[petsc-users] KSPSetDiagonalScale
Jed Brown five9a2 at gmail.com
Thu May 17 14:32:49 CDT 2012
It just means that both matrix arguments A and B are the same.
What happens if you use this direct solver as a preconditioner?
On May 17, 2012 2:23 PM, "Colin McAuliffe" <cjm2176 at columbia.edu> wrote:
> Hello!
> I am solving a coupled multiphysics problem which has several different
> units, which leads to a poorly conditioned jacobian. I am using the
> following ksp options:
> -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package umfpack
> The results I am getting are not right and I suspect that the conditioning
> of the jacobian may be playing a part in that. I would like to improve the
> conditioning by using -ksp_diagonal_scale, but adding it does not seem to
> help. The documentation for this option says 'this routine is only used if
> the matrix and preconditioner matrix are the same thing'.
> Does that mean the command can only be used with no preconditioner?
> http://www.mcs.anl.gov/petsc/**petsc-current/docs/**manualpages/KSP/**
> KSPSetDiagonalScale.html<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPSetDiagonalScale.html>
> All the best,
> Colin McAuliffe
> PhD Candidate
> Columbia University
> Department of Civil Engineering and Engineering Mechanics
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120517/44d014a6/attachment-0001.htm>
