[petsc-users] SLepc configure with Arpack
Nachiket Gokhale gokhalen at gmail.com
Fri May 3 11:31:30 CDT 2013
I can't claim to speak for Jose, but I had asked him this same question
about a year ago, and IIRC he had said that the default algorithm in SlepC
(KrylovSchur) is equivalent or better then Arpack.
Looking through my email this is what I did to get arpack working (I never
used it because I switched to KrylovSchur). Can't guarantee it will work
for you -
> I was able to install ARPACK & link it with SLEPC on FC15 using
gcc/g++/gfortran  The issues were -
> 1)  I needed to change a function declaration in Arpack. This was holding
up the linking.  The function was etime in second.f
> 2)  I need to compile ARPACK with -fno-underscoring to make sure that the
C code (SlepC) links with the Fortran code
> 3)  I needed to compile additional object files by doing make all in the
LAPACK/BLAS directory that came with ARPACK to make sure that the examples
ran.
> 4)  To link it with SlepC I needed to create position independent code
using the -fPIC flag on the compiler
> 5)  I needed to install PETSC and SlepC with OpenMPI to be able to use
Parpack.  I needed to set the LD_LIBRARY_PATH to the directory where the
openmpi compilers were located so that SlepC could find them.
-Nachiket
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130503/4cecb4cd/attachment.html>
