[petsc-users] 3-dimension to matrix
Joon hee Choi
choi240 at purdue.edu
Fri May 17 14:18:59 CDT 2013
Hi Jed Brown,
Thank you for your fast reply. Your last comments looks like my first code. The full size of the matrix is (X, Y*Z). Also, I used SEQAIJ as matrix type and (X, Y) as block size. Also, I implemented SeqAIJpreallocating with nnz. Nevertheless, it was very slow. The Matrix-Set-Up part of the first code is as follows:
sort(tups.begin(), tups.end());
MatCreate(PETSC_COMM_SELF, &A);
MatSetType(A, MATSEQAIJ);
MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, X, Y*Z);
MatSetBlockSizes(A, X, Y);
MatSeqAIJSetPreallocation(A, PETSC_DEFAULT, nnz);
sz = tups.size();
for (i=0; i<sz; i++) {
x = std::tr1::get<0>(tups[i]);
y = std::tr1::get<2>(tups[i]) + std::tr1::get<1>(tups[i])*Y;
val = std::tr1::get<3>(tups[i]);
MatSetValues(A, 1, &x, 1, &y, &val, INSERT_VALUES);
MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
I used tuple (x, z, y, value) and vector of c++. I didn't get any errors from this code. However, it took about 9 minutes in this part. Please let me know what to change my code. Thank you.
Joon
----- Original Message -----
To: "Joon hee Choi" <choi240 at purdue.edu>, petsc-users at mcs.anl.gov
Sent: Friday, May 17, 2013 8:33:18 AM
Subject: Re: [petsc-users] 3-dimension to matrix
Joon hee Choi <choi240 at purdue.edu> writes:
> Hi all,
> I am trying to set up a matrix with 3d coordinates(x,y,z) and
> value. If X=max(x), Y=max(y) and Z=max(z), then the matrix is as
> follows: A = [ A1 A2 ... AZ ] (each A* is X-by-Y block matrix and A
> consists of Z block matrices)
Are these decoupled diagonal blocks or a sequence of blocks in the row.
That is, is the full size of the matrix (X, Y*Z) or (X*Z, Y*Z). From
the code below, it looks like you intend for it to be the former. What
parallel distribution do you intend for the input vector (of dimension
Y*Z) and the output vector (of dimension X)?
> When I tried to set up the matrix using MatSetValues with each
> coordinates and value, I could get the matrix, but it took 10
> minutes.
This is almost certainly due to not preallocating.
> So I tried to set up the matrix again using
> MatSetLocalToGlobalMapping(Mat x, ISLocalToGlobalMapping rmapping,
> ISLocalToGlobalMapping cmapping), but ISLocalToGloalMapping was minus
> because my dataset is too big (X:26M, Y:26M, Z:48M, nonzero:144M) and
> I got errors. Is there the way to set up the matrix quickly in petsc?
> If so, please let me know the way. And my code using
> MatSetLocalToGlobalMapping following:
> ISLocalToGlobalMappingCreate(PETSC_COMM_SELF, 1, &zr, PETSC_OWN_POINTER, &irow);
This has only one entry.
> ISLocalToGlobalMappingUnBlock(irow, X, &orow);
How did you set the block size of the matrix?
> for (z=0; z<Z; i++)
> ISLocalToGlobalMappingCreate(PETSC_COMM_SELF, 1, &z, PETSC_OWN_POINTER, &icol);
This mapping also has only one entry. It is not intended for you to
change the local-to-global mapping on a matrix.
> MatSetLocalToGlobalMappingBlock(A, irow, icol);
> ISLocalToGlobalMappingUnBlock(icol, Y, &ocol);
> MatSetLocalToGlobalMapping(A, orow, ocol);
> while(!mapX[z].empty())
> x = mapX[z].front();
> y = mapY[z].front();
So instead of changing it, just add the offset to y here.
> val = mapVal[z].front();
> MatSetValuesLocal(A, 1, &x, 1, &y, &val, INSERT_VALUES);
> mapX[z].pop_front();
> mapY[z].pop_front();
> mapVal[z].pop_front();
> Thank you,
> Joon
