[petsc-users] ccgraph.c error
Sean Farley sean at mcs.anl.gov
Thu Mar 1 13:55:09 CST 2012
> I was also having this problem (assertion fails) when using ParMetis 3.2
> as a part of PETSc 3.2-p6. I could fix it by installing ParMetis 4.0.2
> directly and passing the header/libs to petsc (check the chages in
> http://glaros.dtc.umn.edu/gkhome/metis/parmetis/changes) .
If you're monkeying around this much with PETSc, why not just switch to
petsc-dev?
>  I do not see this version of ParMetis in the petsc ftp site, what version
> is used in petsc-dev?
ftp://ftp.mcs.anl.gov/pub/petsc/externalpackages/parmetis-4.0.2-p1.tar.gz
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120301/7bc92f2e/attachment.htm>
