[petsc-users] Multigrid preconditioning
Michele Rosso
mrosso at uci.edu
Mon Jul 30 16:06:33 CDT 2012
I am solving a variable coefficients Poisson equation with periodic BCs.
The equation is discretized by using the standard 5-points stencil
finite differencing scheme.
I managed to solve the system successfullywith the PCG method and now I
would like to add
a preconditioner to speed up the calculation. My idea is to use the
multigrid preconditioner.
Example ex22f.F implements what I think I need.
If I understand correctly example ex22f.F, the subroutines "ComputeRHS"
and "ComputeMatrix" define how the
matrix and rhs-vector have to be computed at each level.
In my case tough, both the jacobian and the rhs-vector cannot be
computed "analytically", that is, they depend on variables
whose values are available only at the finest grid.
How can I overcome this difficulty?
Thank you,
Michele
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120730/607864a2/attachment.html>
