[petsc-users] GAMG issue
Jed Brown
jedbrown at mcs.anl.gov
Thu Mar 15 10:24:14 CDT 2012
On Wed, Mar 14, 2012 at 11:27, Mark F. Adams <mark.adams at columbia.edu>wrote:
> The matrix is asymmetric. Does this require the setting of an option?
> Yes: -pc_gamg_sym_graph
Mark, I don't like this name. First, it's imperative in the sense that it's
describing a procedure for fixing something rather than declarative
(stating some property of the problem). Second, there is already a way to
state symmetry, MatSetOption():
Options Describing Matrix Structure:
+ MAT_SPD - symmetric positive definite
- MAT_SYMMETRIC - symmetric in terms of both structure and value
. MAT_HERMITIAN - transpose is the complex conjugation
. MAT_STRUCTURALLY_SYMMETRIC - symmetric nonzero structure
- MAT_SYMMETRY_ETERNAL - if you would like the symmetry/Hermitian flag
you set to be kept with all future use of the
matrix
including after MatAssemblyBegin/End() which
could
potentially change the symmetry structure, i.e.
you
KNOW the matrix will ALWAYS have the property
you set.
Is there a reason you can't just use this information? If you have multiple
methods for handling nonsymmetric structure, then I would suggest using
PetscOptionsList() or PetscOptionsEnum() to select which to use.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120315/5ec6d4c0/attachment.htm>
