[petsc-users] SLepc configure with Arpack
Jose E. Roman
jroman at dsic.upv.es
Fri May 3 12:06:08 CDT 2013
El 03/05/2013, a las 17:53, Dharmendar Reddy escribió:
> Hello,
> this is the exact command i use:
> login4$ ./configure --with-arpack-flags="-Wl,-rpath,$HOME/LocalApps/lib -L$HOME/LocalApps/lib -lparpack -larpack"
> Checking environment...
> Checking PETSc installation...
> Checking ARPACK library...
> ERROR: Unable to link with library ARPACK
> ERROR: In directories /usr/local/lib
> ERROR: With flags -L/usr/local/lib -Wl -rpath /home1/00924/Reddy135/LocalApps/lib -L/
> home1/00924/Reddy135/LocalApps/lib -lparpack -larpack
> ERROR: See "mpi_rScalar_Debug/conf/configure.log" file for details
> configure step is removing the commas and adding -L/usr/local/lib
Yes, you are right. We do a very simple parsing of configure options and currently do not allow options containing commas. This is a bad solution and will try to fix it for the next release.
Jose
