[petsc-users] 3-dimension to matrix
Jed Brown
jedbrown at mcs.anl.gov
Fri May 17 14:24:09 CDT 2013
Joon hee Choi <choi240 at purdue.edu> writes:
> Thank you for your fast reply. Your last comments looks like my first
> code. The full size of the matrix is (X, Y*Z). Also, I used SEQAIJ as
> matrix type and (X, Y) as block size. Also, I implemented
> SeqAIJpreallocating with nnz. Nevertheless, it was very slow. The
> Matrix-Set-Up part of the first code is as follows:
> sort(tups.begin(), tups.end());
> MatCreate(PETSC_COMM_SELF, &A);
> MatSetType(A, MATSEQAIJ);
> MatSetSizes(A, PETSC_DECIDE, PETSC_DECIDE, X, Y*Z);
> MatSetBlockSizes(A, X, Y);
> MatSeqAIJSetPreallocation(A, PETSC_DEFAULT, nnz);
> sz = tups.size();
> for (i=0; i<sz; i++) {
> x = std::tr1::get<0>(tups[i]);
> y = std::tr1::get<2>(tups[i]) + std::tr1::get<1>(tups[i])*Y;
> val = std::tr1::get<3>(tups[i]);
> MatSetValues(A, 1, &x, 1, &y, &val, INSERT_VALUES);
> MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
> I used tuple (x, z, y, value) and vector of c++. I didn't get any
> errors from this code. However, it took about 9 minutes in this
> part.
What version of PETSc? Your preallocation was almost certainly not
sufficient.
