[petsc-users] PETSc installed without X windows on this machine
Wed May 30 10:41:51 CDT 2012
On Wed, 30 May 2012, w_ang_temp wrote:
> Hello
>     When I try to view a matrix with the option -mat_view_draw, I get :
>     [0]PETSC ERROR: PETSc installed without X windows on this machine proceeding without graphics.
>     But calling MatView in side the code is ok.
>     I install the libX11-dev as Matt said in one message in the petsc-users in 2008,  but the problem doesn't solved.
Perhaps you didn't re-run configure/make after installing libX11-dev
Satish
>     The system is ubuntu 10.04.
>     So what might be the reason?
>     Thanks.
>                                           Jim
