[petsc-users] using petsc tools to solve isolated irregular domains with finite difference
Bishesh Khanal
bisheshkh at gmail.com
Mon Nov 11 13:08:45 CST 2013
On Mon, Nov 4, 2013 at 5:25 PM, Bishesh Khanal <bisheshkh at gmail.com> wrote:
> On Mon, Nov 4, 2013 at 4:54 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Mon, Nov 4, 2013 at 4:49 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>> On Fri, Nov 1, 2013 at 1:30 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>> On Fri, Nov 1, 2013 at 12:08 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>> On Thu, Oct 31, 2013 at 11:34 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>> On Thu, Oct 31, 2013 at 5:02 PM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>>> On Thu, Oct 31, 2013 at 7:43 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>>>>> On Thu, Oct 31, 2013 at 1:25 PM, Bishesh Khanal <
>>>>>>>>> I did not call DMCreateMatrix() before when using just dmda (and
>>>>>>>>> it is working). In any case, I added a call to DMCreateMatrix() now but
>>>>>>>>> still there are problems. Here are the code snippets and the error I get:
>>>>>>>> Then you were allowing it to be called automatically by PETSc, and
>>>>>>>> it would have been this time as well.
>>>>>>>>> //Setting up the section and linking it to DM:
>>>>>>>>> ierr = PetscSectionCreate(PETSC_COMM_WORLD, &s);CHKERRQ(ierr);
>>>>>>>>> ierr = DMDAGetNumCells(dm, NULL, NULL, NULL,
>>>>>>>>> &nC);CHKERRQ(ierr);
>>>>>>>>> ierr = PetscSectionSetChart(s, 0, nC);CHKERRQ(ierr);
>>>>>>>>> for (PetscInt j = info.ys; j < info.ys+info.ym; ++j) {
>>>>>>>>> for (PetscInt i = info.xs; i < info.xs+info.xm; ++i) {
>>>>>>>>> PetscInt point;
>>>>>>>>> if(isPosInDomain(&testPoisson,i,j,0)) {
>>>>>>>>> ierr = DMDAGetCellPoint(dm, i, j, 0,
>>>>>>>>> &point);CHKERRQ(ierr);
>>>>>>>>> ierr = PetscSectionSetDof(s, point,
>>>>>>>>> testPoisson.mDof); // No. of dofs associated with the point.
>>>>>>>>> ierr = PetscSectionSetUp(s);CHKERRQ(ierr);
>>>>>>>>> ierr = DMSetDefaultSection(dm, s);CHKERRQ(ierr);
>>>>>>>>> ierr = PetscSectionDestroy(&s);CHKERRQ(ierr);
>>>>>>>>> ierr = DMCreateMatrix(dm,&A);CHKERRQ(ierr);
>>>>>>>>> //Set up KSP:
>>>>>>>>> ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>>>>>>>>> ierr = KSPSetDM(ksp,dm);CHKERRQ(ierr);
>>>>>>>>> ierr =
>>>>>>>>> KSPSetComputeOperators(ksp,computeMatrix2dSection,(void*)&testPoisson);CHKERRQ(ierr);
>>>>>>>>> ierr =
>>>>>>>>> KSPSetComputeRHS(ksp,computeRhs2dSection,(void*)&testPoisson);CHKERRQ(ierr);
>>>>>>>>> ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>>>>>>>>> ierr = KSPSolve(ksp,NULL,NULL);CHKERRQ(ierr);
>>>>>>>>> The computeMatrix2dSection function has:
>>>>>>>>> ierr = KSPGetDM(ksp,&da);CHKERRQ(ierr);
>>>>>>>>> ierr = DMDAGetLocalInfo(da,&info);CHKERRQ(ierr);
>>>>>>>>> ierr = DMGetDefaultGlobalSection(da,&gs);CHKERRQ(ierr);
>>>>>>>>> for(PetscInt j = info.ys; j<info.ys+info.ym; ++j) {
>>>>>>>>> for(PetscInt i = info.xs; i<info.xs+info.xm; ++i) {
>>>>>>>>> if (isPosInDomain(ctx,i,j)) {
>>>>>>>>> ierr =
>>>>>>>>> DMDAGetCellPoint(da,i,j,0,&point);CHKERRQ(ierr);
>>>>>>>>> ierr = PetscSectionGetOffset(gs,point,&row);
>>>>>>>>> ierr = PetscSectionGetDof(gs,point,&dof);
>>>>>>>>> for(PetscInt cDof = 0; cDof < dof; ++cDof) {
>>>>>>>>> num = 0;
>>>>>>>>> row+=cDof;
>>>>>>>>> col[num] = row; //(i,j) position
>>>>>>>>> v[num++] = -4;
>>>>>>>>> if(isPosInDomain(ctx,i+1,j)) {
>>>>>>>>> ierr =
>>>>>>>>> DMDAGetCellPoint(da,i+1,j,0,&point);CHKERRQ(ierr);
>>>>>>>>> ierr =
>>>>>>>>> PetscSectionGetOffset(gs,point,&col[num]);
>>>>>>>>> col[num] += cDof;
>>>>>>>>> v[num++] = 1;
>>>>>>>>> if(isPosInDomain(ctx,i-1,j)) {
>>>>>>>>> ierr =
>>>>>>>>> DMDAGetCellPoint(da,i-1,j,0,&point);CHKERRQ(ierr);
>>>>>>>>> ierr =
>>>>>>>>> col[num] += cDof;
>>>>>>>>> v[num++] = 1;
>>>>>>>>> if(isPosInDomain(ctx,i,j+1)) {
>>>>>>>>> ierr =
>>>>>>>>> DMDAGetCellPoint(da,i,j+1,0,&point);CHKERRQ(ierr);
>>>>>>>>> ierr =
>>>>>>>>> col[num] += cDof;
>>>>>>>>> v[num++] = 1;
>>>>>>>>> if(isPosInDomain(ctx,i,j-1)) {
>>>>>>>>> ierr =
>>>>>>>>> DMDAGetCellPoint(da,i,j-1,0,&point);CHKERRQ(ierr);
>>>>>>>>> ierr =
>>>>>>>>> col[num] += cDof;
>>>>>>>>> v[num++] = 1;
>>>>>>>>> ierr =
>>>>>>>>> MatSetValues(A,1,&row,num,col,v,INSERT_VALUES);CHKERRQ(ierr);
>>>>>>>>> ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>>>>>>> ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>>>>>>> But this is not working. For e.g. for a 6X6 grid size I get the
>>>>>>>>> following error:
>>>>>>>> Okay, here is how to debug this:
>>>>>>>> 0) Go to a single scalar equations to make things easier
>>>>>>>> 1) Use MatView(A, PETSC_VIEWER_STDOUT_WORLD), which should output
>>>>>>>> a 36 row matrix with
>>>>>>>> the preallocated nonzero pattern, filled with zeros
>>>>>>>> 2) Make sure this is the pattern you want
>>>>>>>> 3) Run in the debugger with -start_in_debugger
>>>>>>>> 4) When you get the error, see
>>>>>>>> a) If the (i, j) is one that should be setting a value
>>>>>>>> b) Why this (i, j) was not preallocated
>>>>>>> Up to 4 (a), it is correct. There is a problem in the way
>>>>>>> DMDAGetCellPoint and PetscSectionGetOffset works in this case scenario. I
>>>>>>> will try to explain it below for the case of 4X4 grid.
>>>>>>> First case:
>>>>>>> If I set the computational domain to be all the points of the dmda
>>>>>>> grid, (i.e. isPosInDomain(..,i,j,..) returns true for all i and j in the
>>>>>>> dmda grid), the program runs fine and does not give any error.
>>>>>>> Second case:
>>>>>>> I want the computational domain to be some part of the whole grid.
>>>>>>> There is a problem in this case.
>>>>>>> The following test is in a case where,
>>>>>>> isPosInDomain(..,i,j,..) returns true ONLY for (i,j) pairs of (2,1)
>>>>>>> (1,2) (2,2) (3,2) and (3,2). The grid with its corresponding point number
>>>>>>> in the petscsection is shown below:
>>>>>>> 12 13 14 15
>>>>>>> 8 9 10 11
>>>>>>> 4 5 6 7
>>>>>>> 0 1 2 3
>>>>>>> of which 6, 9, 10, 11 and 14 correspond to the (i,j) points that
>>>>>>> returns true for isPosInDomain(..,i,j,..)
>>>>>>> MatView gives me the 16-row matrix with the star stencil non-zero
>>>>>>> structure as expected.
>>>>>>> The error I get is: new non-zero at (0,2) caused a malloc.
>>>>>>> This error is for the value of (i,j) = (2,1), i.e. point 6.
>>>>>>> The loop to set values in the matrix starts as:
>>>>>>> ierr =
>>>>>>> Now, what I wanted from the beginning is to create the matrix
>>>>>>> containing the rows corresponding to only those points (i,j) which has true
>>>>>>> values for isPosInDomain(ctx,i,j), that means in this case 5 row matrix. In
>>>>>>> the current test, the first (i,j) that reaches DMDAGetCellPoint is (2,1),
>>>>>>> which gives sets point variable to 6.
>>>>>>> The line PetscSectionGetOffset(gs,point,&row) sets the value of row
>>>>>>> to 0.
>>>>>>> So I think this where the inconsistency lies.
>>>>>>> MatSetValues(A,1,&row,num,col,v,INSERT_VALUES) expects row variable
>>>>>>> and col[] array to correspond to (i,j) based on DMDA, but
>>>>>>> PetsSectionGetOffset gives result based on how we masked away some of the
>>>>>>> points from dmda grid. Or am I missing something very basic here ?
>>>>>> You are missing something basic. The row is correctly identified as
>>>>>> 0, and that means the 2 is
>>>>>> point 10.
>>>>> The problem must be preallocation. First, you should send the result
>>>>>> of MatView().
>>>>> MatView shows that the preallocation and the matrix created is for the
>>>>> full dmda grid which is probably not what we want here, right ? Here is the
>>>>> matview result:
>>>> Thats right. Did you call
>>>> DMSetDefaultSection(da, s)
>>>> after you made the new section and before you called DMGetMatrix()?
>>> Do you mean before I called DMCreateMatrix() ? I called
>>> DMSetDefaultSection(da,s) as below:
>>> // ierr = DMGetMatrix(dm,&A);CHKERRQ(ierr); //It seems DMGetMatrix
>>> is changed to DMCreateMatrix().
>>> ierr = MatView(A,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>> Yes, this is correct. I do exactly this in the example code and it works
>> fine. I suspect
>> you are not creating the section you think you are. You can send the
>> code if you want
>> and I will look at it.
> Thanks, here is the code:
> https://github.com/bishesh/petscPoissonIrregular/blob/master/poissonIrregular.cxx
> It works for 2D and 3D without using PetscSection. (The choice of using
> Petsc_section is on line 68). Using PetsSection currently it implements
> only the 2D case with dof = 1. It works when the domain consists of all the
> cells of the dmda, it works (to check you can uncomment line 129 in
> isPosInDomain(). But it does not when I mask out some of the cells while
> creating the petscsection.
Hi Matt, I'm afraid if my last email somehow escaped you. Could you please
let me know what could be possibly going wrong with my code linked above ?
>> Matt
>>> This MatView on A shows (result below) that it still has 16 rows for all
>>> DMDA points instead of only those petscsection points for which I set a
>>> non-zero dof. Is it what it should not be doing ?
>>>> Mat Object: 1 MPI processes
>>>>> type: seqaij
>>>>> row 0: (0, 0) (1, 0) (4, 0)
>>>>> row 1: (0, 0) (1, 0) (2, 0) (5, 0)
>>>>> row 2: (1, 0) (2, 0) (3, 0) (6, 0)
>>>>> row 3: (2, 0) (3, 0) (7, 0)
>>>>> row 4: (0, 0) (4, 0) (5, 0) (8, 0)
>>>>> row 5: (1, 0) (4, 0) (5, 0) (6, 0) (9, 0)
>>>>> row 6: (2, 0) (5, 0) (6, 0) (7, 0) (10, 0)
>>>>> row 7: (3, 0) (6, 0) (7, 0) (11, 0)
>>>>> row 8: (4, 0) (8, 0) (9, 0) (12, 0)
>>>>> row 9: (5, 0) (8, 0) (9, 0) (10, 0) (13, 0)
>>>>> row 10: (6, 0) (9, 0) (10, 0) (11, 0) (14, 0)
>>>>> row 11: (7, 0) (10, 0) (11, 0) (15, 0)
>>>>> row 12: (8, 0) (12, 0) (13, 0)
>>>>> row 13: (9, 0) (12, 0) (13, 0) (14, 0)
>>>>> row 14: (10, 0) (13, 0) (14, 0) (15, 0)
>>>>> row 15: (11, 0) (14, 0) (15, 0)
>>>>> [0]PETSC ERROR: --------------------- Error Message
>>>>> [0]PETSC ERROR: Argument out of range!
>>>>> [0]PETSC ERROR: New nonzero at (0,2) caused a malloc!
>>> For reference here is the code snippet again:
>>> ierr = DMDAGetNumCells(dm, NULL, NULL, NULL, &nC);CHKERRQ(ierr);
>>> PetscInt point;
>>> ierr = PetscSectionSetDof(s, point, testPoisson.mDof);
>>> ierr =
>>> ierr =
>>> The function computeMatrix2dSection:
>>> #undef __FUNCT__
>>> #define __FUNCT__ "computeMatrix2dSection"
>>> PetscErrorCode computeMatrix2dSection(KSP ksp, Mat A, Mat B,
>>> MatStructure *str, void *context) {
>>> PoissonModel *ctx = (PoissonModel*)context;
>>> PetscErrorCode ierr;
>>> DM da;
>>> DMDALocalInfo info;
>>> PetscInt row, col[5];
>>> PetscInt dof;
>>> PetscScalar v[5]; //array to store 5 point stencil for
>>> each row
>>> PetscInt num; //non-zero position in the current row
>>> // PetscScalar dScale = 1; //to scale Dirichlet
>>> identity rows if needed
>>> PetscSection gs; //Global Section that keeps
>>> the grid info and indices
>>> PetscInt point; //Current point of the
>>> petscSection
>>> PetscFunctionBeginUser;
>>> ierr = DMCreateMatrix(da,&A);CHKERRQ(ierr);
>>> // ierr = MatView(A,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
>>> ierr = DMDAGetCellPoint(da,i,j,0,&point);CHKERRQ(ierr);
>>> for(PetscInt cDof = 0; cDof < ctx->mDof; ++cDof) {
>>> num = 0;
>>> row+=cDof;
>>> v[num++] = -4;
>>> ierr =
>>> ierr = PetscSectionGetOffset(gs,point,&col[num]);
>>> col[num] += cDof;
>>> v[num++] = 1;
>>> ierr =
>>> col[num] += cDof;
>>> v[num++] = 1;
>>> ierr =
>>> col[num] += cDof;
>>> v[num++] = 1;
>>> ierr =
>>> col[num] += cDof;
>>> v[num++] = 1;
>>> ierr =
>>>>>> Matt
>>>>>>>> Thanks,
>>>>>>>> Matt
>>>>>>>>> [0]PETSC ERROR: New nonzero at (0,6) caused a malloc!
>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>> [0]PETSC ERROR: Petsc Development GIT revision:
>>>>>>>>> 61e5e40bb2c5bf2423e94b71a15fef47e411b0da GIT Date: 2013-10-25 21:47:45
>>>>>>>>> -0500
>>>>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>> [0]PETSC ERROR: build/poissonIrregular on a arch-linux2-cxx-debug
>>>>>>>>> named edwards by bkhanal Thu Oct 31 19:23:58 2013
>>>>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>>>>> /home/bkhanal/Documents/softwares/petsc/arch-linux2-cxx-debug/lib
>>>>>>>>> [0]PETSC ERROR: Configure run at Sat Oct 26 16:35:15 2013
>>>>>>>>> [0]PETSC ERROR: Configure options --download-mpich
>>>>>>>>> -download-f-blas-lapack=1 --download-metis --download-parmetis
>>>>>>>>> --download-superlu_dist --download-scalapack --download-mumps
>>>>>>>>> --download-hypre --with-clanguage=cxx
>>>>>>>>> [0]PETSC ERROR:
>>>>>>>>> [0]PETSC ERROR: MatSetValues_SeqAIJ() line 413 in
>>>>>>>>> src/mat/impls/aij/seq/aij.c
>>>>>>>>> [0]PETSC ERROR: MatSetValues() line 1130 in
>>>>>>>>> src/mat/interface/matrix.c
>>>>>>>>> [0]PETSC ERROR: computeMatrix2dSection() line 318 in
>>>>>>>>> /user/bkhanal/home/works/poissonIrregular/poissonIrregular.cxx
>>>>>>>>> [0]PETSC ERROR: KSPSetUp() line 228 in
>>>>>>>>> src/ksp/ksp/interface/itfunc.c
>>>>>>>>> [0]PETSC ERROR: KSPSolve() line 399 in
>>>>>>>>> [0]PETSC ERROR: main() line 598 in
>>>>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 63) - process 0
>>>>>>>>> [unset]: aborting job:
>>>>>>>>>> Matt
>>>>>>>>>>> However, now since I do not want the rows in the matrix
>>>>>>>>>>> corresponding to the points in the grid which do not lie in the
>>>>>>>>>>> computational domain. This means the size of the matrix will not
>>>>>>>>>>> necessarily equal the total number of cells in DMDA. So in the following
>>>>>>>>>>> code:
>>>>>>>>>>> ierr = DMDAGetLocalInfo(dm,&info);CHKERRQ(ierr);
>>>>>>>>>>> &s);CHKERRQ(ierr);
>>>>>>>>>>> &nC);CHKERRQ(ierr);
>>>>>>>>>>> PetscInt point;
>>>>>>>>>>> should I myself compute proper nC (i.e. total no. of points for
>>>>>>>>>>> which I want the matrix to have a corresponding row) before calling
>>>>>>>>>>> PetscSectionSetChart() or is the masking out of the points inside the loop
>>>>>>>>>>> with if(isPosInDomain(&testPoisson,i,j,0)) sufficient ?
>>>>>>>>>>> And, when you write:
>>>>>>>>>>> PetscSectionGetOffset(gs, p, &ind);
>>>>>>>>>>> row = ind < 0 ? -(ind+1) : ind;
>>>>>>>>>>> it seems you allow the possibility of getting a -ve ind when
>>>>>>>>>>> using PetscSectionGetOffset. When would an offset to a particular dof and
>>>>>>>>>>> point?
>>>>>>>>>>>>> num = 0;
>>>>>>>>>>>>> /*ierr =
>>>>>>>>>>>>> DMDAGetCellPoint(da,i,j,0,&point);CHKERRQ(ierr);*/ /*Get the PetscPoint*/
>>>>>>>>>>>>> /*But I did now understand how I would emulate
>>>>>>>>>>>>> the row.c and col.c info with PetscSection*/
>>>>>>>>>>>>> row.i = i; row.j = j;
>>>>>>>>>>>> Here you would call
>>>>>>>>>>>> ierr = DMDAGetCellPoint(da, i, j, 0, &cell);CHKERRQ(ierr);
>>>>>>>>>>>> ierr = PetscSectionGetOffset(da, cell, &row);CHKERRQ(ierr);
>>>>>>>>>>>> ierr = PetscSectionGetDof(da, cell, &dof);CHKERRQ(ierr);
>>>>>>>>>>>> This means that this cell has global rows = [row, row+dof).
>>>>>>>>>>>>> col[num].i = i; col[num].j = j;
>>>>>>>>>>>>> if (isPosInDomain(ctx,i,j)) { /*put the
>>>>>>>>>>>>> operator for only the values for only the points lying in the domain*/
>>>>>>>>>>>>> v[num++] = -4;
>>>>>>>>>>>>> col[num].i = i+1; col[num].j = j;
>>>>>>>>>>>>> v[num++] = 1;
>>>>>>>>>>>>> col[num].i = i-1; col[num].j = j;
>>>>>>>>>>>>> v[num++] = 1;
>>>>>>>>>>>>> col[num].i = i; col[num].j = j+1;
>>>>>>>>>>>>> v[num++] = 1;
>>>>>>>>>>>>> col[num].i = i; col[num].j = j-1;
>>>>>>>>>>>>> v[num++] = 1;
>>>>>>>>>>>>> } else {
>>>>>>>>>>>>> v[num++] = dScale; /*set Dirichlet
>>>>>>>>>>>>> identity rows for points in the rectangle but outside the computational
>>>>>>>>>>>>> domain*/
>>>>>>>>>>>> You do the same thing for the columns, and then call
>>>>>>>>>>>> ierr = MatSetValues(A, dof, rows, num*dof, cols, v,
>>>>>>>>>>>>> ierr =
>>>>>>>>>>>>> MatSetValuesStencil(A,1,&row,num,col,v,INSERT_VALUES);CHKERRQ(ierr);
>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>>>>> If not, just put the identity into
>>>>>>>>>>>>>>>>>>>>>>>> the rows you do not use on the full cube. It will
>>>>>>>>>>>>>>>>>>>>>>>> not hurt scalability or convergence.
>>>>>>>>>>>>>>>>>>>>>>> In the case of Poisson with Dirichlet condition this
>>>>>>>>>>>>>>>>>>>>>>> might be the case. But is it always true that having identity rows in the
>>>>>>>>>>>>>>>>>>>>>>> system matrix will not hurt convergence ? I thought otherwise for the
>>>>>>>>>>>>>>>>>>>>>>> following reasons:
>>>>>>>>>>>>>>>>>>>>>>> 1) Having read Jed's answer here :
>>>>>>>>>>>>>>>>>>>>>>> http://scicomp.stackexchange.com/questions/3426/why-is-pinning-a-point-to-remove-a-null-space-bad/3427#3427
>>>>>>>>>>>>>>>>>>>>>> Jed is talking about a constraint on a the pressure
>>>>>>>>>>>>>>>>>>>>>> at a point. This is just decoupling these unknowns from the rest
>>>>>>>>>>>>>>>>>>>>>> of the problem.
>>>>>>>>>>>>>>>>>>>>>>> 2) Some observation I am getting (but I am still
>>>>>>>>>>>>>>>>>>>>>>> doing more experiments to confirm) while solving my staggered-grid 3D
>>>>>>>>>>>>>>>>>>>>>>> stokes flow with schur complement and using -pc_type gamg for A00 matrix.
>>>>>>>>>>>>>>>>>>>>>>> Putting the identity rows for dirichlet boundaries and for ghost cells
>>>>>>>>>>>>>>>>>>>>>>> seemed to have effects on its convergence. I'm hoping once I know how to
>>>>>>>>>>>>>>>>>>>>>>> use PetscSection, I can get rid of using ghost cells method for the
>>>>>>>>>>>>>>>>>>>>>>> staggered grid and get rid of the identity rows too.
>>>>>>>>>>>>>>>>>>>>>> It can change the exact iteration, but it does not
>>>>>>>>>>>>>>>>>>>>>> make the matrix conditioning worse.
>>>>>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>>>>>> Anyway please provide me with some pointers so
>>>>>>>>>>>>>>>>>>>>>>> that I can start trying with petscsection on top of a dmda, in the
>>>>>>>>>>>>>>>>>>>>>>> beginning for non-staggered case.
>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>> Bishesh
>>>>>>>>>>>>>>>>>>>>>>>> Matt
>>>>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>>>>> Bishesh
>>>>>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before
>>>>>>>>>>>>>>>>>>>>>>>> they begin their experiments is infinitely more interesting than any
>>>>>>>>>>>>>>>>>>>>>>>> results to which their experiments lead.
>>>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before they
>>>>>>>>>>>>>>>>>>>>>> begin their experiments is infinitely more interesting than any results to
>>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>> experiments lead.
>>>>>>>>>> -- Norbert Wiener
>>>>>>>> experiments lead.
>>>>>>>> -- Norbert Wiener
>>>>>> experiments lead.
>>>>>> -- Norbert Wiener
>>>> experiments lead.
>>>> -- Norbert Wiener
>> experiments lead.
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131111/13d06d86/attachment-0001.html>
