[petsc-users] DMPlex Filed data to VTK file
Dharmendar Reddy
dharmareddy84 at gmail.com
Wed Apr 17 19:34:43 CDT 2013
Hello,
I think i finally was able to go thorugh the process of solving a
poisson problem using DMPlex object. Now i need to visualize the data.
I was looking at following lines from exmple 62:
733: if (user.runType == RUN_FULL) {734: PetscViewer
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Viewer/PetscViewer.html#PetscViewer>
viewer;735: Vec
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Vec/Vec.html#Vec>
uLocal;
737: PetscViewerCreate
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Viewer/PetscViewerCreate.html#PetscViewerCreate>(PETSC_COMM_WORLD
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PETSC_COMM_WORLD.html#PETSC_COMM_WORLD>,
&viewer);738: PetscViewerSetType
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Viewer/PetscViewerSetType.html#PetscViewerSetType>(viewer,
PETSCVIEWERVTK);739: PetscViewerSetFormat
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Viewer/PetscViewerSetFormat.html#PetscViewerSetFormat>(viewer,
PETSC_VIEWER_ASCII_VTK);740: PetscViewerFileSetName
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Viewer/PetscViewerFileSetName.html#PetscViewerFileSetName>(viewer,
"ex62_sol.vtk");
742: DMGetLocalVector
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/DM/DMGetLocalVector.html#DMGetLocalVector>(user.dm,
&uLocal);743: DMGlobalToLocalBegin
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/DM/DMGlobalToLocalBegin.html#DMGlobalToLocalBegin>(user.dm,
u, INSERT_VALUES
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/INSERT_VALUES.html#INSERT_VALUES>,
uLocal);744: DMGlobalToLocalEnd
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/DM/DMGlobalToLocalEnd.html#DMGlobalToLocalEnd>(user.dm,
u, INSERT_VALUES
uLocal);
746: PetscObjectReference
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PetscObjectReference.html#PetscObjectReference>((PetscObject
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PetscObject.html#PetscObject>)
user.dm); /* Needed because viewer destroys the DM */747:
uLocal); /* Needed because viewer destroys the Vec
*/748: PetscViewerVTKAddField
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Viewer/PetscViewerVTKAddField.html#PetscViewerVTKAddField>(viewer,
(PetscObject <http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Sys/PetscObject.html#PetscObject>)
user.dm, DMPlexVTKWriteAll
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/DM/DMPlexVTKWriteAll.html#DMPlexVTKWriteAll>,
PETSC_VTK_POINT_FIELD, (PetscObject
uLocal);749: DMRestoreLocalVector
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/DM/DMRestoreLocalVector.html#DMRestoreLocalVector>(user.dm,
&uLocal);750: PetscViewerDestroy
<http://www.mcs.anl.gov/petsc/petsc-dev/docs/manualpages/Viewer/PetscViewerDestroy.html#PetscViewerDestroy>(&viewer);751:
Can i do the same or some thing similar from fortran ? Some calls seem to
have type casting.
Othere wise if you can give me some idea on how to get the solution vector,
including the boundary values.
As of now, i access the solution using solution vector passed to snes
object but that does not give values at boundary nodes.
Thanks
Reddy
Dharmendar Reddy Palle
Graduate Student
Microelectronics Research center,
University of Texas at Austin,
10100 Burnet Road, Bldg. 160
MER 2.608F, TX 78758-4445
e-mail: dharmareddy84 at gmail.com
Phone: +1-512-350-9082
United States of America.
Homepage: https://webspace.utexas.edu/~dpr342
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130417/f0d28c9c/attachment.html>
