[petsc-users] cannot find 'libz.a' when configuring
Satish Balay
balay at mcs.anl.gov
Wed Apr 10 19:11:23 CDT 2013
send logs to petsc-maint
Satish
On Wed, 10 Apr 2013, Seungbum Koo wrote:
> Thank you. It fixed the problem. But it stopped with other message, saying
> that
> UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> details):
> --with-hdf5-dir=/opt/hdf5-1.8.9 did not work
> I asked up to which version of HDF5 does PETSc support this morning because
> of this problem, thinking if this is a compatibility reason or some sort
> similar.
> I tried to attach the configure.log file but there is 512kb limit to this
> mailing list.
> Any suggestion will help.
> Thanks.
> Seungbum
> On Wed, Apr 10, 2013 at 5:21 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > try using configure option LIBS="-L/opt/zlib-1.2.7/lib -lz'
> > Satish
> > > Hi. I tried to add hdf5 when configuring. HDF5-1.8.9 is currently
> > installed
> > > with szip-2.1 and zlib-1.2.7.
> > > It stops with message
> > > details):
> > > Compression library [libz.a or equivalent] not found
> > > What I don't understand is that 'libz.a' file exists in
> > > '/opt/zlib-1.2.7/lib'. What should I do?
> > > Seungbum
