[petsc-users] Advice Being Sought
Jed Brown
jedbrown at mcs.anl.gov
Wed Apr 24 07:11:23 CDT 2013
David Scott <d.scott at ed.ac.uk> writes:
> I am uncertain what I should do precisely. With reference to the code
> that I attached to a previous message should I insert something like
> PetscViewer viewer
> call MatView(B, viewer, ierr)
> call PetscViewerBinaryOpen(PETSC_COMM_WORLD, 'BinaryMatrix', &
> FILE_MODE_WRITE, viewer, ierr)
You can't use the viewer before you open the viewer, so you'll have to
swap the two lines above.
> call PetscViewerDestroy(viewer, ierr)
> in compute_matrix after B has been assembled (and similar code in
> compute_rhs).
You can just check for error/non-convergence when you call KSPSolve and
write the matrix and vector at that time. You can put them in the same
file:
call PetscViewerBinaryOpen(PETSC_COMM_WORLD, 'DifficultSystem', &
call MatView(B, viewer, ierr) ! use KSPGetOperators() if needed
call VecView(X, viewer, ierr) ! use KSPGetRhs() if needed
