[petsc-users] SLepc configure with Arpack
Jose E. Roman jroman at dsic.upv.es
Fri May 3 12:23:09 CDT 2013
El 03/05/2013, a las 19:14, Dharmendar Reddy escribió:
> Thanks.  I can manage for now by adding the lib path to LD_LIBRARY_PATH.
> On a different note, how do i get help for slepc function used in a executable.
> If i try -help with my code which also uses petsc, i see a lot of petsc realated options as well in the help.
> Is there an option like -eps_help ?
./ex1 -help | grep eps
Jose
