[petsc-users] Issue about using MUMPS with PETSc
Jed Brown
jedbrown at mcs.anl.gov
Mon May 20 23:21:37 CDT 2013
Gavin Ge <jianchaoge at gmail.com> writes:
> Hi Satish:
> Yes I used to use metis. But this update require a cmake 2.5 or
> higher, which I don't have a privilege to install on the cluster..
Common misconception, but you can install that stuff just fine.
Configure PETSc with --download-cmake, for example.
I recommend using --download-metis because we have patched several
upstream bugs. (Upstream has pretty much stopped maintaining the
package.)
