[petsc-users] ccgraph.c error
    Mohammad Mirzadeh
    mirzadeh at gmail.com
    Thu Mar  1 13:51:12 CST 2012
Hi all,
I was also having this problem (assertion fails) when using ParMetis 3.2 as
a part of PETSc 3.2-p6. I could fix it by installing ParMetis 4.0.2
directly and passing the header/libs to petsc (check the chages in
http://glaros.dtc.umn.edu/gkhome/metis/parmetis/changes) . I do not see
this version of ParMetis in the petsc ftp site, what version is used in
petsc-dev?
Mohammad
On Thu, Mar 1, 2012 at 10:32 AM, Sean Farley <sean at mcs.anl.gov> wrote:
> On Thu, Mar 1, 2012 at 12:09 PM, John Fettig <john.fettig at gmail.com>wrote:
>> Sorry to dig up an old thread (I seem to have a tendency of doing that
>> here!), but this problem exists in petsc-3.2-p6 with MUMPS and Metis as
>> well.  Looking at the differences between the dev version of mump.c and the
>> release version, I don't see anything that would have obviously fixed
>> this.  Could you give me a hint about what was changed?  Is it as simple as
>> using the updated Metis package (in dev)?  How difficult would it be to
>> backport the fix to the released version?
> It'd be pretty murky to do this. Start by looking at this changeset:
> http://petsc.cs.iit.edu/petsc/petsc-dev/rev/0c0bf07c7a32
> Luckily, you just need to look at revisions that I authored (
> sean at mcs.anl.gov): hg log -r 'user(sean)'. The *real* difficultly would
> be the changes I made to SuperLU_DIST, MUMPS, and SuiteSparse and hope that
> it all works together for 3.2p6.
> Related question, would it be a problem to just use petsc-dev?
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120301/c932d37a/attachment.htm>
