[petsc-users] Issue about using MUMPS with PETSc
Satish Balay
balay at mcs.anl.gov
Mon May 20 18:14:23 CDT 2013
And petsc-3.1 presumably was using 'metis' - and not 'scotch' - so you
could try rebuilding mumps with metis/parmetis.
right now we do:
if self.parmetis.found:
orderingsc += ' -Dmetis -Dparmetis'
Should this splitup to a separate dependency on metis?
Satish
On Mon, 20 May 2013, Matthew Knepley wrote:
> On Mon, May 20, 2013 at 5:47 PM, Gavin Ge <jianchaoge at gmail.com> wrote:
> > Hi:
> > I just have my PETSc updated from 3.1 to 3.4, then find problem with using
> > MUMPs. I have no problem before in 3.1 and also no problem with builtin
> > iterative solvers for current version. I got the following error message:
> > (0): ERROR: stratParserParse: invalid method parameter name "type", before
> > "h,rat=0.7,vert=100,low=h{pass=10},asc=b{width=3,bnd=f{bal=0.2},org=(|h{pass=10})f{bal=0.2}}}|m{type=h,rat=0.7,vert=100,low=h{pass=10},asc=b{width=3,bnd=f{bal=0.2},org=(|h{pass=10})f{bal=0.2}}};,ole=f{cmin=0,cmax=100000,frat=0.0},ose=g},unc=n{sep=/(vert>120)?m{type=h,rat=0.7,vert=100,low=h{pass=10},asc=b{width=3,bnd=f{bal=0.2},org=(|h{pass=10})f{bal=0.2}}}|m{type=h,rat=0.7,vert=100,low=h{pass=10},asc=b{width=3,bnd=f{bal=0.2},org=(|h{pass=10})f{bal=0.2}}};,ole=f{cmin=15,cmax=100000,frat=0.0},ose=g}}"
> > (0): ERROR: SCOTCH_stratGraphOrder: error in ordering strategy
> This appears to be an internal MUMPS error related to their use of Scotch
> for graph partitioning. I would
> send this to the MUMPS user list.
> Thanks,
> Matt
> > Error:no root nodes in ROOTLIST
> > Error in DISTRIBUTE , layernmb=
> > 0
> > procedure reporting the error: ROOTLIST
> > [48]PETSC ERROR: --------------------- Error Message
> > [48]PETSC ERROR: Error in external library!
> > [48]PETSC ERROR: Error reported by MUMPS in analysis phase: INFOG(1)=-135
> > [48]PETSC ERROR:
> > [48]PETSC ERROR: Petsc Release Version 3.4.0, May, 13, 2013
> > [48]PETSC ERROR: See docs/changes/index.html for recent updates.
> > [48]PETSC ERROR: See docs/faq.html for hints about trouble shooting.
> > [48]PETSC ERROR: See docs/index.html for manual pages.
> > [48]PETSC ERROR:
> > [48]PETSC ERROR: ./code on a linux-gnu-c-debug named bhc.tamu.edu by jge
> > Mon May 20 17:24:22 2013
> > [48]PETSC ERROR: Libraries linked from
> > /data/jge/petsc/linux-gnu-c-debug/lib
> > [48]PETSC ERROR: Configure run at Thu May 16 17:15:26 2013
> > [48]PETSC ERROR: Configure options --with-cc=gcc --with-fc-gfortran
> > --download-f-blas-lapack --download-mpich --download-scalapack
> > --download-ptscotch --download-mumps --with-scalar-type=complex
> > [48]PETSC ERROR:
> > [48]PETSC ERROR: MatLUFactorSymbolic_AIJMUMPS() line 960 in
> > src/mat/impls/aij/mpi/mumps/mumps.c
> > [49]PETSC ERROR: --------------------- Error Message
> > [49]PETSC ERROR: Error in external library!
> > [49]PETSC ERROR: Error reported by MUMPS in analysis phase: INFOG(1)=-135
> > Could anyone help me solve this? Thanks!
> > Regards,
> > Gavin
