[petsc-users] PETSc installed without X windows on this machine
w_ang_temp w_ang_temp at 163.com
Wed May 30 21:39:09 CDT 2012
Hello Satish
       I think I need to reconfigure Petsc with the option --with-X=1.
       Thanks.
                                                      Jim
At 2012-05-30 23:41:51,"Satish Balay" <balay at mcs.anl.gov> wrote:
>On Wed, 30 May 2012, w_ang_temp wrote:
>> Hello
>>     When I try to view a matrix with the option -mat_view_draw, I get :
>>     [0]PETSC ERROR: PETSc installed without X windows on this machine proceeding without graphics.
>>     But calling MatView in side the code is ok.
>>     I install the libX11-dev as Matt said in one message in the petsc-users in 2008,  but the problem doesn't solved.
>Perhaps you didn't re-run configure/make after installing libX11-dev
>Satish
>>     The system is ubuntu 10.04.
>>     So what might be the reason?
>>     Thanks.
>>                                           Jim
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120531/34fdfdef/attachment.html>
