[petsc-users] petsc 3.4:
Matteo Parsani parsani.matteo at gmail.com
Wed May 15 07:09:28 CDT 2013
Hello Satish,
the problem with the PATH and LD_LIBRARY_PATH has been fixed. The
administrator of our systems was working on the OS to install new libraries
and my .bashrc was not loaded properly. So, now everything is fine.
Although I set --prefix to install petsc in my code dependencies, I noticed
that I still was using PETSC_ARC in both petsc 3.3-p7 and petsc 3.4
(something like:  make PETSC_DIR=/scratch/home0/pmatteo/research/lib_src/
petsc-3.3-p7 PETSC_ARCH=arch-linux2-c-debug install). That was my fault,
sorry.
However, with 3.3-p7 even if I use PETSC_ARCH=arch-linux2-c-debug I did not
get
egrep: /scratch/home0/pmatteo/
research/workspace/codes/ssdc/deps/petsc/arch-linux2-c-debug/include/
petscconf.h: No such file or directory
Whereas with petsc 3.4 I got it because of course under petsc installation
directory I have no petsc/arch-linux2-c-debug. All the header files are in
petsc/lib as it should be.
Thus a couple of questions:
1- Installation of petsc 3.4 seems to be more careful and it is able to
detect that I am setting  --prefix and PETSC_ARCH. It does not say that
explicitly but it print the "egrep message". Would not be better to check
if the user is setting --prefix and change the installation instructions
printed at screen?
Also in the petsc installation documentation it is stressed that PETSC_ARCH
must not be used with --prefix but ss it is now, even if the user sets
--prefix, the instructions say:
make PETSC_DIR=/scratch/home0/pmatteo/research/lib_src/petsc-3.3-p7 PETSC
2- this is just a curiosity: why petsc 3.3-p7 was not giving me back the "
egrep message" though I was setting PETSC_ARCH=arch-linux2-c-debug?
Thank you.
On Tue, May 14, 2013 at 4:25 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> On Tue, 14 May 2013, Matteo Parsani wrote:
> > Dear PETSc developers and users,
> > I have just updated petsc from 3.3-p7 to petsc 3.4. and during the
> > installation testing I get the following message:
> > pmatteo at parsani-lan:~/research/lib_src/petsc$ make
> > pmatteo/research/workspace/codes/ssdc/deps/petscnew test
> > Running test examples to verify correct installation
> > Using
> PETSC_DIR=/scratch/home0/pmatteo/research/workspace/codes/ssdc/deps/
> > petscnew and PETSC_ARCH=arch-linux2-c-debug
> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 1
> > MPIprocess
> > C/C++ example src/snes/examples/tutorials/ex19 run successfully with 2
> > MPIprocesses
> > egrep: /scratch/home0/pmatteo/research/workspace/codes/ssdc/deps/petscnew
> > /arch-linux2-c-debug/include/petscconf.h: No such file or directory
> Perhaps you are having file system problems?
> > Fortran example src/snes/examples/tutorials/ex5f run successfully with
> > 1 MPIprocess
> > Completed test examples
> > The test pass successfully but ....
> Ok - then the library is ok and useable.
> > Attached the log file.
> > Moreover, when I run my Fortran 90 as usual it seems the libpetsc.so can
> > not be opened (./NSE: error while loading shared libraries: libpetsc.so:
> > cannot open shared object file: No such file or directory)
> > PATH and LD_LIBRARY_PATH are set exactly as for petsc 3.3-p7 through my .
> > bashrc file and libpetsc.so is in the right location.
> > If I switch to 3.3-p7 (just by point to the other directory where
> > petsc3.3-p7 is installed) it works fine.
> Perhaps you can use PETSc makefiles - so you don't have to rely on
> LD_LIBRARY_PATH?
> [or use
> -Wl,-rpath,/scratch/home0/pmatteo/research/lib_src/petsc/arch-linux2-c-debug/lib]
> You can always do 'ldd NSE' to see if the required sharedlibraries are
> found or not
> Satish
> > Any idea?
> > Thanks,
Matteo
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130515/a767328d/attachment.html>
