[petsc-users] How much memory does TS use (in terms of # of matrices)
Andrew Spott andrew.spott at gmail.com
Wed May 16 08:38:55 CDT 2012
I'm honestly not sure why I did that, however what I thought would be the obvious fix ( 'Mat h = *A' ) isn't, I'm still getting the error.
Is there a reason I can't do that?
-Andrew
On May 16, 2012, at 7:17 AM, Jed Brown wrote:
> On Wed, May 16, 2012 at 7:08 AM, Andrew Spott <andrew.spott at gmail.com> wrote:
> Not until you pointed it out… :).  Though it probably should have been.  It was late.
> Though I'm not sure how to fix that… should I do a MatDestroy(A) at the beginning of that function every time?.
> Is *A a pointer to the last used matrix, should I just do the mat duplicate into A?
> Do you really mean to only change A (the operator), but not B (the preconditioning matrix)?
> Why do you want to create a new matrix instead of reusing those?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120516/b52b1c4c/attachment.htm>
