[petsc-users] petsc 3.4:
Matteo Parsani
parsani.matteo at gmail.com
Wed May 15 07:54:40 CDT 2013
Hello Satish,
Lisandro has found that in the make file we have
include ././${PETSC_ARCH}/conf/petscvariables
However if one uses --prefix PETSC_ARCH must not be used
This is a very minor issue but I think it would be nice to have it fixed.
Thank you in advance.
Best Regards
On Wed, May 15, 2013 at 8:33 AM, Matteo Parsani <parsani.matteo at gmail.com>wrote:
> Just an update. I have install petsc 3.4 without setting PETSC_ARCH
> and with surprise I still get the message
> egrep: /scratch/home0/pmatteo/
> research/workspace/codes/ssdc/deps/petsc/arch-linux2-c-debug/include/
> petscconf.h: No such file or directory
> Thus I have tried
> export PETSC_ARCH=
> and the rerun make PETSC_DIR=/scratch/home0/pmatteo
> /research/workspace/codes/ssdc/deps/petsc
> but I still get the same message.
> Lisandro suggested to run the test with the following
> make PETSC_DIR=/scratch/home0/pmatteo/research/workspace/codes/ssdc/deps/
> petsc PETSC_ARCH= test
> and this works without printing any message. Thus we think that maybe the
> test_build target, for the case of testing a prefix install has to be
> reviewed. Is that right?
> Thank you.
> On Wed, May 15, 2013 at 8:09 AM, Matteo Parsani <parsani.matteo at gmail.com>wrote:
>> Hello Satish,
>> the problem with the PATH and LD_LIBRARY_PATH has been fixed. The
>> administrator of our systems was working on the OS to install new libraries
>> and my .bashrc was not loaded properly. So, now everything is fine.
>> Although I set --prefix to install petsc in my code dependencies, I
>> noticed that I still was using PETSC_ARC in both petsc 3.3-p7 and petsc3.4 (something like: make
>> PETSC_DIR=/scratch/home0/pmatteo/research/lib_src/petsc-3.3-p7 PETSC
>> _ARCH=arch-linux2-c-debug install). That was my fault, sorry.
>> However, with 3.3-p7 even if I use PETSC_ARCH=arch-linux2-c-debug I did
>> not get
>> Whereas with petsc 3.4 I got it because of course under petscinstallation directory I have no
>> petsc/arch-linux2-c-debug. All the header files are in petsc/lib as it
>> should be.
>> Thus a couple of questions:
>> 1- Installation of petsc 3.4 seems to be more careful and it is able to
>> detect that I am setting --prefix and PETSC_ARCH. It does not say that
>> explicitly but it print the "egrep message". Would not be better to
>> check if the user is setting --prefix and change the installation
>> instructions printed at screen?
>> Also in the petsc installation documentation it is stressed that PETSC_ARCH
>> must not be used with --prefix but ss it is now, even if the user sets
>> --prefix, the instructions say:
>> make PETSC_DIR=/scratch/home0/pmatteo/research/lib_src/petsc-3.3-p7 PETSC
>> 2- this is just a curiosity: why petsc 3.3-p7 was not giving me back the
>> "egrep message" though I was setting PETSC_ARCH=arch-linux2-c-debug?
>> Thank you.
>> On Tue, May 14, 2013 at 4:25 PM, Satish Balay <balay at mcs.anl.gov> wrote:
>>> On Tue, 14 May 2013, Matteo Parsani wrote:
>>> > Dear PETSc developers and users,
>>> > I have just updated petsc from 3.3-p7 to petsc 3.4. and during the
>>> > installation testing I get the following message:
>>> > pmatteo at parsani-lan:~/research/lib_src/petsc$ make
>>> > pmatteo/research/workspace/codes/ssdc/deps/petscnew test
>>> > Running test examples to verify correct installation
>>> > Using
>>> > petscnew and PETSC_ARCH=arch-linux2-c-debug
>>> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
>>> > MPIprocess
>>> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2
>>> > MPIprocesses
>>> > egrep:
>>> /scratch/home0/pmatteo/research/workspace/codes/ssdc/deps/petscnew
>>> > /arch-linux2-c-debug/include/petscconf.h: No such file or directory
>>> Perhaps you are having file system problems?
>>> > Fortran example src/snes/examples/tutorials/ex5f run successfully with
>>> > 1 MPIprocess
>>> > Completed test examples
>>> > The test pass successfully but ....
>>> Ok - then the library is ok and useable.
>>> > Attached the log file.
>>> > Moreover, when I run my Fortran 90 as usual it seems the libpetsc.so
>>> can
>>> > not be opened (./NSE: error while loading shared libraries:
>>> libpetsc.so:
>>> > cannot open shared object file: No such file or directory)
>>> > PATH and LD_LIBRARY_PATH are set exactly as for petsc 3.3-p7 through
>>> my .
>>> > bashrc file and libpetsc.so is in the right location.
>>> > If I switch to 3.3-p7 (just by point to the other directory where
>>> > petsc3.3-p7 is installed) it works fine.
>>> Perhaps you can use PETSc makefiles - so you don't have to rely on
>>> LD_LIBRARY_PATH?
>>> [or use
>>> -Wl,-rpath,/scratch/home0/pmatteo/research/lib_src/petsc/arch-linux2-c-debug/lib]
>>> You can always do 'ldd NSE' to see if the required sharedlibraries are
>>> found or not
>>> Satish
>>> > Any idea?
>>> > Thanks,
>> Matteo
> Matteo
Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130515/4f55d73a/attachment.html>
