[petsc-users] using petsc tools to solve isolated irregular domains with finite difference
Bishesh Khanal bisheshkh at gmail.com
Mon Nov 4 04:49:25 CST 2013
On Fri, Nov 1, 2013 at 1:30 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Nov 1, 2013 at 12:08 AM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>> On Thu, Oct 31, 2013 at 11:34 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>> On Thu, Oct 31, 2013 at 5:02 PM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>> On Thu, Oct 31, 2013 at 7:43 PM, Matthew Knepley <knepley at gmail.com>wrote:
>>>>> On Thu, Oct 31, 2013 at 1:25 PM, Bishesh Khanal <bisheshkh at gmail.com>wrote:
>>>>>> I did not call DMCreateMatrix() before when using just dmda (and it
>>>>>> is working). In any case, I added a call to DMCreateMatrix() now but still
>>>>>> there are problems. Here are the code snippets and the error I get:
>>>>> Then you were allowing it to be called automatically by PETSc, and it
>>>>> would have been this time as well.
>>>>>> //Setting up the section and linking it to DM:
>>>>>> ierr = PetscSectionCreate(PETSC_COMM_WORLD, &s);CHKERRQ(ierr);
>>>>>>     ierr = DMDAGetNumCells(dm, NULL, NULL, NULL, &nC);CHKERRQ(ierr);
>>>>>>     ierr = PetscSectionSetChart(s, 0, nC);CHKERRQ(ierr);
>>>>>>     for (PetscInt j = info.ys; j < info.ys+info.ym; ++j) {
>>>>>>         for (PetscInt i = info.xs; i < info.xs+info.xm; ++i) {
>>>>>>             PetscInt point;
>>>>>>             if(isPosInDomain(&testPoisson,i,j,0)) {
>>>>>>                 ierr = DMDAGetCellPoint(dm, i, j, 0,
>>>>>> &point);CHKERRQ(ierr);
>>>>>>                 ierr = PetscSectionSetDof(s, point,
>>>>>> testPoisson.mDof); // No. of dofs associated with the point.
>>>>>>     ierr = PetscSectionSetUp(s);CHKERRQ(ierr);
>>>>>>     ierr = DMSetDefaultSection(dm, s);CHKERRQ(ierr);
>>>>>>     ierr = PetscSectionDestroy(&s);CHKERRQ(ierr);
>>>>>>     ierr = DMCreateMatrix(dm,&A);CHKERRQ(ierr);
>>>>>>  //Set up KSP:
>>>>>>     ierr = KSPCreate(PETSC_COMM_WORLD,&ksp);CHKERRQ(ierr);
>>>>>>     ierr = KSPSetDM(ksp,dm);CHKERRQ(ierr);
>>>>>>     ierr =
>>>>>> KSPSetComputeOperators(ksp,computeMatrix2dSection,(void*)&testPoisson);CHKERRQ(ierr);
>>>>>>     ierr =
>>>>>> KSPSetComputeRHS(ksp,computeRhs2dSection,(void*)&testPoisson);CHKERRQ(ierr);
>>>>>>     ierr = KSPSetFromOptions(ksp);CHKERRQ(ierr);
>>>>>>     ierr = KSPSolve(ksp,NULL,NULL);CHKERRQ(ierr);
>>>>>> The computeMatrix2dSection function has:
>>>>>> ierr = KSPGetDM(ksp,&da);CHKERRQ(ierr);
>>>>>>     ierr = DMDAGetLocalInfo(da,&info);CHKERRQ(ierr);
>>>>>>     ierr = DMGetDefaultGlobalSection(da,&gs);CHKERRQ(ierr);
>>>>>>     for(PetscInt j = info.ys; j<info.ys+info.ym; ++j) {
>>>>>>         for(PetscInt i = info.xs; i<info.xs+info.xm; ++i) {
>>>>>>             if (isPosInDomain(ctx,i,j)) {
>>>>>>                 ierr =
>>>>>> DMDAGetCellPoint(da,i,j,0,&point);CHKERRQ(ierr);
>>>>>>                 ierr = PetscSectionGetOffset(gs,point,&row);
>>>>>>                 ierr = PetscSectionGetDof(gs,point,&dof);
>>>>>>                 for(PetscInt cDof = 0; cDof < dof; ++cDof) {
>>>>>>                     num = 0;
>>>>>>                     row+=cDof;
>>>>>>                     col[num] = row;         //(i,j) position
>>>>>>                     v[num++] = -4;
>>>>>>                     if(isPosInDomain(ctx,i+1,j)) {
>>>>>>                         ierr =
>>>>>> DMDAGetCellPoint(da,i+1,j,0,&point);CHKERRQ(ierr);
>>>>>>                         ierr =
>>>>>> PetscSectionGetOffset(gs,point,&col[num]);
>>>>>>                         col[num] += cDof;
>>>>>>                         v[num++] = 1;
>>>>>>                     if(isPosInDomain(ctx,i-1,j)) {
>>>>>>                         ierr =
>>>>>> DMDAGetCellPoint(da,i-1,j,0,&point);CHKERRQ(ierr);
>>>>>>                         ierr =
>>>>>>                         col[num] += cDof;
>>>>>>                         v[num++] = 1;
>>>>>>                     if(isPosInDomain(ctx,i,j+1)) {
>>>>>>                         ierr =
>>>>>> DMDAGetCellPoint(da,i,j+1,0,&point);CHKERRQ(ierr);
>>>>>>                         ierr =
>>>>>>                         col[num] += cDof;
>>>>>>                         v[num++] = 1;
>>>>>>                     if(isPosInDomain(ctx,i,j-1)) {
>>>>>>                         ierr =
>>>>>> DMDAGetCellPoint(da,i,j-1,0,&point);CHKERRQ(ierr);
>>>>>>                         ierr =
>>>>>>                         col[num] += cDof;
>>>>>>                         v[num++] = 1;
>>>>>>                     ierr =
>>>>>> MatSetValues(A,1,&row,num,col,v,INSERT_VALUES);CHKERRQ(ierr);
>>>>>>     ierr = MatAssemblyBegin(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>>>>     ierr = MatAssemblyEnd(A,MAT_FINAL_ASSEMBLY);CHKERRQ(ierr);
>>>>>> But this is not working. For e.g. for a 6X6 grid size I get the
>>>>>> following error:
>>>>> Okay, here is how to debug this:
>>>>>   0) Go to a single scalar equations to make things easier
>>>>>   1) Use MatView(A, PETSC_VIEWER_STDOUT_WORLD), which should output a
>>>>> 36 row matrix with
>>>>>        the preallocated nonzero pattern, filled with zeros
>>>>>   2) Make sure this is the pattern you want
>>>>>   3) Run in the debugger with -start_in_debugger
>>>>>   4) When you get the error, see
>>>>>     a) If the (i, j) is one that should be setting a value
>>>>>     b) Why this (i, j) was not preallocated
>>>> Up to 4 (a), it is correct. There is a problem in the way
>>>> DMDAGetCellPoint and PetscSectionGetOffset works in this case scenario. I
>>>> will try to explain it below for the case of 4X4 grid.
>>>> First case:
>>>> If I set the computational domain to be all the points of the dmda
>>>> grid, (i.e. isPosInDomain(..,i,j,..) returns true for all i and j in the
>>>> dmda grid), the program runs fine and does not give any error.
>>>> Second case:
>>>> I want the computational domain to be some part of the whole grid.
>>>> There is a problem in this case.
>>>> The following test is in a case where,
>>>> isPosInDomain(..,i,j,..) returns true ONLY for (i,j) pairs of (2,1)
>>>> (1,2) (2,2) (3,2) and (3,2). The grid with its corresponding point number
>>>> in the petscsection is shown below:
>>>> 12  13  14  15
>>>> 8    9     10  11
>>>> 4    5     6    7
>>>> 0    1     2    3
>>>> of which 6, 9, 10, 11 and 14 correspond to the (i,j) points that
>>>> returns true for isPosInDomain(..,i,j,..)
>>>> MatView gives me the 16-row matrix with the star stencil non-zero
>>>> structure as expected.
>>>> The error I get is: new non-zero at (0,2) caused a malloc.
>>>> This error is for the value of (i,j) = (2,1), i.e. point 6.
>>>> The loop to set values in the matrix starts as:
>>>>                 ierr = DMDAGetCellPoint(da,i,j,0,&point);CHKERRQ(ierr);
>>>> Now, what I wanted from the beginning is to create the matrix
>>>> containing the rows corresponding to only those points (i,j) which has true
>>>> values for isPosInDomain(ctx,i,j), that means in this case 5 row matrix. In
>>>> the current test, the first (i,j) that reaches DMDAGetCellPoint is (2,1),
>>>> which gives sets point variable to 6.
>>>> The line PetscSectionGetOffset(gs,point,&row) sets the value of row to
>>>> 0.
>>>> So I think this where the inconsistency lies.
>>>> MatSetValues(A,1,&row,num,col,v,INSERT_VALUES) expects row variable and
>>>> col[] array to correspond to (i,j) based on DMDA, but PetsSectionGetOffset
>>>> gives result based on how we masked away some of the points from dmda grid.
>>>> Or am I missing something very basic here ?
>>> You are missing something basic. The row is correctly identified as 0,
>>> and that means the 2 is
>>> point 10.
>> The problem must be preallocation. First, you should send the result of
>>> MatView().
>> MatView shows that the preallocation and the matrix created is for the
>> full dmda grid which is probably not what we want here, right ? Here is the
>> matview result:
> Thats right. Did you call
>   DMSetDefaultSection(da, s)
> after you made the new section and before you called DMGetMatrix()?
Do you mean before I called DMCreateMatrix() ? I called
DMSetDefaultSection(da,s) as below:
//    ierr = DMGetMatrix(dm,&A);CHKERRQ(ierr);  //It seems DMGetMatrix is
changed to DMCreateMatrix().
    ierr = MatView(A,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
This MatView on A shows (result below) that it still has 16 rows for all
DMDA points instead of only those petscsection points for which I set a
non-zero dof. Is it what it should not be doing ?
> Mat Object: 1 MPI processes
>> type: seqaij
>> row 0: (0, 0) (1, 0) (4, 0)
>> row 1: (0, 0) (1, 0) (2, 0) (5, 0)
>> row 2: (1, 0) (2, 0) (3, 0) (6, 0)
>> row 3: (2, 0) (3, 0) (7, 0)
>> row 4: (0, 0) (4, 0) (5, 0) (8, 0)
>> row 5: (1, 0) (4, 0) (5, 0) (6, 0) (9, 0)
>> row 6: (2, 0) (5, 0) (6, 0) (7, 0) (10, 0)
>> row 7: (3, 0) (6, 0) (7, 0) (11, 0)
>> row 8: (4, 0) (8, 0) (9, 0) (12, 0)
>> row 9: (5, 0) (8, 0) (9, 0) (10, 0) (13, 0)
>> row 10: (6, 0) (9, 0) (10, 0) (11, 0) (14, 0)
>> row 11: (7, 0) (10, 0) (11, 0) (15, 0)
>> row 12: (8, 0) (12, 0) (13, 0)
>> row 13: (9, 0) (12, 0) (13, 0) (14, 0)
>> row 14: (10, 0) (13, 0) (14, 0) (15, 0)
>> row 15: (11, 0) (14, 0) (15, 0)
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Argument out of range!
>> [0]PETSC ERROR: New nonzero at (0,2) caused a malloc!
For reference here is the code snippet again:
            PetscInt point;
                ierr = DMDAGetCellPoint(dm, i, j, 0, &point);CHKERRQ(ierr);
                ierr = PetscSectionSetDof(s, point, testPoisson.mDof); //
 ierr =
 ierr =
The function computeMatrix2dSection:
#undef __FUNCT__
#define __FUNCT__ "computeMatrix2dSection"
PetscErrorCode computeMatrix2dSection(KSP ksp, Mat A, Mat B, MatStructure
*str, void *context) {
    PoissonModel            *ctx = (PoissonModel*)context;
    PetscErrorCode          ierr;
    DM                      da;
    DMDALocalInfo           info;
    PetscInt                row, col[5];
    PetscInt                dof;
    PetscScalar             v[5]; //array to store 5 point stencil for each
row
    PetscInt                num; //non-zero position in the current row
    //    PetscScalar             dScale = 1;     //to scale Dirichlet
identity rows if needed
    PetscSection            gs;             //Global Section that keeps the
grid info and indices
    PetscInt                point;          //Current point of the
petscSection
    PetscFunctionBeginUser;
    ierr = DMCreateMatrix(da,&A);CHKERRQ(ierr);
//    ierr = MatView(A,PETSC_VIEWER_STDOUT_WORLD);CHKERRQ(ierr);
                for(PetscInt cDof = 0; cDof < ctx->mDof; ++cDof) {
                    num = 0;
                    row+=cDof;
                    v[num++] = -4;
                        ierr =
                        ierr = PetscSectionGetOffset(gs,point,&col[num]);
                        col[num] += cDof;
                        v[num++] = 1;
                        ierr =
                        col[num] += cDof;
                        v[num++] = 1;
                        ierr =
                        col[num] += cDof;
                        v[num++] = 1;
                        ierr =
                        col[num] += cDof;
                        v[num++] = 1;
                    ierr =
>>>    Matt
>>>>>   Thanks,
>>>>>      Matt
>>>>>> [0]PETSC ERROR: New nonzero at (0,6) caused a malloc!
>>>>>> [0]PETSC ERROR:
>>>>>> [0]PETSC ERROR: Petsc Development GIT revision:
>>>>>> 61e5e40bb2c5bf2423e94b71a15fef47e411b0da  GIT Date: 2013-10-25 21:47:45
>>>>>> -0500
>>>>>> [0]PETSC ERROR: See docs/changes/index.html for recent updates.
>>>>>> [0]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>>>>> [0]PETSC ERROR: See docs/index.html for manual pages.
>>>>>> [0]PETSC ERROR:
>>>>>> [0]PETSC ERROR: build/poissonIrregular on a arch-linux2-cxx-debug
>>>>>> named edwards by bkhanal Thu Oct 31 19:23:58 2013
>>>>>> [0]PETSC ERROR: Libraries linked from
>>>>>> /home/bkhanal/Documents/softwares/petsc/arch-linux2-cxx-debug/lib
>>>>>> [0]PETSC ERROR: Configure run at Sat Oct 26 16:35:15 2013
>>>>>> [0]PETSC ERROR: Configure options --download-mpich
>>>>>> -download-f-blas-lapack=1 --download-metis --download-parmetis
>>>>>> --download-superlu_dist --download-scalapack --download-mumps
>>>>>> --download-hypre --with-clanguage=cxx
>>>>>> [0]PETSC ERROR:
>>>>>> [0]PETSC ERROR: MatSetValues_SeqAIJ() line 413 in
>>>>>> src/mat/impls/aij/seq/aij.c
>>>>>> [0]PETSC ERROR: MatSetValues() line 1130 in src/mat/interface/matrix.c
>>>>>> [0]PETSC ERROR: computeMatrix2dSection() line 318 in
>>>>>> /user/bkhanal/home/works/poissonIrregular/poissonIrregular.cxx
>>>>>> [0]PETSC ERROR: KSPSetUp() line 228 in src/ksp/ksp/interface/itfunc.c
>>>>>> [0]PETSC ERROR: KSPSolve() line 399 in src/ksp/ksp/interface/itfunc.c
>>>>>> [0]PETSC ERROR: main() line 598 in
>>>>>> application called MPI_Abort(MPI_COMM_WORLD, 63) - process 0
>>>>>> [unset]: aborting job:
>>>>>>>    Matt
>>>>>>>> However, now since I do not want the rows in the matrix
>>>>>>>> corresponding to the points in the grid which do not lie in the
>>>>>>>> computational domain. This means the size of the matrix will not
>>>>>>>> necessarily equal the total number of cells in DMDA. So in the following
>>>>>>>> code:
>>>>>>>>  ierr = DMDAGetLocalInfo(dm,&info);CHKERRQ(ierr);
>>>>>>>>             PetscInt point;
>>>>>>>> should I myself compute proper nC (i.e. total no. of points for
>>>>>>>> which I want the matrix to have a corresponding row) before calling
>>>>>>>> PetscSectionSetChart() or is the masking out of the points inside the loop
>>>>>>>> with if(isPosInDomain(&testPoisson,i,j,0)) sufficient ?
>>>>>>>> And, when you write:
>>>>>>>> PetscSectionGetOffset(gs, p, &ind);
>>>>>>>>   row = ind < 0 ? -(ind+1) : ind;
>>>>>>>> it seems you allow the possibility of getting a -ve ind when using
>>>>>>>> PetscSectionGetOffset. When would an offset to a particular dof and point?
>>>>>>>>>>                 num = 0;
>>>>>>>>>>                 /*ierr =
>>>>>>>>>> DMDAGetCellPoint(da,i,j,0,&point);CHKERRQ(ierr);*/ /*Get the PetscPoint*/
>>>>>>>>>>                 /*But I did now understand how I would emulate
>>>>>>>>>> the row.c and col.c info with PetscSection*/
>>>>>>>>>>                 row.i = i;  row.j = j;
>>>>>>>>> Here you would call
>>>>>>>>>    ierr = DMDAGetCellPoint(da, i, j, 0, &cell);CHKERRQ(ierr);
>>>>>>>>>    ierr = PetscSectionGetOffset(da, cell, &row);CHKERRQ(ierr);
>>>>>>>>>    ierr = PetscSectionGetDof(da, cell, &dof);CHKERRQ(ierr);
>>>>>>>>> This means that this cell has global rows = [row, row+dof).
>>>>>>>>>>                  col[num].i = i; col[num].j = j;
>>>>>>>>>>                 if (isPosInDomain(ctx,i,j)) {      /*put the
>>>>>>>>>> operator for only the values for only the points lying in the domain*/
>>>>>>>>>>                     v[num++] = -4;
>>>>>>>>>>                         col[num].i = i+1;   col[num].j = j;
>>>>>>>>>>                         v[num++] = 1;
>>>>>>>>>>                         col[num].i = i-1;   col[num].j = j;
>>>>>>>>>>                         v[num++] = 1;
>>>>>>>>>>                         col[num].i = i;     col[num].j = j+1;
>>>>>>>>>>                         v[num++] = 1;
>>>>>>>>>>                         col[num].i = i;     col[num].j = j-1;
>>>>>>>>>>                         v[num++] = 1;
>>>>>>>>>>                 } else {
>>>>>>>>>>                     v[num++] = dScale;  /*set Dirichlet identity
>>>>>>>>>> rows for points in the rectangle but outside the computational domain*/
>>>>>>>>> You do the same thing for the columns, and then call
>>>>>>>>>   ierr = MatSetValues(A, dof, rows, num*dof, cols, v,
>>>>>>>>>>                 ierr =
>>>>>>>>>> MatSetValuesStencil(A,1,&row,num,col,v,INSERT_VALUES);CHKERRQ(ierr);
>>>>>>>>>>>     Thanks,
>>>>>>>>>>>      Matt
>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>   Thanks,
>>>>>>>>>>>>>>>>>      Matt
>>>>>>>>>>>>>>>>>>>  If not, just put the identity into
>>>>>>>>>>>>>>>>>>>>> the rows you do not use on the full cube. It will not
>>>>>>>>>>>>>>>>>>>>> hurt scalability or convergence.
>>>>>>>>>>>>>>>>>>>> In the case of Poisson with Dirichlet condition this
>>>>>>>>>>>>>>>>>>>> might be the case. But is it always true that having identity rows in the
>>>>>>>>>>>>>>>>>>>> system matrix will not hurt convergence ? I thought otherwise for the
>>>>>>>>>>>>>>>>>>>> following reasons:
>>>>>>>>>>>>>>>>>>>> 1)  Having read Jed's answer here :
>>>>>>>>>>>>>>>>>>>> http://scicomp.stackexchange.com/questions/3426/why-is-pinning-a-point-to-remove-a-null-space-bad/3427#3427
>>>>>>>>>>>>>>>>>>> Jed is talking about a constraint on a the pressure at a
>>>>>>>>>>>>>>>>>>> point. This is just decoupling these unknowns from the rest
>>>>>>>>>>>>>>>>>>> of the problem.
>>>>>>>>>>>>>>>>>>>> 2) Some observation I am getting (but I am still doing
>>>>>>>>>>>>>>>>>>>> more experiments to confirm) while solving my staggered-grid 3D stokes flow
>>>>>>>>>>>>>>>>>>>> with schur complement and using -pc_type gamg for A00 matrix. Putting the
>>>>>>>>>>>>>>>>>>>> identity rows for dirichlet boundaries and for ghost cells seemed to have
>>>>>>>>>>>>>>>>>>>> effects on its convergence. I'm hoping once I know how to use PetscSection,
>>>>>>>>>>>>>>>>>>>> I can get rid of using ghost cells method for the staggered grid and get
>>>>>>>>>>>>>>>>>>>> rid of the identity rows too.
>>>>>>>>>>>>>>>>>>> It can change the exact iteration, but it does not make
>>>>>>>>>>>>>>>>>>> the matrix conditioning worse.
>>>>>>>>>>>>>>>>>>>    Matt
>>>>>>>>>>>>>>>>>>>>  Anyway please provide me with some pointers so that I
>>>>>>>>>>>>>>>>>>>> can start trying with petscsection on top of a dmda, in the beginning for
>>>>>>>>>>>>>>>>>>>> non-staggered case.
>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>> Bishesh
>>>>>>>>>>>>>>>>>>>>>   Matt
>>>>>>>>>>>>>>>>>>>>>> Thanks,
>>>>>>>>>>>>>>>>>>>>>> Bishesh
>>>>>>>>>>>>>>>>>>>>> What most experimenters take for granted before they
>>>>>>>>>>>>>>>>>>>>> begin their experiments is infinitely more interesting than any results to
>>>>>>>>>>>>>>>>>>>>> which their experiments lead.
>>>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>>>> What most experimenters take for granted before they begin
>>>>>>>>>>>>>>>>> their experiments is infinitely more interesting than any results to which
>>>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>>>> What most experimenters take for granted before they begin their
>>>>>>>>>>> experiments is infinitely more interesting than any results to which their
>>>>>>>>>>> experiments lead.
>>>>>>>>>>> -- Norbert Wiener
>>>>>>>>> experiments lead.
>>>>>>>>> -- Norbert Wiener
>>>>>>> experiments lead.
>>>>>>> -- Norbert Wiener
>>>>> experiments lead.
>>>>> -- Norbert Wiener
>>> experiments lead.
>>> -- Norbert Wiener
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20131104/6e7c8cbf/attachment-0001.html>
