[petsc-users] KSPSetDiagonalScale
Colin McAuliffe
cjm2176 at columbia.edu
Thu May 17 14:50:27 CDT 2012
Using the direct solver as a preconditioner I can't seem to find any
difference between the results with -ksp_diagonal_scale vs the results
without this option. I also cant tell if the diagonal scaling is
actually being applied in this case.
Quoting Jed Brown <five9a2 at gmail.com>:
> It just means that both matrix arguments A and B are the same.
> What happens if you use this direct solver as a preconditioner?
> On May 17, 2012 2:23 PM, "Colin McAuliffe" <cjm2176 at columbia.edu> wrote:
>> Hello!
>> I am solving a coupled multiphysics problem which has several different
>> units, which leads to a poorly conditioned jacobian. I am using the
>> following ksp options:
>> -ksp_type preonly -pc_type lu -pc_factor_mat_solver_package umfpack
>> The results I am getting are not right and I suspect that the conditioning
>> of the jacobian may be playing a part in that. I would like to improve the
>> conditioning by using -ksp_diagonal_scale, but adding it does not seem to
>> help. The documentation for this option says 'this routine is only used if
>> the matrix and preconditioner matrix are the same thing'.
>> Does that mean the command can only be used with no preconditioner?
>> http://www.mcs.anl.gov/petsc/**petsc-current/docs/**manualpages/KSP/**
>> KSPSetDiagonalScale.html<http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPSetDiagonalScale.html>
>> All the best,
>> Colin McAuliffe
>> PhD Candidate
>> Columbia University
>> Department of Civil Engineering and Engineering Mechanics
Colin McAuliffe
PhD Candidate
Columbia University
