[petsc-users] GAMG issue
Mark F. Adams
mark.adams at columbia.edu
Thu Mar 15 12:19:43 CDT 2012
On Mar 15, 2012, at 11:24 AM, Jed Brown wrote:
> On Wed, Mar 14, 2012 at 11:27, Mark F. Adams <mark.adams at columbia.edu> wrote:
>> The matrix is asymmetric. Does this require the setting of an option?
> Yes: -pc_gamg_sym_graph
> Mark, I don't like this name. First, it's imperative in the sense that it's describing a procedure for fixing something rather than declarative (stating some property of the problem). Second, there is already a way to state symmetry, MatSetOption():
Good point, I've added:
ierr = MatIsSymmetricKnown(Amat, &set, &flg); CHKERRQ(ierr);
symm = pc_gamg_agg->sym_graph || !(set && flg);
> Options Describing Matrix Structure:
> + MAT_SPD - symmetric positive definite
> - MAT_SYMMETRIC - symmetric in terms of both structure and value
> . MAT_HERMITIAN - transpose is the complex conjugation
> . MAT_STRUCTURALLY_SYMMETRIC - symmetric nonzero structure
> - MAT_SYMMETRY_ETERNAL - if you would like the symmetry/Hermitian flag
> you set to be kept with all future use of the matrix
> including after MatAssemblyBegin/End() which could
> potentially change the symmetry structure, i.e. you
> KNOW the matrix will ALWAYS have the property you set.
> Is there a reason you can't just use this information? If you have multiple methods for handling nonsymmetric structure, then I would suggest using PetscOptionsList() or PetscOptionsEnum() to select which to use.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120315/baa15c1d/attachment-0001.htm>
