[petsc-users] maintaining application compatibility with 3.1 and 3.2
Alexei Matveev alexei.matveev+petsc at gmail.com
Thu Apr 18 07:26:41 CDT 2013
> Do I understand it correctly that there is no way currently to load a
>> distributed
>> Vec from the file without knowing and setting its dimensions first?
> I am not sure what you mean here. The point is that prescribing the layout
> of a Vec
> in a file is clearly wrong. We would like to be able to save from one
> parallel configuration
> and load on another (maybe serial). Thus, the loader prescribes the layout.
I see. You understood me correctly. I used that feature to to quickly load
a Vec from a file and dump it in ACSII or to do simple arithmetics.
Admittedly
that was usually done in serial runs.
So the comment here is actually wrong, since you say it is not going to be
supported by any viewer/loader pair?
/* This one is supposed to save enough meta-info (such as distribution
   pattern, dimensions) to recover the vector from scratch: */
void vec_save (const char file[], const Vec vec)
  PetscViewer viewer;
  PetscViewerBinaryOpen (PETSC_COMM_WORLD, file, FILE_MODE_WRITE, &viewer);
  VecView (vec, viewer);
  PetscViewerDestroy (viewer);
Sorry for spamming the channel,
Alexei.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130418/a14316f2/attachment.html>
