[petsc-users] Advice Being Sought
Mark F. Adams
mark.adams at columbia.edu
Tue Apr 23 03:39:21 CDT 2013
On Apr 22, 2013, at 12:26 PM, David Scott <d.scott at ed.ac.uk> wrote:
> Thanks for the suggestion.
> I had tried '-pc_type gamg -pc_gamg_agg_nsmooths 1' with an earlier version of the code without success. I have tried it again but I get NaN's after only 90 time steps whereas with block Jacobi it runs quite happily for 36,000 time steps and produces physically sensible results.
I have had good success with the robustness of hypre. So you might want to try that.
It sounds like these pressure solves are changing over time. Using
-pc_gamg_reuse_interpolation false
with GAMG will make it more robust to that.
> David
> On 22/04/2013 13:12, Matthew Knepley wrote:
>> On Mon, Apr 22, 2013 at 7:56 AM, David Scott <d.scott at ed.ac.uk
>> <mailto:d.scott at ed.ac.uk>> wrote:
>> Hello,
>> I am working on a fluid-mechanical code to solve the two-phase
>> Navier–Stokes equations with levelset interface capturing. I have
>> been asked to replace the pressure calculation which uses the SOR
>> and Jacobi iterative schemes with a Krylov subspace method. I have
>> done this and the code is working but as I have never used PETSc
>> before I would like to know if improvements to my code, or the run
>> time parameters that I am using, could be made.
>> I am using GMRES with a Block Jacobi pre-conditioner. I have tried
>> Conjugate Gradient with a Block Jacobi pre-conditioner but it
>> diverges. If I use GMRES for the first few thousand time steps and
>> then swap to CG it does converge but the speed of execution is
>> somewhat reduced.
>> Krylov methods do not work with preconditioners. You have a Poisson
>> problem, so as abundantly documented in the literature, you should use
>> multigrid. The easiest thing to try is
>> Thanks,
>> Matt
>> I have attached relevant excerpts from the code.
>> Yours sincerely,
>> David Scott
>> Dr. D. M. Scott
>> Applications Consultant
>> Edinburgh Parallel Computing Centre
>> Tel. 0131 650 5921
>> The University of Edinburgh is a charitable body, registered in
>> Scotland, with registration number SC005336.
>> experiments is infinitely more interesting than any results to which
>> their experiments lead.
>> -- Norbert Wiener
> Dr. D. M. Scott
> Tel. 0131 650 5921
