, 0, &cell);CHKERRQ(ierr);
>>>>>>>>>>>    ierr = PetscSectionGetOffset(da, cell, &row);CHKERRQ(ierr);
>>>>>>>>>>>    ierr = PetscSectionGetDof(da, cell, &dof);CHKERRQ(ierr);
>>>>>>>>>>> This means that this cell has global rows = [row, row+dof).
>>>>>>>>>>>>                  col[num].i = i; col[num].j = j;
>>>>>>>>>>>>                 if (isPosInDomain(ctx,i,j)) {      /*put the
>>>>>>>>>>>> operator for only the values for only the points lying in the domain*/
>>>>>>>>>>>>                     v[num++] = -4;
>>>>>>>>>>>>                         col[num].i = i+1;   col[num].j = j;
>>>>>>>>>>>>                         v[num++] = 1;
>>>>>>>>>>>>                         col[num].i = i-1;   col[num].j = j;
>>>>>>>>>>>>                         v[num++] = 1;
>>>>>>>>>>>>                         col[num].i = i;     col[num].j = j+1;
>>>>>>>>>>>>                         v[num++] = 1;
>>>>>>>>>>>>                         col[num].i = i;     col[num].j = j-1;
>>>>>>>>>>>>                         v[num++] = 1;
>>>>>>>>>>>>                 } else {
>>>>>>>>>>>>                     v[num++] = dScale;  /*set Dirichlet
>>>>>>>>>>>> identity rows for points in the rectangle but outside the computational
>>>>>>>>>>>> domain*/
>>>>>>>>>>> You do the same thing for the columns, and then call
>>>>>>>>>>>   ierr = MatSetValues(A, dof, rows, num*dof, cols, v,
>>>>>>>>>>>>                 ierr =
>>>>>>>>>>>> MatSetValuesStencil(A,1,&row,num,col,v,INSERT_VALUES);CHKERRQ(ierr);
>>>>>>>>>>>>>     Thanks,
>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>>>>>>>>  If not, just put the identity into
>>>>>>>>>>>>>>>>>>>>>>> the rows you do not use on the full cube. It will
>>>>>>>>>>>>>>>>>>>>>>> not hurt scalability or convergence.
>>>>>>>>>>>>>>>>>>>>>> In the case of Poisson with Dirichlet condition this
>>>>>>>>>>>>>>>>>>>>>> might be the case. But is it always true that having identity rows in the
>>>>>>>>>>>>>>>>>>>>>> system matrix will not hurt convergence ? I thought otherwise for the
>>>>>>>>>>>>>>>>>>>>>> following reasons:
>>>>>>>>>>>>>>>>>>>>>> 1)  Having read Jed's answer here :
>>>>>>>>>>>>>>>>>>>>>> http://scicomp.stackexchange.com/questions/3426/why-is-pinning-a-point-to-remove-a-null-space-bad/3427#3427
>>>>>>>>>>>>>>>>>>>>> Jed is talking about a constraint on a the pressure at
>>>>>>>>>>>>>>>>>>>>> a point. This is just decoupling these unknowns from the rest
>>>>>>>>>>>>>>>>>>>>> of the problem.
>>>>>>>>>>>>>>>>>>>>>> 2) Some observation I am getting (but I am still
>>>>>>>>>>>>>>>>>>>>>> doing more experiments to confirm) while solving my staggered-grid 3D
>>>>>>>>>>>>>>>>>>>>>> stokes flow with schur complement and using -pc_type gamg for A00 matrix.
>>>>>>>>>>>>>>>>>>>>>> Putting the identity rows for dirichlet boundaries and for ghost cells
>>>>>>>>>>>>>>>>>>>>>> seemed to have effects on its convergence. I'm hoping once I know how to
>>>>>>>>>>>>>>>>>>>>>> use PetscSection, I can get rid of using ghost cells method for the
>>>>>>>>>>>>>>>>>>>>>> staggered grid and get rid of the identity rows too.
>>>>>>>>>>>>>>>>>>>>> It can change the exact iteration, but it does not
>>>>>>>>>>>>>>>>>>>>> make the matrix conditioning worse.
>>>>>>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>>>>>>  Anyway please provide me with some pointers so that
>>>>>>>>>>>>>>>>>>>>>> I can start trying with petscsection on top of a dmda, in the beginning for
>>>>>>>>>>>>>>>>>>>>>> non-staggered case.
>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>> Bishesh
>>>>>>>>>>>>>>>>>>>>>>>   Matt
>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>> Bishesh
>>>>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before they
>>>>>>>>>>>>>>>>>>>>>>> begin their experiments is infinitely more interesting than any results to
>>>>>>>>>>>>>>>>>>>>>>> which their experiments lead.
>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131104/d5a4bbd3/attachment-0001.html>
