[petsc-users] Multigrid preconditioning
    Jed Brown
    jedbrown at mcs.anl.gov
    Mon Jul 30 16:18:14 CDT 2012
On Mon, Jul 30, 2012 at 4:06 PM, Michele Rosso <mrosso at uci.edu> wrote:
>  Hi,
> I am solving a variable coefficients Poisson equation with periodic BCs.
> The equation is discretized by using the standard 5-points stencil finite
> differencing scheme.
> I managed to solve the system successfully with the PCG method and now I
> would like to add
> a preconditioner to speed up the calculation. My idea is to use the
> multigrid preconditioner.
> Example ex22f.F implements what I think I need.
> If I understand correctly example ex22f.F, the subroutines "ComputeRHS"
> and "ComputeMatrix" define how the
> matrix and rhs-vector have to be computed at each level.
> In my case tough, both the jacobian and the rhs-vector cannot be computed
> "analytically", that is, they depend on variables
> whose values are available only at the finest grid.
> How can I overcome this difficulty?
Two possibilities:
1. homogenize on your own and rediscretize
2. use Galerkin coarse operators (possibly with algebraic multigrid)
Option 2 is much more convenient because it never
For geometric multigrid using DMDA, just use -pc_type mg -pc_mg_galerkin
For algebraic multigrid, use -pc_type gamg -pc_gamg_agg_nsmooths 1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20120730/93592b83/attachment.html>
