[petsc-users] How much memory does TS use (in terms of # of matrices)
Wed May 16 08:17:32 CDT 2012
On Wed, May 16, 2012 at 7:08 AM, Andrew Spott <andrew.spott at gmail.com>wrote:
> Not until you pointed it out… :).  Though it probably should have been.
>  It was late.
> Though I'm not sure how to fix that… should I do a MatDestroy(A) at the
> beginning of that function every time?.
> Is *A a pointer to the last used matrix, should I just do the mat
> duplicate into A?
Do you really mean to only change A (the operator), but not B (the
preconditioning matrix)?
Why do you want to create a new matrix instead of reusing those?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120516/5b2ea259/attachment-0001.htm>
