[petsc-users] External package SCALAPACK does not work on Microsoft Windows
Pham Van pham_ha at yahoo.com
Fri Mar 16 00:23:20 CDT 2012
Dear Team,
I used to compile petsc with external package mumps in version 3.1
However, today I tried 3.2 and get many of such error massage:
It happens also with blacs. How can I build mumps without those pakages?
Kind regards,
PVH
 From: "petsc-users-request at mcs.anl.gov" <petsc-users-request at mcs.anl.gov>
To: petsc-users at mcs.anl.gov
Sent: Friday, March 16, 2012 8:24 AM
Subject: petsc-users Digest, Vol 39, Issue 48
Send petsc-users mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
    https://lists.mcs.anl.gov/mailman/listinfo/petsc-users
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
    petsc-users-owner at mcs.anl.gov
When replying, please edit your Subject line so it is more specific
than "Re: Contents of petsc-users digest..."
Today's Topics:
   1. Re:  [petsc-maint #107932] run a simple example ex19 in
      src/snes/examples/tutorials (Xiangze Zeng)
Message: 1
Date: Fri, 16 Mar 2012 09:24:24 +0800 (CST)
Subject: Re: [petsc-users] [petsc-maint #107932] run a simple example
    ex19 in src/snes/examples/tutorials
To: "PETSc users list" <petsc-users at mcs.anl.gov>
Message-ID:
    <6d1d77a7.1c6ef.136191b0a3b.Coremail.zengshixiangze at 163.com>
Content-Type: text/plain; charset="gbk"
I can see log_summary output when I use -log_summary [filename].
But the time of inserting the matrices values is almost the same when I use PCJACOBI  to run the code on GPU instead of PCSOR.They are all much longer than that when I run the code in CPU(I still use a small system to test it). The attachments are outputs of log_summary, c_jacobi_sum is the output of using CPU, PCJACOBI;g_sor_sum using GPU, PCSOR;g_jac_sum using GPU, PCJACOBI.
Zeng
? 2012-03-15 22:26:41?"Jed Brown" <jedbrown at mcs.anl.gov> ???
2012/3/15 Xiangze Zeng <zengshixiangze at 163.com>
Sorry, someting is wrong with my file which stores the size of the matriex.
But I still can't see -log_summary output. I just see at the first time, after that, never.
It is written by PetscFinalize(). Find out why you don't get there. Also note that the option needs to be visible at PetscInitialize (through the command line/options file/environment).
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120316/080214eb/attachment.htm>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120316/080214eb/attachment.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120316/080214eb/attachment-0001.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120316/080214eb/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120316/080214eb/attachment-0003.obj>
End of petsc-users Digest, Vol 39, Issue 48
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120315/c25a7b62/attachment.htm>
