[petsc-users] KSPSetDiagonalScale
Colin McAuliffe
cjm2176 at columbia.edu
Thu May 17 14:23:35 CDT 2012
Hello!
I am solving a coupled multiphysics problem which has several
different units, which leads to a poorly conditioned jacobian. I am
using the following ksp options:
-ksp_type preonly -pc_type lu -pc_factor_mat_solver_package umfpack
The results I am getting are not right and I suspect that the
conditioning of the jacobian may be playing a part in that. I would
like to improve the conditioning by using -ksp_diagonal_scale, but
adding it does not seem to help. The documentation for this option
says 'this routine is only used if the matrix and preconditioner
matrix are the same thing'.
Does that mean the command can only be used with no preconditioner?
http://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/KSP/KSPSetDiagonalScale.html
All the best,
Colin McAuliffe
PhD Candidate
Columbia University
Department of Civil Engineering and Engineering Mechanics
