[petsc-users] Issue about using MUMPS with PETSc
Gavin Ge jianchaoge at gmail.com
Mon May 20 23:17:15 CDT 2013
Hi Satish:
Yes I used to use metis. But this update require a cmake 2.5 or higher, which I don't have a privilege to install on the cluster.. But I think you are right, this problem could be fixed by install metis instead. Thanks!
Gavin
On May 20, 2013, at 6:14 PM, Satish Balay wrote:
> And petsc-3.1 presumably was using 'metis' - and not 'scotch' - so you
> could try rebuilding mumps with metis/parmetis.
> right now we do:
>    if self.parmetis.found:
>      orderingsc += ' -Dmetis -Dparmetis'
> Should this splitup to a separate dependency on metis?
> Satish
> On Mon, 20 May 2013, Matthew Knepley wrote:
>> On Mon, May 20, 2013 at 5:47 PM, Gavin Ge <jianchaoge at gmail.com> wrote:
>>> Hi:
>>> I just have my PETSc updated from 3.1 to 3.4, then find problem with using
>>> MUMPs. I have no problem before in 3.1 and also no problem with builtin
>>> iterative solvers for current version. I got the following error message:
>>> (0): ERROR: stratParserParse: invalid method parameter name "type", before
>>> "h,rat=0.7,vert=100,low=h{pass=10},asc=b{width=3,bnd=f{bal=0.2},org=(|h{pass=10})f{bal=0.2}}}|m{type=h,rat=0.7,vert=100,low=h{pass=10},asc=b{width=3,bnd=f{bal=0.2},org=(|h{pass=10})f{bal=0.2}}};,ole=f{cmin=0,cmax=100000,frat=0.0},ose=g},unc=n{sep=/(vert>120)?m{type=h,rat=0.7,vert=100,low=h{pass=10},asc=b{width=3,bnd=f{bal=0.2},org=(|h{pass=10})f{bal=0.2}}}|m{type=h,rat=0.7,vert=100,low=h{pass=10},asc=b{width=3,bnd=f{bal=0.2},org=(|h{pass=10})f{bal=0.2}}};,ole=f{cmin=15,cmax=100000,frat=0.0},ose=g}}"
>>> (0): ERROR: SCOTCH_stratGraphOrder: error in ordering strategy
>> This appears to be an internal MUMPS error related to their use of Scotch
>> for graph partitioning. I would
>> send this to the MUMPS user list.
>>  Thanks,
>>     Matt
>>> Error:no root nodes in ROOTLIST
>>> Error in DISTRIBUTE                                      , layernmb=
>>>      0
>>> procedure reporting the error: ROOTLIST
>>> [48]PETSC ERROR: --------------------- Error Message
>>> [48]PETSC ERROR: Error in external library!
>>> [48]PETSC ERROR: Error reported by MUMPS in analysis phase: INFOG(1)=-135
>>> [48]PETSC ERROR:
>>> [48]PETSC ERROR: Petsc Release Version 3.4.0, May, 13, 2013
>>> [48]PETSC ERROR: See docs/changes/index.html for recent updates.
>>> [48]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
>>> [48]PETSC ERROR: See docs/index.html for manual pages.
>>> [48]PETSC ERROR:
>>> [48]PETSC ERROR: ./code on a linux-gnu-c-debug named bhc.tamu.edu by jge
>>> Mon May 20 17:24:22 2013
>>> [48]PETSC ERROR: Libraries linked from
>>> /data/jge/petsc/linux-gnu-c-debug/lib
>>> [48]PETSC ERROR: Configure run at Thu May 16 17:15:26 2013
>>> [48]PETSC ERROR: Configure options --with-cc=gcc --with-fc-gfortran
>>> --download-f-blas-lapack --download-mpich --download-scalapack
>>> --download-ptscotch --download-mumps --with-scalar-type=complex
>>> [48]PETSC ERROR:
>>> [48]PETSC ERROR: MatLUFactorSymbolic_AIJMUMPS() line 960 in
>>> src/mat/impls/aij/mpi/mumps/mumps.c
>>> [49]PETSC ERROR: --------------------- Error Message
>>> [49]PETSC ERROR: Error in external library!
>>> [49]PETSC ERROR: Error reported by MUMPS in analysis phase: INFOG(1)=-135
>>> Could anyone help me solve this? Thanks!
>>> Regards,
>>> Gavin
