[petsc-users] petsc 3.4:
Matteo Parsani
parsani.matteo at gmail.com
Wed May 15 07:33:59 CDT 2013
Just an update. I have install petsc 3.4 without setting PETSC_ARCH
and with surprise I still get the message
egrep: /scratch/home0/pmatteo/
research/workspace/codes/ssdc/deps/petsc/arch-linux2-c-debug/include/
petscconf.h: No such file or directory
Thus I have tried
export PETSC_ARCH=
and the rerun make PETSC_DIR=/scratch/home0/pmatteo
/research/workspace/codes/ssdc/deps/petsc
but I still get the same message.
Lisandro suggested to run the test with the following
make PETSC_DIR=/scratch/home0/pmatteo/research/workspace/codes/ssdc/deps/
petsc PETSC_ARCH= test
and this works without printing any message. Thus we think that maybe the
test_build target, for the case of testing a prefix install has to be
reviewed. Is that right?
Thank you.
On Wed, May 15, 2013 at 8:09 AM, Matteo Parsani <parsani.matteo at gmail.com>wrote:
> Hello Satish,
> the problem with the PATH and LD_LIBRARY_PATH has been fixed. The
> administrator of our systems was working on the OS to install new libraries
> and my .bashrc was not loaded properly. So, now everything is fine.
> Although I set --prefix to install petsc in my code dependencies, I
> noticed that I still was using PETSC_ARC in both petsc 3.3-p7 and petsc3.4 (something like: make
> PETSC_DIR=/scratch/home0/pmatteo/research/lib_src/petsc-3.3-p7 PETSC
> _ARCH=arch-linux2-c-debug install). That was my fault, sorry.
> However, with 3.3-p7 even if I use PETSC_ARCH=arch-linux2-c-debug I did
> not get
> Whereas with petsc 3.4 I got it because of course under petscinstallation directory I have no
> petsc/arch-linux2-c-debug. All the header files are in petsc/lib as it
> should be.
> Thus a couple of questions:
> 1- Installation of petsc 3.4 seems to be more careful and it is able to
> detect that I am setting --prefix and PETSC_ARCH. It does not say that
> explicitly but it print the "egrep message". Would not be better to check
> if the user is setting --prefix and change the installation instructions
> printed at screen?
> Also in the petsc installation documentation it is stressed that PETSC_ARCH
> must not be used with --prefix but ss it is now, even if the user sets
> --prefix, the instructions say:
> make PETSC_DIR=/scratch/home0/pmatteo/research/lib_src/petsc-3.3-p7 PETSC
> 2- this is just a curiosity: why petsc 3.3-p7 was not giving me back the "
> egrep message" though I was setting PETSC_ARCH=arch-linux2-c-debug?
> Thank you.
> On Tue, May 14, 2013 at 4:25 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>> On Tue, 14 May 2013, Matteo Parsani wrote:
>> > Dear PETSc developers and users,
>> > I have just updated petsc from 3.3-p7 to petsc 3.4. and during the
>> > installation testing I get the following message:
>> > pmatteo at parsani-lan:~/research/lib_src/petsc$ make
>> > pmatteo/research/workspace/codes/ssdc/deps/petscnew test
>> > Running test examples to verify correct installation
>> > Using
>> > petscnew and PETSC_ARCH=arch-linux2-c-debug
>> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
>> > MPIprocess
>> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2
>> > MPIprocesses
>> > egrep:
>> /scratch/home0/pmatteo/research/workspace/codes/ssdc/deps/petscnew
>> > /arch-linux2-c-debug/include/petscconf.h: No such file or directory
>> Perhaps you are having file system problems?
>> > Fortran example src/snes/examples/tutorials/ex5f run successfully with
>> > 1 MPIprocess
>> > Completed test examples
>> > The test pass successfully but ....
>> Ok - then the library is ok and useable.
>> > Attached the log file.
>> > Moreover, when I run my Fortran 90 as usual it seems the libpetsc.so can
>> > not be opened (./NSE: error while loading shared libraries: libpetsc.so:
>> > cannot open shared object file: No such file or directory)
>> > PATH and LD_LIBRARY_PATH are set exactly as for petsc 3.3-p7 through my
>> > bashrc file and libpetsc.so is in the right location.
>> > If I switch to 3.3-p7 (just by point to the other directory where
>> > petsc3.3-p7 is installed) it works fine.
>> Perhaps you can use PETSc makefiles - so you don't have to rely on
>> LD_LIBRARY_PATH?
>> [or use
>> -Wl,-rpath,/scratch/home0/pmatteo/research/lib_src/petsc/arch-linux2-c-debug/lib]
>> You can always do 'ldd NSE' to see if the required sharedlibraries are
>> found or not
>> Satish
>> > Any idea?
>> > Thanks,
> Matteo
Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130515/f56dfbbf/attachment-0001.html>
