[petsc-users] SLepc configure with Arpack
Jose E. Roman
jroman at dsic.upv.es
Fri May 3 10:33:35 CDT 2013
El 03/05/2013, a las 17:11, Dharmendar Reddy escribió:
> Hello,
> I am trying to configure slpec with arpack. I installed the arpack-ng-3.2 in my home directory : $HOME/arpack
> i configure slpec as:
> ./configure --with-arpack-dir=$HOME/arpack/lib --with-arpack-flags='-lparpack -larpack"
> The configure wroks, i could compile the code. However, tests fails.
> I do not have $HOME/arpack/lib in the LD_LIBRARY_PATH. Tests pas iff i add arpack lib path to LD_LIB_PATH.
> I do not want to do that, i want to the configure to take care of the rpath
> I tried --with-arpack-flags="-Wl, rpath, $HOME/arpack/lib -L$HOME/arpack/lib -lparpack -larpack"
> This does not work.
> What should i do ?
> thanks
> Reddy
I think you have to add a dash before rpath and remove the blank before $HOME/arpack/lib. See examples here
http://stackoverflow.com/questions/6562403/i-dont-understand-wl-rpath-wl
Jose
