[petsc-users] 3-dimension to matrix
Jed Brown
jedbrown at mcs.anl.gov
Fri May 17 07:33:18 CDT 2013
Joon hee Choi <choi240 at purdue.edu> writes:
> Hi all,
> I am trying to set up a matrix with 3d coordinates(x,y,z) and
> value. If X=max(x), Y=max(y) and Z=max(z), then the matrix is as
> follows: A = [ A1 A2 ... AZ ] (each A* is X-by-Y block matrix and A
> consists of Z block matrices)
Are these decoupled diagonal blocks or a sequence of blocks in the row.
That is, is the full size of the matrix (X, Y*Z) or (X*Z, Y*Z). From
the code below, it looks like you intend for it to be the former. What
parallel distribution do you intend for the input vector (of dimension
Y*Z) and the output vector (of dimension X)?
> When I tried to set up the matrix using MatSetValues with each
> coordinates and value, I could get the matrix, but it took 10
> minutes.
This is almost certainly due to not preallocating.
> So I tried to set up the matrix again using
> MatSetLocalToGlobalMapping(Mat x, ISLocalToGlobalMapping rmapping,
> ISLocalToGlobalMapping cmapping), but ISLocalToGloalMapping was minus
> because my dataset is too big (X:26M, Y:26M, Z:48M, nonzero:144M) and
> I got errors. Is there the way to set up the matrix quickly in petsc?
> If so, please let me know the way. And my code using
> MatSetLocalToGlobalMapping following:
> ISLocalToGlobalMappingCreate(PETSC_COMM_SELF, 1, &zr, PETSC_OWN_POINTER, &irow);
This has only one entry.
> ISLocalToGlobalMappingUnBlock(irow, X, &orow);
How did you set the block size of the matrix?
> for (z=0; z<Z; i++)
> ISLocalToGlobalMappingCreate(PETSC_COMM_SELF, 1, &z, PETSC_OWN_POINTER, &icol);
This mapping also has only one entry. It is not intended for you to
change the local-to-global mapping on a matrix.
> MatSetLocalToGlobalMappingBlock(A, irow, icol);
> ISLocalToGlobalMappingUnBlock(icol, Y, &ocol);
> MatSetLocalToGlobalMapping(A, orow, ocol);
> while(!mapX[z].empty())
> x = mapX[z].front();
> y = mapY[z].front();
So instead of changing it, just add the offset to y here.
> val = mapVal[z].front();
> MatSetValuesLocal(A, 1, &x, 1, &y, &val, INSERT_VALUES);
> mapX[z].pop_front();
> mapY[z].pop_front();
> mapVal[z].pop_front();
> Thank you,
> Joon
