[petsc-users] cannot find 'libz.a' when configuring
Seungbum Koo
doougsini at gmail.com
Wed Apr 10 18:59:02 CDT 2013
Thank you. It fixed the problem. But it stopped with other message, saying
that
UNABLE to CONFIGURE with GIVEN OPTIONS (see configure.log for
details):
--with-hdf5-dir=/opt/hdf5-1.8.9 did not work
I asked up to which version of HDF5 does PETSc support this morning because
of this problem, thinking if this is a compatibility reason or some sort
similar.
I tried to attach the configure.log file but there is 512kb limit to this
mailing list.
Any suggestion will help.
Thanks.
Seungbum
On Wed, Apr 10, 2013 at 5:21 PM, Satish Balay <balay at mcs.anl.gov> wrote:
> try using configure option LIBS="-L/opt/zlib-1.2.7/lib -lz'
> Satish
> On Wed, 10 Apr 2013, Seungbum Koo wrote:
> > Hi. I tried to add hdf5 when configuring. HDF5-1.8.9 is currently
> installed
> > with szip-2.1 and zlib-1.2.7.
> > It stops with message
> > details):
> > Compression library [libz.a or equivalent] not found
> > What I don't understand is that 'libz.a' file exists in
> > '/opt/zlib-1.2.7/lib'. What should I do?
> > Seungbum
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20130410/80c195fc/attachment.html>
