[petsc-users] maintaining application compatibility with 3.1 and 3.2
Matthew Knepley
knepley at gmail.com
Thu Apr 18 07:13:20 CDT 2013
On Thu, Apr 18, 2013 at 8:08 AM, Alexei Matveev <
alexei.matveev+petsc at gmail.com> wrote:
> Hi, All,
> Thanks for your comments.
> On 17 April 2013 23:35, Barry Smith <bsmith at mcs.anl.gov> wrote:
>> It is our intention that PETSc be easy enough for anyone to
>> install that rather than making your application work with different
>> versions one simply install the PETSc version one needs. In addition we
>> recommend updating applications to work with the latest release within a
>> couple of months after each release.
> I understand that. With rapid development it is unavoidable to break
> API occasionally.
> I managed to compile and run the code with the quick hack below and
> somewhat
> more. Thanks, Kirk! Need yet to find out why the tests fail.
> Do I understand it correctly that there is no way currently to load a
> distributed
> Vec from the file without knowing and setting its dimensions first?
I am not sure what you mean here. The point is that prescribing the layout
of a Vec
in a file is clearly wrong. We would like to be able to save from one
parallel configuration
and load on another (maybe serial). Thus, the loader prescribes the layout.
Matt
> Like I was doing here:
> +# if PETSC_VERSION < 30200
> VecLoad (viewer, VECMPI, &vec); /* creates it */
> +#else
> + /* FIXME: how to make it distributed? */
> + VecCreate (PETSC_COMM_WORLD, &vec);
> + VecLoad (vec, viewer);
> +#endif
> BTW, I found myself calling (DM)DAGetInfo() on the array descriptor DM/DA
> quite often to get the shape of the 3d grid. I noticed that now that the
> signature
> of the *GetInfo() changed. Is there an official way to get that shape info
> by enquiring
> the Vec itself?
> Alexei
> -#include "petscda.h" /* Vec, Mat, DA, ... */
> +#include "petscdmda.h" /* Vec, Mat, DA, ... */
> #include "petscdmmg.h" /* KSP, ... */
> +#define PETSC_VERSION (PETSC_VERSION_MAJOR * 10000 + PETSC_VERSION_MINOR
> * 100)
> +/* FIXME: PETSC 3.2 */
> +#if PETSC_VERSION >= 30200
> +typedef DM DA;
> +typedef PetscBool PetscTruth;
> +# define VecDestroy(x) (VecDestroy)(&(x))
> +# define VecScatterDestroy(x) (VecScatterDestroy)(&(x))
> +# define MatDestroy(x) (MatDestroy)(&(x))
> +# define ISDestroy(x) (ISDestroy)(&(x))
> +# define KSPDestroy(x) (KSPDestroy)(&(x))
> +# define SNESDestroy(x) (SNESDestroy)(&(x))
> +# define PetscViewerDestroy(x) (PetscViewerDestroy)(&(x))
> +# define PCDestroy(x) (PCDestroy)(&(x))
> +# define DADestroy(x) (DMDestroy)(&(x))
> +# define DAGetCorners DMDAGetCorners
> +# define DACreate3d DMDACreate3d
> +# define DACreateGlobalVector DMCreateGlobalVector
> +# define DAGetGlobalVector DMGetGlobalVector
> +# define DAGetInfo DMDAGetInfo
> +# define DAGetMatrix DMGetMatrix
> +# define DARestoreGlobalVector DMRestoreGlobalVector
> +# define DAVecGetArray DMDAVecGetArray
> +# define DAVecRestoreArray DMDAVecRestoreArray
> +# define VecLoadIntoVector(viewer, vec) VecLoad (vec, viewer)
> +# define DA_STENCIL_STAR DMDA_STENCIL_STAR
> +# define DA_XYZPERIODIC DMDA_XYZPERIODIC
> +#endif
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130418/c3c65582/attachment.html>
