[petsc-users] cannot find 'libz.a' when configuring
Satish Balay
balay at mcs.anl.gov
Wed Apr 10 19:37:31 CDT 2013
I could retrieve it from the one you attempted to send to petsc-users. And see:
Possible ERROR while running linker: /opt/hdf5-1.8.9/lib/libhdf5.a(H5Z.o): In function `H5Zunregister':
H5Z.c:(.text+0xa9b): undefined reference to `SZ_encoder_enabled'
/opt/hdf5-1.8.9/lib/libhdf5.a(H5Z.o): In function `H5Z_unregister':
H5Z.c:(.text+0x1872): undefined reference to `SZ_encoder_enabled'
/opt/hdf5-1.8.9/lib/libhdf5.a(H5Z.o): In function `H5Zfilter_avail':
H5Z.c:(.text+0x2592): undefined reference to `SZ_encoder_enabled'
You did mention building hdf4 with szip-2.1. So perhaps you sould
specify hdf5 - and all the dependent libraries using
--with-hdf5-include --with-hdf5-lib options [and not --with-hdf5
option]
Satish
On Wed, 10 Apr 2013, Satish Balay wrote:
> send logs to petsc-maint
> Satish
> On Wed, 10 Apr 2013, Seungbum Koo wrote:
> > Thank you. It fixed the problem. But it stopped with other message, saying
> > that
> > UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
> > details):
> > --with-hdf5-dir=/opt/hdf5-1.8.9 did not work
> > I asked up to which version of HDF5 does PETSc support this morning because
> > of this problem, thinking if this is a compatibility reason or some sort
> > similar.
> > I tried to attach the configure.log file but there is 512kb limit to this
> > mailing list.
> > Any suggestion will help.
> > Thanks.
> > Seungbum
> > On Wed, Apr 10, 2013 at 5:21 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> > > try using configure option LIBS="-L/opt/zlib-1.2.7/lib -lz'
> > > Satish
> > > > Hi. I tried to add hdf5 when configuring. HDF5-1.8.9 is currently
> > > installed
> > > > with szip-2.1 and zlib-1.2.7.
> > > > It stops with message
> > > > details):
> > > > Compression library [libz.a or equivalent] not found
> > > > What I don't understand is that 'libz.a' file exists in
> > > > '/opt/zlib-1.2.7/lib'. What should I do?
> > > > Seungbum
