[petsc-users] ccgraph.c error
    Mohammad Mirzadeh
    mirzadeh at gmail.com
    Thu Mar  1 13:59:30 CST 2012
The only reason I did it by hand was I could not find it -- its
totally weird how I missed it there!
thanks anyways.
On Thu, Mar 1, 2012 at 11:55 AM, Sean Farley <sean at mcs.anl.gov> wrote:
> I was also having this problem (assertion fails) when using ParMetis 3.2
>> as a part of PETSc 3.2-p6. I could fix it by installing ParMetis 4.0.2
>> directly and passing the header/libs to petsc (check the chages in
>> http://glaros.dtc.umn.edu/gkhome/metis/parmetis/changes) .
> If you're monkeying around this much with PETSc, why not just switch to
> petsc-dev?
>>  I do not see this version of ParMetis in the petsc ftp site, what
>> version is used in petsc-dev?
> ftp://ftp.mcs.anl.gov/pub/petsc/externalpackages/parmetis-4.0.2-p1.tar.gz
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120301/cba5521a/attachment.htm>
