[petsc-users] Linesearch algorithm
behzad baghapour behzad.baghapour at gmail.com
Tue May 15 01:26:00 CDT 2012
Thanks. Actually the jacobian which I obtain has a part of transient as J =
M/dt + dR/dQ. Then I want to eliminate the time effect before calculating
R^T*J*dQ as the descent direction. So, which way is correct in my case?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120515/34b087a2/attachment.htm>
