[petsc-users] using petsc tools to solve isolated irregular domains with finite difference
Matthew Knepley
knepley at gmail.com
Mon Nov 4 09:54:23 CST 2013
On Mon, Nov 4, 2013 at 4:49 AM, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> On Fri, Nov 1, 2013 at 1:30 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Nov 1, 2013 at 12:08 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>> On Thu, Oct 31, 2013 at 11:34 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Thu, Oct 31, 2013 at 5:02 PM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>> On Thu, Oct 31, 2013 at 7:43 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Thu, Oct 31, 2013 at 1:25 PM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>>> I did not call DMCreateMatrix() before when using just dmda (and it
>>>>>>> is working). In any case, I added a call to DMCreateMatrix() now but still
>>>>>>> there are problems. Here are the code snippets and the error I get:
>>>>>> Then you were allowing it to be called automatically by PETSc, and it
>>>>>> would have been this time as well.
>>>>>>> //Setting up the section and linking it to DM:
>>>>>>> ierr = PetscSectionCreate(PETSC_COMM_WORLD, &s);CHKERRQ(ierr);
>>>>>>> ierr = DMDAGetNumCells(dm, NULL, NULL, NULL, &nC);CHKERRQ(ierr);
>>>>>>> ierr = PetscSectionSetChart(s, 0, nC);CHKERRQ(ierr);
>>>>>>> for (PetscInt j = info.ys; j < info.ys+info.ym; ++j) {
>>>>>>> for (PetscInt i = info.xs; i < info.xs+info.xm; ++i) {
>>>>>>> PetscInt point;
>>>>>>> if(isPosInDomain(&testPoisson,i,j,0)) {
>>>>>>> ierr = DMDAGetCellPoint(dm, i, j, 0,
>>>>>>> &point);CHKERRQ(ierr);
>>>>>>> ierr = PetscSectionSetDof(s, point,
>>>>>>> testPoisson.mDof); // No. of dofs associated with the point.
>>>>>>> ierr = PetscSectionSetUp(s);CHKERRQ(ierr);
>>>>>>> ierr = DMSetDefaultSection(dm, s);CHKERRQ(ierr);
>>>>>>> ierr = PetscSectionDestroy(&s);CHKERRQ(ierr);
>>>>>>> ierr = DMCreateMatrix(dm,&A);CHKERRQ(ierr);
>>>>>>> //Set up KSP:
>>>>>>> ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>>>>>>> ierr = KSPSetDM(ksp,dm);CHKERRQ(ierr);
>>>>>>> ierr =
>>>>>>> KSPSetComputeOperators(ksp,computeMatrix2dSection,(void*)&testPoisson);CHKERRQ(ierr);
>>>>>>> ierr =
>>>>>>> KSPSetComputeRHS(ksp,computeRhs2dSection,(void*)&testPoisson);CHKERRQ(ierr);
>>>>>>> ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>>>>>>> ierr = KSPSolve(ksp,NULL,NULL);CHKERRQ(ierr);
>>>>>>> The computeMatrix2dSection function has:
>>>>>>> ierr = KSPGetDM(ksp,&da);CHKERRQ(ierr);
>>>>>>> ierr = DMDAGetLocalInfo(da,&info);CHKERRQ(ierr);
>>>>>>> ierr = DMGetDefaultGlobalSection(da,&gs);CHKERRQ(ierr);
>>>>>>> for(PetscInt j = info.ys; j<info.ys+info.ym; ++j) {
>>>>>>> for(PetscInt i = info.xs; i<info.xs+info.xm; ++i) {
>>>>>>> if (isPosInDomain(ctx,i,j)) {
>>>>>>> ierr =
>>>>>>> DMDAGetCellPoint(da,i,j,0,&point);CHKERRQ(ierr);
>>>>>>> ierr = PetscSectionGetOffset(gs,point,&row);
>>>>>>> ierr = PetscSectionGetDof(gs,point,&dof);
>>>>>>> for(PetscInt cDof = 0; cDof < dof; ++cDof) {
>>>>>>> num = 0;
>>>>>>> row+=cDof;
>>>>>>> col[num] = row; //(i,j) position
>>>>>>> v[num++] = -4;
>>>>>>> if(isPosInDomain(ctx,i+1,j)) {
>>>>>>> ierr =
>>>>>>> DMDAGetCellPoint(da,i+1,j,0,&point);CHKERRQ(ierr);
>>>>>>> ierr =
>>>>>>> PetscSectionGetOffset(gs,point,&col[num]);
>>>>>>> col[num] += cDof;
>>>>>>> v[num++] = 1;
>>>>>>> if(isPosInDomain(ctx,i-1,j)) {
>>>>>>> ierr =
>>>>>>> DMDAGetCellPoint(da,i-1,j,0,&point);CHKERRQ(ierr);
>>>>>>> ierr =
>>>>>>> col[num] += cDof;
>>>>>>> v[num++] = 1;
>>>>>>> if(isPosInDomain(ctx,i,j+1)) {
>>>>>>> ierr =
>>>>>>> DMDAGetCellPoint(da,i,j+1,0,&point);CHKERRQ(ierr);
>>>>>>> ierr =
>>>>>>> col[num] += cDof;
>>>>>>> v[num++] = 1;
>>>>>>> if(isPosInDomain(ctx,i,j-1)) {
>>>>>>> ierr =
>>>>>>> DMDAGetCellPoint(da,i,j-1,0,&point);CHKERRQ(ierr);
>>>>>>> ierr =
>>>>>>> col[num] += cDof;
>>>>>>> v[num++] = 1;
>>>>>>> ierr =
>>>>>>> MatSetValues(A,1,&row,num,col,v,INSERT_VALUES);CHKERRQ(ierr);
>>>>>>> ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>>>>> ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>>>>> But this is not working. For e.g. for a 6X6 grid size I get the
>>>>>>> following error:
>>>>>> Okay, here is how to debug this:
>>>>>> 0) Go to a single scalar equations to make things easier
>>>>>> 1) Use MatView(A, PETSC_VIEWER_STDOUT_WORLD), which should output a
>>>>>> 36 row matrix with
>>>>>> the preallocated nonzero pattern, filled with zeros
>>>>>> 2) Make sure this is the pattern you want
>>>>>> 3) Run in the debugger with -start_in_debugger
>>>>>> 4) When you get the error, see
>>>>>> a) If the (i, j) is one that should be setting a value
>>>>>> b) Why this (i, j) was not preallocated
>>>>> Up to 4 (a), it is correct. There is a problem in the way
>>>>> DMDAGetCellPoint and PetscSectionGetOffset works in this case scenario. I
>>>>> will try to explain it below for the case of 4X4 grid.
>>>>> First case:
>>>>> If I set the computational domain to be all the points of the dmda
>>>>> grid, (i.e. isPosInDomain(..,i,j,..) returns true for all i and j in the
>>>>> dmda grid), the program runs fine and does not give any error.
>>>>> Second case:
>>>>> I want the computational domain to be some part of the whole grid.
>>>>> There is a problem in this case.
>>>>> The following test is in a case where,
>>>>> isPosInDomain(..,i,j,..) returns true ONLY for (i,j) pairs of (2,1)
>>>>> (1,2) (2,2) (3,2) and (3,2). The grid with its corresponding point number
>>>>> in the petscsection is shown below:
>>>>> 12 13 14 15
>>>>> 8 9 10 11
>>>>> 4 5 6 7
>>>>> 0 1 2 3
>>>>> of which 6, 9, 10, 11 and 14 correspond to the (i,j) points that
>>>>> returns true for isPosInDomain(..,i,j,..)
>>>>> MatView gives me the 16-row matrix with the star stencil non-zero
>>>>> structure as expected.
>>>>> The error I get is: new non-zero at (0,2) caused a malloc.
>>>>> This error is for the value of (i,j) = (2,1), i.e. point 6.
>>>>> The loop to set values in the matrix starts as:
>>>>> ierr = DMDAGetCellPoint(da,i,j,0,&point);CHKERRQ(ierr);
>>>>> Now, what I wanted from the beginning is to create the matrix
>>>>> containing the rows corresponding to only those points (i,j) which has true
>>>>> values for isPosInDomain(ctx,i,j), that means in this case 5 row matrix. In
>>>>> the current test, the first (i,j) that reaches DMDAGetCellPoint is (2,1),
>>>>> which gives sets point variable to 6.
>>>>> The line PetscSectionGetOffset(gs,point,&row) sets the value of row to
>>>>> 0.
>>>>> So I think this where the inconsistency lies.
>>>>> MatSetValues(A,1,&row,num,col,v,INSERT_VALUES) expects row variable
>>>>> and col[] array to correspond to (i,j) based on DMDA, but
>>>>> PetsSectionGetOffset gives result based on how we masked away some of the
>>>>> points from dmda grid. Or am I missing something very basic here ?
>>>> You are missing something basic. The row is correctly identified as 0,
>>>> and that means the 2 is
>>>> point 10.
>>> The problem must be preallocation. First, you should send the result of
>>>> MatView().
>>> MatView shows that the preallocation and the matrix created is for the
>>> full dmda grid which is probably not what we want here, right ? Here is the
>>> matview result:
>> Thats right. Did you call
>> DMSetDefaultSection(da, s)
>> after you made the new section and before you called DMGetMatrix()?
> Do you mean before I called DMCreateMatrix() ? I called
> DMSetDefaultSection(da,s) as below:
> // ierr = DMGetMatrix(dm,&A);CHKERRQ(ierr); //It seems DMGetMatrix is
> changed to DMCreateMatrix().
> ierr = MatView(A,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
Yes, this is correct. I do exactly this in the example code and it works
fine. I suspect
you are not creating the section you think you are. You can send the code
if you want
and I will look at it.
Matt
> This MatView on A shows (result below) that it still has 16 rows for all
> DMDA points instead of only those petscsection points for which I set a
> non-zero dof. Is it what it should not be doing ?
>> Mat Object: 1 MPI processes
>>> type: seqaij
>>> row 0: (0, 0) (1, 0) (4, 0)
>>> row 1: (0, 0) (1, 0) (2, 0) (5, 0)
>>> row 2: (1, 0) (2, 0) (3, 0) (6, 0)
>>> row 3: (2, 0) (3, 0) (7, 0)
>>> row 4: (0, 0) (4, 0) (5, 0) (8, 0)
>>> row 5: (1, 0) (4, 0) (5, 0) (6, 0) (9, 0)
>>> row 6: (2, 0) (5, 0) (6, 0) (7, 0) (10, 0)
>>> row 7: (3, 0) (6, 0) (7, 0) (11, 0)
>>> row 8: (4, 0) (8, 0) (9, 0) (12, 0)
>>> row 9: (5, 0) (8, 0) (9, 0) (10, 0) (13, 0)
>>> row 10: (6, 0) (9, 0) (10, 0) (11, 0) (14, 0)
>>> row 11: (7, 0) (10, 0) (11, 0) (15, 0)
>>> row 12: (8, 0) (12, 0) (13, 0)
>>> row 13: (9, 0) (12, 0) (13, 0) (14, 0)
>>> row 14: (10, 0) (13, 0) (14, 0) (15, 0)
>>> row 15: (11, 0) (14, 0) (15, 0)
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Argument out of range!
>>> [0]PETSC ERROR: New nonzero at (0,2) caused a malloc!
> For reference here is the code snippet again:
> PetscInt point;
> ierr = DMDAGetCellPoint(dm, i, j, 0, &point);CHKERRQ(ierr);
> ierr = PetscSectionSetDof(s, point, testPoisson.mDof); //
> ierr =
> ierr =
> The function computeMatrix2dSection:
> #undef __FUNCT__
> #define __FUNCT__ "computeMatrix2dSection"
> PetscErrorCode computeMatrix2dSection(KSP ksp, Mat A, Mat B, MatStructure
> *str, void *context) {
> PoissonModel *ctx = (PoissonModel*)context;
> PetscErrorCode ierr;
> DM da;
> DMDALocalInfo info;
> PetscInt row, col[5];
> PetscInt dof;
> PetscScalar v[5]; //array to store 5 point stencil for
> each row
> PetscInt num; //non-zero position in the current row
> // PetscScalar dScale = 1; //to scale Dirichlet
> identity rows if needed
> PetscSection gs; //Global Section that keeps
> the grid info and indices
> PetscInt point; //Current point of the
> petscSection
> PetscFunctionBeginUser;
> ierr = DMCreateMatrix(da,&A);CHKERRQ(ierr);
> // ierr = MatView(A,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
> for(PetscInt cDof = 0; cDof < ctx->mDof; ++cDof) {
> num = 0;
> row+=cDof;
> v[num++] = -4;
> ierr =
> ierr = PetscSectionGetOffset(gs,point,&col[num]);
> col[num] += cDof;
> v[num++] = 1;
> ierr =
> col[num] += cDof;
> v[num++] = 1;
> ierr =
> col[num] += cDof;
> v[num++] = 1;
> ierr =
> col[num] += cDof;
> v[num++] = 1;
> ierr =
>>>> Matt
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> [0]PETSC ERROR: New nonzero at (0,6) caused a malloc!
>>>>>>> [0]PETSC ERROR:
>>>>>>> [0]PETSC ERROR: Petsc Development GIT revision:
>>>>>>> 61e5e40bb2c5bf2423e94b71a15fef47e411b0da GIT Date: 2013-10-25 21:47:45
>>>>>>> -0500
>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>> [0]PETSC ERROR:
>>>>>>> [0]PETSC ERROR: build/poissonIrregular on a arch-linux2-cxx-debug
>>>>>>> named edwards by bkhanal Thu Oct 31 19:23:58 2013
>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>> /home/bkhanal/Documents/softwares/petsc/arch-linux2-cxx-debug/lib
>>>>>>> [0]PETSC ERROR: Configure run at Sat Oct 26 16:35:15 2013
>>>>>>> [0]PETSC ERROR: Configure options --download-mpich
>>>>>>> -download-f-blas-lapack=1 --download-metis --download-parmetis
>>>>>>> --download-superlu_dist --download-scalapack --download-mumps
>>>>>>> --download-hypre --with-clanguage=cxx
>>>>>>> [0]PETSC ERROR:
>>>>>>> [0]PETSC ERROR: MatSetValues_SeqAIJ() line 413 in
>>>>>>> src/mat/impls/aij/seq/aij.c
>>>>>>> [0]PETSC ERROR: MatSetValues() line 1130 in
>>>>>>> src/mat/interface/matrix.c
>>>>>>> [0]PETSC ERROR: computeMatrix2dSection() line 318 in
>>>>>>> /user/bkhanal/home/works/poissonIrregular/poissonIrregular.cxx
>>>>>>> [0]PETSC ERROR: KSPSetUp() line 228 in src/ksp/ksp/interface/itfunc.c
>>>>>>> [0]PETSC ERROR: KSPSolve() line 399 in src/ksp/ksp/interface/itfunc.c
>>>>>>> [0]PETSC ERROR: main() line 598 in
>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 63) - process 0
>>>>>>> [unset]: aborting job:
>>>>>>>> Matt
>>>>>>>>> However, now since I do not want the rows in the matrix
>>>>>>>>> corresponding to the points in the grid which do not lie in the
>>>>>>>>> computational domain. This means the size of the matrix will not
>>>>>>>>> necessarily equal the total number of cells in DMDA. So in the following
>>>>>>>>> code:
>>>>>>>>> ierr = DMDAGetLocalInfo(dm,&info);CHKERRQ(ierr);
>>>>>>>>> &nC);CHKERRQ(ierr);
>>>>>>>>> PetscInt point;
>>>>>>>>> should I myself compute proper nC (i.e. total no. of points for
>>>>>>>>> which I want the matrix to have a corresponding row) before calling
>>>>>>>>> PetscSectionSetChart() or is the masking out of the points inside the loop
>>>>>>>>> with if(isPosInDomain(&testPoisson,i,j,0)) sufficient ?
>>>>>>>>> And, when you write:
>>>>>>>>> PetscSectionGetOffset(gs, p, &ind);
>>>>>>>>> row = ind < 0 ? -(ind+1) : ind;
>>>>>>>>> it seems you allow the possibility of getting a -ve ind when using
>>>>>>>>> PetscSectionGetOffset. When would an offset to a particular dof and point?
>>>>>>>>>>> num = 0;
>>>>>>>>>>> /*ierr =
>>>>>>>>>>> DMDAGetCellPoint(da,i,j,0,&point);CHKERRQ(ierr);*/ /*Get the PetscPoint*/
>>>>>>>>>>> /*But I did now understand how I would emulate
>>>>>>>>>>> the row.c and col.c info with PetscSection*/
>>>>>>>>>>> row.i = i; row.j = j;
>>>>>>>>>> Here you would call
>>>>>>>>>> ierr = DMDAGetCellPoint(da, i, j, 0, &cell);CHKERRQ(ierr);
>>>>>>>>>> ierr = PetscSectionGetOffset(da, cell, &row);CHKERRQ(ierr);
>>>>>>>>>> ierr = PetscSectionGetDof(da, cell, &dof);CHKERRQ(ierr);
>>>>>>>>>> This means that this cell has global rows = [row, row+dof).
>>>>>>>>>>> col[num].i = i; col[num].j = j;
>>>>>>>>>>> if (isPosInDomain(ctx,i,j)) { /*put the
>>>>>>>>>>> operator for only the values for only the points lying in the domain*/
>>>>>>>>>>> v[num++] = -4;
>>>>>>>>>>> col[num].i = i+1; col[num].j = j;
>>>>>>>>>>> v[num++] = 1;
>>>>>>>>>>> col[num].i = i-1; col[num].j = j;
>>>>>>>>>>> v[num++] = 1;
>>>>>>>>>>> col[num].i = i; col[num].j = j+1;
>>>>>>>>>>> v[num++] = 1;
>>>>>>>>>>> col[num].i = i; col[num].j = j-1;
>>>>>>>>>>> v[num++] = 1;
>>>>>>>>>>> } else {
>>>>>>>>>>> v[num++] = dScale; /*set Dirichlet identity
>>>>>>>>>>> rows for points in the rectangle but outside the computational domain*/
>>>>>>>>>> You do the same thing for the columns, and then call
>>>>>>>>>> ierr = MatSetValues(A, dof, rows, num*dof, cols, v,
>>>>>>>>>>> ierr =
>>>>>>>>>>> MatSetValuesStencil(A,1,&row,num,col,v,INSERT_VALUES);CHKERRQ(ierr);
>>>>>>>>>>>> Thanks,
>>>>>>>>>>>> Matt
>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>>> If not, just put the identity into
>>>>>>>>>>>>>>>>>>>>>> the rows you do not use on the full cube. It will not
>>>>>>>>>>>>>>>>>>>>>> hurt scalability or convergence.
>>>>>>>>>>>>>>>>>>>>> In the case of Poisson with Dirichlet condition this
>>>>>>>>>>>>>>>>>>>>> might be the case. But is it always true that having identity rows in the
>>>>>>>>>>>>>>>>>>>>> system matrix will not hurt convergence ? I thought otherwise for the
>>>>>>>>>>>>>>>>>>>>> following reasons:
>>>>>>>>>>>>>>>>>>>>> 1) Having read Jed's answer here :
>>>>>>>>>>>>>>>>>>>>> http://scicomp.stackexchange.com/questions/3426/why-is-pinning-a-point-to-remove-a-null-space-bad/3427#3427
>>>>>>>>>>>>>>>>>>>> Jed is talking about a constraint on a the pressure at
>>>>>>>>>>>>>>>>>>>> a point. This is just decoupling these unknowns from the rest
>>>>>>>>>>>>>>>>>>>> of the problem.
>>>>>>>>>>>>>>>>>>>>> 2) Some observation I am getting (but I am still doing
>>>>>>>>>>>>>>>>>>>>> more experiments to confirm) while solving my staggered-grid 3D stokes flow
>>>>>>>>>>>>>>>>>>>>> with schur complement and using -pc_type gamg for A00 matrix. Putting the
>>>>>>>>>>>>>>>>>>>>> identity rows for dirichlet boundaries and for ghost cells seemed to have
>>>>>>>>>>>>>>>>>>>>> effects on its convergence. I'm hoping once I know how to use PetscSection,
>>>>>>>>>>>>>>>>>>>>> I can get rid of using ghost cells method for the staggered grid and get
>>>>>>>>>>>>>>>>>>>>> rid of the identity rows too.
>>>>>>>>>>>>>>>>>>>> It can change the exact iteration, but it does not make
>>>>>>>>>>>>>>>>>>>> the matrix conditioning worse.
>>>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>>>> Anyway please provide me with some pointers so that
>>>>>>>>>>>>>>>>>>>>> I can start trying with petscsection on top of a dmda, in the beginning for
>>>>>>>>>>>>>>>>>>>>> non-staggered case.
>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>> Bishesh
>>>>>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>> Bishesh
>>>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before they
>>>>>>>>>>>>>>>>>>>>>> begin their experiments is infinitely more interesting than any results to
>>>>>>>>>>>>>>>>>>>>>> which their experiments lead.
>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131104/3102f5f9/attachment-0001.html>
